What did you do to your TJ today? - Page 527 - JeepForum.com
 394Likes
post #7891 of 112001 Old 10-04-2007, 07:37 PM
chainsaw620
heat gunn'd my flares today look new
chainsaw620 is offline
post #7892 of 112001 Old 10-04-2007, 10:41 PM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
Wired up my new KC Slim Lites.
We save dogs:
JBWood05TJ is offline
post #7893 of 112001 Old 10-04-2007, 10:50 PM
UPSucks
GO BIG RED!
UPSucks's Avatar
Picked it up (last night)
It felt like forever waiting for the lift to be installed....especially since I dropped it off on saturday and they started working on it monday morning.
5.5" RE Tri-Link
Toyo Open Country MTs 35x15x13.50
Banks exhaust
Going to Uwharrie next weekend!!
UPSucks is offline
post #7894 of 112001 Old 10-05-2007, 09:32 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
last night I ...
put the front coils in
drilled and tapped the lower front spring purtches for my custom free bump stops
put the rear axle under the jeep again
attached the rear lower arms to the axle
bent the rear brake line again
today i plan to...
drill the hole for my shock mounts
rear springs
rear bumpstops
drive shaft
rear upper control arms
what will probably happen today after I get home from school and work.
get home
look at jeep and say "i need to work on that"
instead of working on jeep get on JF and screw around for an hour
look at jeep again
go inside to check mail and JF again
get stuff ready for the swap meet and load trailer for swap meet
work on jeep for a little bit
then go inside again because it's friday night and go out.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #7895 of 112001 Old 10-05-2007, 11:41 AM
goody6691
finally got my baja claws on 35-12.5 -15, now i just have to try them out.
o3 tj, yellow, currie 4 in,savvy arms, 1in bl, mml, ramsey 9500, synth line, 8.8, 456's, arb's. 35x12.5x17 mtrk's, 17x8.5 raceline beadlocks, aem, banks exhaust, psc rear stinger, no limits front stinger, rockmen corners, a-z cage, piaa lights, rampage softtop, anti-rock, AA shifter, UCF aluminum skid.........98 audi a4, fully built, 350 whp awd, yellow
goody6691 is offline
post #7896 of 112001 Old 10-05-2007, 12:58 PM
fivedive69
fivedive69's Avatar
Installed the winch....hope to try it out this weekend!!
I knew I took a wrong turn somewhere....
fivedive69 is offline
post #7897 of 112001 Old 10-05-2007, 01:17 PM
Okiiashi
Okiiashi's Avatar
Took both Jeeps out mudding
|¯¯l,[___],
l---L--OlllllllO¬
()_) ()_)---)_)RED JEEP #446
“Even if you’re on the right track, you’ll get run over if you just sit there” - Will Rogers
Okiiashi is offline
post #7898 of 112001 Old 10-05-2007, 02:28 PM
jericho2068
Took off those stupid nerf bars! They were on the Jeep when I got it,but I always thought they made my rig look too low. After taking them off ,it now looks like I got it lifted 2 inches!
jericho2068 is offline
post #7899 of 112001 Old 10-05-2007, 05:51 PM
BaddAndy
Dropped T-case and engine skid plates, swapped trans mount, removed rear driveshaft and balancer, drained t-case, then started taking T-case apart for the SYE kit. This all probably would have been completed by tonite if Quadratech would've sent me the SYE kit I ordered instaed of putting a used driveshaft in the box. At least I can take my time to do this as the parts aren't due now till Monday. Prepped rebuilt front and TW rear driveshaft for install. Loosened rear upper control arms for the adjustable ones on order.
BaddAndy is offline
post #7900 of 112001 Old 10-05-2007, 07:20 PM
LightningRod
Installed my 33x12.5 Pro Comp Wheels with 15X8 Rock Crawler Street Locks
LightningRod is offline
post #7901 of 112001 Old 10-05-2007, 09:53 PM
daniel01TJ
been working on installing the lift and tires. front is done and it looks damn good!
01 Silver TJ Anniversary edition, 4.0L 6cyl, nv3550 tranny, 3.73 gears, dana 30fr/44rr, FT 3" Economy, JKS Quicker Discos, 33x12.5 Trxus MT, 15x8 Rock Crawlers, Rokmen Sliders
daniel01TJ is offline
post #7902 of 112001 Old 10-06-2007, 09:41 AM
06flex
06flex's Avatar
Installed 1.25" body lift and 1" Brown dog motor mount lift.
Before
After
Stu website supporter.
One of the best jeep websites out there for reference. If you can help please do.
You didn't correct the problem, you only worked around the real problem.
06flex is offline
post #7903 of 112001 Old 10-06-2007, 01:33 PM
RobFromRI
i changed my serpentine belt and my air filter...
1999 Jeep Wrangler TJ 4.0 5 Speed Chili Pepper Red
2003 VW GTI 1.8T 6 Speed
Jazz Blue 20th Anniversary Edition #3177 of 4000
RobFromRI is offline
post #7904 of 112001 Old 10-06-2007, 02:23 PM
BradG
It's too darned nice out. I opened the Jeep all the way up again for the weekend at home.
2003 TJ X Silver | 31x10.50x15 BFG A/Ts | 10k front tow hooks, factory rear tow hook | 2" coil spacers | Cobra 19 with RatShack 102" stainless whip on an Arizona RockyRoad tire carrier mount | Kilby Steering Box Skid | AtoZ Fabrication Rock Sliders | Olympic Slider Rear Bumper w Receiver | Skid Row Engine/Oil/Tranny skid (still sitting in my living room)
BradG is offline
post #7905 of 112001 Old 10-06-2007, 02:57 PM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
(yesterday) Rotated the tires and installed an adjustable front track bar. Drilling the front track bar mount on the driver's side was a *****! It's roughly 13/16ths thick steel, and had to drill the existing tapered hole out to 5/8". Many thanks to mrblaine for the help with that!
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
modifications , tj
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
AftonJeeper , WinterJeep
