What did you do to your TJ today? - Page 5018 - JeepForum.com
 1224Likes
post #75256 of 114039 Old 10-11-2012, 02:03 PM
wwch99tj
Originally Posted by Neudiin
That is a nice clean Jeep. Looks good all cleaned up =)
Thanks
wwch99tj is offline
post #75257 of 114039 Old 10-11-2012, 02:43 PM
XxJeepOrDiexX
Originally Posted by wwch99tj
Decided today was the day to switch tops...
I scrubbed the soft top and gave the Jeep a bath then I removed the top and sat it aside to dry
I gave the Jeep a good coat of wax before winter
All cleaned up and ready for the hardtop I took just one last toppless ride for te season
My wife and I sat the top in place and i bolted her down and installed the old set of upper windows that i dyed black a few months ago
I like the black soft uppers, and what mirrors are those? Looks great
XxJeepOrDiexX is offline
post #75258 of 114039 Old 10-11-2012, 03:09 PM
Maverickxeo
Today I:
Changed out front and rear PCV elbows and grommets... no more high-ish idle!
Got a factory throttle spring and put it on... I had a really heavy one, and it was getting hard on the foot.
Changed the trans fluid to RP synchomax... I can shift so much nicer now! Still a little loud, but Ive only taken it around the block twice, so that could improve yet.
Maverickxeo is offline
post #75259 of 114039 Old 10-11-2012, 03:12 PM
Yellow02
Installed my new Tattons rear CV driveshaft.
USN Jeep Club Hull #144
#83 Rubicon Sahara Edition
Yellow02 is offline
post #75260 of 114039 Old 10-11-2012, 03:19 PM
jeeptjman2000
Installed a nice cb and ordered a firestick fs and mount pics to come
jeeptjman2000 is offline
post #75261 of 114039 Old 10-11-2012, 04:05 PM
wwch99tj
Thanks. The mirrors are 03-up style like $21ea I got them from www.Rockauto.com the only thing about them is that they vibrate going down the road...
wwch99tj is offline
post #75262 of 114039 Old 10-11-2012, 04:10 PM
MedicJK
2015 JK Wrangler
Swapped in some black lug nuts.
Sienna Pearl Coat Club Member #24
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
MedicJK is offline
post #75263 of 114039 Old 10-11-2012, 04:31 PM
acres145
painted my hardtop and put on new lift supports for the back window.
acres145 is offline
post #75264 of 114039 Old 10-11-2012, 04:44 PM
wwch99tj
Now you need to paint the end of that rusty axle
wwch99tj is offline
post #75265 of 114039 Old 10-11-2012, 04:58 PM
MedicJK
2015 JK Wrangler
I was doing a lot of winter prepping, then it decided to drop below zero and snow. Got to wait for warm weather now.
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
MedicJK is offline
post #75266 of 114039 Old 10-11-2012, 05:51 PM
DKenyon28
DKenyon28's Avatar
Got these bad boys from brown Santa and got them put on today
DKenyon28 is offline
post #75267 of 114039 Old 10-11-2012, 05:55 PM
XxJeepOrDiexX
Picked up my replacement passenger side mirror, and replaced the fender decals on the passenger side. Gotta do drivers side in the morning. Tip to anyone removing factory decals, I picked up some turtle wax sticker remover for like $7, and although this may not be any better for removing adhesive, the most useful part was the top. Since trying to peel off decals with my fingers was proving useless, I figured that the give in the plastic top made it the perfect sticker remover...and it worked like a charm. Used the edge of the top, and the give kept me from damaging paint.
Hard to tell from pics, but old decals were gray, new decals are black and newer. Forgot to take before of passenger side, so before pic is drivers
After:
Also blacked out fuel filler housing using high temp header paint...we'll see how it holds up against gas
post #75268 of 114039 Old 10-11-2012, 05:56 PM
JBTJ
I would be more worried about those brake rotors. Looks like they need to be replaced.
JBTJ is offline
post #75269 of 114039 Old 10-11-2012, 05:57 PM
XxJeepOrDiexX
Not sure why it put that extra pic in at the end, and I meant to say new decals are black and BIGGER (hence the different placement of decals) instead of newer...
post #75270 of 114039 Old 10-11-2012, 06:06 PM
MedicJK
2015 JK Wrangler
That same rotor. Looks fine to me, no grooves, cracks, thickness is good, pads are good.
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
MedicJK is offline
modifications , tj
Currently Active Users Viewing This Thread: 7 (2 members and 5 guests)
moemuledeer
