What did you do to your TJ today? - Page 506 - JeepForum.com
 815Likes
post #7576 of 113364 Old 09-03-2007, 11:11 AM
frankske_
Originally Posted by MuskTJ
Installed a wench .... now I have to adjust for sag ...: (
Attachment 36420
M
If you have stock springs, use XJ springs up front, that's what I did at first. I'll be 1/2" higher than stock.
I then swapped them out for some ZJ V8 springs front and rear. Front and rear will raise 1 1/2" (they did on mine with a Warn XP 9.5 anyway).
'03 2.4 TJ, 5 speed -
- Warn 9.5 XP - 30mm MML - 1" BL - 1" flat skid - ZJ V8 springs - Bad Death Wobble
frankske_ is offline
post #7577 of 113364 Old 09-03-2007, 11:56 AM
muskoka
TJ
muskoka's Avatar
Thanks for your input ... but I got er dialed in with a set of 2" spacers
back to level
Low Output 4 Cylinder Jeep Club #36
muskoka is offline
post #7578 of 113364 Old 09-03-2007, 12:42 PM
Baotchi
Baotchi's Avatar
2010 JK Wrangler
Originally Posted by Rick98TJ
JK shocks are about an 1/8th of an inch shorter than 4" lift TJ shocks
What would happen if I run them with only a 2" lift ?
How is the ride with those shocks on a TJ ?
Black 2010 Sport JK
Black 2003 Sport TJ Gone!
Baotchi is offline
post #7579 of 113364 Old 09-03-2007, 05:43 PM
Capeman29
Did the krylon fusion trick on my fender flares, 2 hours and 3 spray cans later, my 02 looks like an 06!
Lets see how it holds up.
02 TJ, X Trim, Patriotic Blue, All Stock - - - Too Broke To Buy Any Fun Stuff
Capeman29 is offline
post #7580 of 113364 Old 09-03-2007, 05:52 PM
Tommy R
Tommy R's Avatar
Drained the water from my Warn tire carrier (about a half gallon's worth) and then fabbed a Hi-Lift mount for it.
2001 Wrangler homemade long arm, 99" WB, ARBs, alloys, 4.88s, 35" MTRs
Tommy R is offline
post #7581 of 113364 Old 09-03-2007, 06:02 PM
AlTheKillerr
AlTheKillerr's Avatar
took the steps and side skirts off. turns out i dented my body the last time i went wheelin too. i knew i tore the skirt but didnt see the body damage. looks like its time for some rocker guards
Photographer
AlTheKillerr is offline
post #7582 of 113364 Old 09-03-2007, 07:16 PM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
3 cans? I only used 1 to get mine done. Then again, I did get some chips down to the faded grey on the last wheeling trip.
We save dogs:
JBWood05TJ is offline
post #7583 of 113364 Old 09-03-2007, 07:18 PM
JBWood05TJ
JBWood05TJ's Avatar
Originally Posted by JBWood05TJ
Pulled the stock output shaft and housing in preparation for the arrival tomorrow of my new AA SYE/TW CV kit!
And then fiddled around a little with the install on my CB. Made a bracket for the antenna, tried to decide where to mount the radio itself, and decided to oreder a Tuffy o/h console for it - so I did.
We save dogs:
post #7584 of 113364 Old 09-03-2007, 07:31 PM
garthbrown
Installed a new rear axle
I replaced my broken D35 with a new Rubicon D44 housing I'd stuffed with an ARB, Moser 35 spline 1.5" axles, a ZJ disc brake conversion, and a Riddler diff cover.
Nice to have a functioning rear end again! The brakes were running hot after the first test drive, but I tweaked the parking brake shoes and it seems fine now...
I'm excited about the 35 spline rear - but I'd do it differently next time around. I originally ordered the Alloy USA Mas Grande 35 spline shafts, but after two months of run-around from 4wheel parts and Alloy USA, 4wheel parts had a set of shafts custom manufactured at Moser. Took a long time, but they took care of the problem without any extra charges. Moral of the story is that really specialized parts can take a LONG time if anything goes wrong.
garthbrown is offline
post #7585 of 113364 Old 09-04-2007, 05:43 AM
wahala
Replaced the chrome bezels with black. While I had the bezels out, I went ahead and put in new Silverstar headlights. Put on Olympic nerf bars, washed it, then proceeded to get it dirty again going mushroom hunting.
wahala is offline
post #7586 of 113364 Old 09-04-2007, 07:33 AM
Longspoon
I got my personalized tags this weekend which I then put on. Also crammed 7 people into it, coulda prolly fit a coupla more but was still fun packing 7 in...
Join these groups...
"I'm not a Republican because I grew up rich, but because I didn't want to spend
the rest of my life poor, waiting for the government to rescue me." MH
The less a man makes declarative statements, the less apt he is to look foolish in retrospect. - CR
Finally, a word to those of you out there who have yet to be offended by something I have written or said: Please be patient. I am working as fast as I can. - AC
Longspoon is offline
post #7587 of 113364 Old 09-04-2007, 08:54 AM
errinjan
New pro comp es9000 shocks
(after dismembering my left front, on our first trail ride)
New JkS disconnects
New extended brake lines (blue covered braided stainless steel )
looking into power inverter to replace BFH and old chisel (small angle grinder much more effective)
errinjan is offline
post #7588 of 113364 Old 09-04-2007, 10:55 AM
goody6691
washed the mud off from two weeks ago
o3 tj, yellow, currie 4 in,savvy arms, 1in bl, mml, ramsey 9500, synth line, 8.8, 456's, arb's. 35x12.5x17 mtrk's, 17x8.5 raceline beadlocks, aem, banks exhaust, psc rear stinger, no limits front stinger, rockmen corners, a-z cage, piaa lights, rampage softtop, anti-rock, AA shifter, UCF aluminum skid.........98 audi a4, fully built, 350 whp awd, yellow
goody6691 is offline
post #7589 of 113364 Old 09-04-2007, 11:38 AM
mtgmike
Fusion'ed my flares, headlight and fog light bezels, and put in a soundbar I bought on craigslist.
http://www.mustangmods.com/ims/u/3244/9299/193017.jpg
mtgmike is offline
post #7590 of 113364 Old 09-04-2007, 02:52 PM
Davejb
Replaced the bulbs that came with my Roundeyes with Sylvania Silverstars, replaced the stock fog bulbs with Silverstars, removed the bulb "covers" from the stock fogs, and cut the tabs off the bottom and angled them slightly outboard.
2006 Wrangler Unlimited
Vote Quimby
Davejb is offline
modifications , tj
