Installed a new Blower motor relay yesterday. Now all the speeds work again.
Put in a pair of new Headlights. Went with Phillips Xtra visions, because the store was out of Silverstars...Still better than before.
Looked around for the reason why no air was coming out of the Panel vents. Found a vacuum line had fallen off one of the actuators under the dash. Works now, but only when i turn it to defrost first, then turn it back to panel. Whatever.
Ever since i bought the Jeep, the driver's side floor always gets soaking wet after a storm. So i got the trusty hose out and sprayed around. Nothing at first. Then i placed it right over the cowl vent to try and flood it. No leak there, either. Then i ran it on top of the roof towards the driver's side so the water would cascade over the driver's door: Bull's eye! The leak didn't start immediately, but when it started it was like river coming into the cab! It was coming in from the A pillar. Not sure how high it started but i actually saw water coming in at the seal where the window meets the tub. it was at the door end of the seal. It looks like a big, square block and the A pillar trim sits on top of it. I also noted that the plastic A pillar trim has this sticky foam strip on the one side. So i got out some black RTV silicone and filled in some places. Hopefully that did the trick. Will let you all know when it rains next or when i get time to stick the hose out.
