What did you do to your TJ today? - Page 53 - JeepForum.com
 395Likes
post #781 of 112004 Old 03-29-2006, 10:07 AM
cmorganf64
Not today, but my day off Monday.....
Cut down the front bumper...I really like it!
Painted the front bumper
Painted the milk jugs on the back bumper till I can weld the cut-offs from the front to the back bumper
Painted the license plate holder
Installed 10K lbs tow hooks
Finished the shelf for the 12' sub box and stapped it down. (I like the mild boom)
Washed the green beast and was going to pin-stipe it but couldnt find the new pins I bought (cheesy...maybe, but I kind of like the look)
Really scrubbed the soft top....I think Im gonna try somple green next time for a couple of stains...but I cnt really bring myself to spray that stuff on the top and let it get to the paint....
Thats it I think!
Good manly day.....got to tinker with the jeep!
ChrisM
cmorganf64 is offline
post #782 of 112004 Old 03-29-2006, 10:22 AM
de6w6it
Finally got around to putting in a home-made hand throttle.
I also assembled my little electrical box to hook up to my MAP sensor to be able to adjust it's input voltage to in turn adjust the duty cycle on the injectors. Gonna be great to be able to tune that... Now I just have to install it....
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:
de6w6it is offline
post #783 of 112004 Old 03-29-2006, 12:19 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Why would you want/need to do that?
I'll be Savvy someday!
neZZr is offline
post #784 of 112004 Old 03-29-2006, 12:27 PM
BigJeepJay
BigJeepJay's Avatar
I was wondering the same thing.
Pics...
TJ Stretch Thread...
BigJeepJay is offline
post #785 of 112004 Old 03-29-2006, 02:08 PM
Deezul
Deezul's Avatar
It's for time travel silly!!
2004 Khaki Rubicon. Jeeperman Custom Brushguard and 54" bumper, Kilby steering skid, Skidrow radiator skid, SRC Rockcrawler rocker guards, UFW Al Engine Skid, OME Shocks, JKS Quicker Discos, AEM Dryflo intake;KC Slimlight 130W Long range lights, ORO LiteDots and LitePlate, Banks Stainless Monster cat-back, Eclipse stereo, BA Speakers, Jeeperman Handles, Cobra CB, interior leds... more to come.
**R.I.P NOW TOTALED** 98TJ Sport, 30x9.5 BFG ATKO's on AR Outlaw II's, K&N FIPK, Borla Catback,
Green jeep club member #139
Deezul is offline
post #786 of 112004 Old 03-29-2006, 02:24 PM
GaytorHater703
Finally installed my LOD HD rear bumper and tire carrier (Monday), Put on a set of locking door lugs with black plastic coating (this past saturday), and took off my am/fm radio antenna (today) and put a black one on.....keepin the black theme
GaytorHater703 is offline
post #787 of 112004 Old 03-29-2006, 02:32 PM
de6w6it
Adjusting the input voltage to the map sensor changes the duty cycle on the injectors, meaning that they stay on longer or shorter. More voltage=longer duty cycle, =more rich, and vice versa. This means you can adjust running lean to rich. A little richer mixture with some timing adjustments and you would be surprised the gains you get.
That way you can account for any modifications that would require more fuel to the motor. Everyone says that chips and programmers and such work, but that the motor relearns proper values, and you end up not getting much out of those mods. This is a permanent change to the motor settings. Also, if you upgrade injectors, or increase air flow, it can benefit you by allowing for a fine adjustment on how rich/lean the motor runs, without going through the fuel economy type filters which govern how the ecm regulates the motor.
If I wanted to time travel, I would need a flux capacitor, and those are a little harder to build than a voltage adjuster/regulator.
Build:
de6w6it is offline
post #788 of 112004 Old 03-29-2006, 03:22 PM
Toombs
Is that going to work? It's my understanding that it uses that for it's primary fuel metering, but then relies on the O2 to fine tune the mixture from there. It's not going to be happy if you alter that signal, but not the O2 feedback. It'll try to compensate or throw a code for a malfunctioning O2, I would think. Good luck with that.
Mike
Toombs is offline
post #789 of 112004 Old 03-29-2006, 03:23 PM
TJ Willy
TJ Willy's Avatar
Picked up custom Battery Cables. Gonna swap in the Yellow Top tonight hopefully for the Red Top.
2008 JK Unlimited Sahara -
SOLD: 99 TJ
SOLD: 04 TJ Willys Ed.
TJ Willy is offline
post #790 of 112004 Old 03-29-2006, 04:19 PM
MDcracker
I relocated my mirrors from my doors to the windsheild cowl on my 2003 sport. We gotta have side mirrors on in MD and I wanna take the doors off. The brackets only cost me bout 25 bucks.
MDcracker is offline
post #791 of 112004 Old 03-29-2006, 04:42 PM
Bren Gun
Bren Gun's Avatar
Finished rattle-canning my a to z rockers and removed the old side steps and mini flare in prep for them. Steps and flares up for sale now...
'99 TJ, '03 KJ and a '53 CJ3B sitting in the barn waiting on a restoration... @
Gone, but never forgotten... 1973 DJ5C, 1964 CJ5, 1953 M38A1, 1971 Hurst Special Jeepster
Bren Gun is offline
post #792 of 112004 Old 03-30-2006, 06:00 PM
Trombino
Trombino's Avatar
1978 CJ7
Just added a JKS 1.25" body lift this afternoon. Gonna tackle the BMML in the AM, along with the RE BB and get the new tires mounted (32x11.50 Kumho MT 834's).
Trombino is offline
post #793 of 112004 Old 03-30-2006, 06:48 PM
Deezul
Deezul's Avatar
IPF Fatboys with IPF E code lamps and wire harness.......I can easily see a block away, also did the fog light override.
Deezul is offline
post #794 of 112004 Old 03-30-2006, 09:05 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Finished taking the axles out, still have to drain them and get the front shafts out. They are going to be re geared and the rear is going to be locked. Also started on the Kilby OBA set up. got the compressor in and realized that I forgot to put the washers on it, so I had to take it all back apart again.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #795 of 112004 Old 03-30-2006, 09:16 PM
fireman483
Yesterday I put the insurance back on the Jeep! Sadly I took it off the truck since I sold it. But NOW I can finally get the Jeep out of the garage. Man, the thing is squirrelly, ...no more long wheelbase on the truck... I'll see you guys (and gals) on the roads and trails....so WAVE!
fireman483 is offline
modifications , tj
baron , MikeWL , tjkelowna
