Quantcast What did you do to your TJ today? - Page 501 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
Truck-Lite's New LED Headlamp SeriesTJ 5.25" Speaker Adapters - NalinMFGCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!
Old 08-29-2007, 03:25 PM   #7501
AlTheKillerr
found that i have a broken tranny mount, axle seal and i need to replace my brakes
AlTheKillerr is offline   Reply With Quote
Old 08-29-2007, 04:57 PM   #7502
BradG
How'd you find out about the tranny mount? Occasionally if I'm slipping the clutch (i.e. starting from a stop) and let the RPMs get a little too high mine starts to shake like hell. But if I'm finessing the clutch while going over a rock or something on the trail (in 4LO) it doesn't shake...
2003 TJ X Silver | 31x10.50x15 BFG A/Ts | 10k front tow hooks, factory rear tow hook | 2" coil spacers | Cobra 19 with RatShack 102" stainless whip on an Arizona RockyRoad tire carrier mount | Kilby Steering Box Skid | AtoZ Fabrication Rock Sliders | Olympic Slider Rear Bumper w Receiver | Skid Row Engine/Oil/Tranny skid (still sitting in my living room)
BradG is offline   Reply With Quote
Old 08-29-2007, 05:00 PM   #7503
03XJeep
Changed front and rear Diff oil and tightened all of the lift components and applied lock tight. I was tired of my Trak bar coming loose and giveing me death wobble.
Banks Torque Tube Header, Banks Stinger Cat-Back Stainless steel exhaust,IPF H4 Headlight Upgrade, Bushwhacker 4” Pocket Extended Fender Flares, Both Axles re-geared to 4.10:1 Ratio, Warn RockCrawler Front Bumper, Custom Built Rear Bumper, BF Goodrich 33/12.5, RE 3.5 Super flex suspension
[QUOTE]Originally posted by [B]perro ryan[/B]
we should get a betting pool going on her death. . .
I almost made $25 on anna's demise.
[/QUOTE]
[QUOTE]Originally Posted by [B]schitzangiggles[/B]
pull your mouth offa mommy's titay. Dawg
[/QUOTE]
03XJeep is offline   Reply With Quote
Old 08-29-2007, 06:20 PM   #7504
Samba242
Replaced the sealed beam headlights with IPF headlight housings and IPF X51 FatBoy bulbs. What a difference over the Silverstars and no comparison at all to the stockers!
2004 Jeep TJ Sport (Silver)
ProComp 2" lift, 32" BFG ATs, MT Classic II wheels, Warn M8000 winch
misc: tint, Rubi rocker guards, RE discos, poly bushings
Samba242 is offline   Reply With Quote
Old 08-29-2007, 06:58 PM   #7505
bigjoe611
Installed my bestop rear bumper and oversized spare tire carrier.
Never underestimate the power of stupid people in large groups.
bigjoe611 is offline   Reply With Quote
Old 08-29-2007, 07:14 PM   #7506
AlTheKillerr
mines actually an auto but it shakes really bad from 0-30 and also while im idling. i thought it was just an exhaust mount till i actually took the time to look under it. i think the mount is only 50 bucks so thats not to bad. ill hopefully be able to use my buddies shop as well and do it myself rather than pay for labor but i need to get ahold of him first.
Old 08-29-2007, 07:30 PM   #7507
TJJEEPER03
what i did
installed skyjacker dual shok steering stabilizer mad a huge difference with the bumps also miror relocation brackets and door entry gaurds
TJJEEPER03 is offline   Reply With Quote
Old 08-29-2007, 08:53 PM   #7508
StvDiego
Misconfigured DNS
Cleaned the inside
and after last weekend that was no small feat. It was Dirty. Replaced my broken driving light from the tree hit, finally aired back up from Saturday (how's that for lazy) and discovered that I have a lot more to fix, bummer
San Diego JeepForum Section
StvDiego is offline   Reply With Quote
Old 08-29-2007, 10:01 PM   #7509
silvergreentj
Chopped my txt bumper up to fit my ramsey as far back as she would go...
02 TJ with scratches
www.handegraphix.com
silvergreentj is offline   Reply With Quote
Old 08-29-2007, 11:00 PM   #7510
vegas TJ driver
Red Jeep Club Member #462
vegas TJ driver's Avatar
Tire carrier
Installed my Or-Fab tire/can carrier. Required modifying my lock box behind the back seat.
Had a hard time removing the hinge from the tailgate. Of course the allen head bolt stripped out. Attempted to drill and easy out but broke easy out. Ended up cutting head of bolt off with dremel and die grinder. Then simply put a pair of vise grips on the stud and it came right out. I also found that the tailgate is beginning to crack from the weight of the 33" spare hanging on the tailgate with an adapter to raise and move it out.
The Or-Fab tire can carrier can hold up to 200 lbs. Doing the math in my head I was not sure how close it was going to be. With a little research I discovered that gas weighs about 6.2 lbs/gal. The carrier will hold 2 jerry cans so that is a little over 30 lbs plus the cans. The spare tire weighs a whopping 73 lbs (according to my bathroom scale). With that info I should be okay to carry handyman jack if I decide I want to.
It went together pretty well I thought.
vegas TJ driver is offline   Reply With Quote
Old 08-29-2007, 11:25 PM   #7511
Panici
(O|||||||O)
Panici's Avatar
-Drilled and tapped a never used 8-ball i had lying around for years. Used the chrome collar from my crap chrome shift ball I had on for ONE DAY (too small for my hand) to dress it up abit.
-Took off the doors and plastic windows, and put on safari mirrors (WAYYYYYYYY TOO HOT TODAY FOR TOP DOWN!)
_______
|_Jeep_|
(OlllllllO)
590nm Jeep TJ Build+Life
Panici is offline   Reply With Quote
Old 08-29-2007, 11:34 PM   #7512
MickBurke
Winch and lites:
http://picasaweb.google.com/MickBurkellc/2007_08_29/photo?authkey=rO9ok9t2yF8#5104346670013128450
MickBurke is offline   Reply With Quote
Old 08-29-2007, 11:56 PM   #7513
Brice014
take your end caps off!!!
Low Output 4 Cylinder Jeep Club #420
Originally Posted by bigchevyman24
ahhhh....finally 35's...but can't we all dream of 42" TSL's???? Body Cutting, Tube Fenders, Wheelbase Lengthening, 14 Bolts, Dana60s and Detroit Lockers...dreaming is nice, isn't it??????
Maybe one day...
Brice014 is offline   Reply With Quote
Old 08-30-2007, 01:54 AM   #7514
Sairys
Location: Troy Michigan, attend college at Mich Tech Univ.
These past few days I've been working on setting up my CB antenna. Yesterday I got the mount up after work and after some consideration took the drill to the body, talk about painful first timer. The drilling went well though and ended up not even hurting the paint around the hole.
Today I came back to it all and fiddled with trying to tune the antenna, but after some screwing around figured that I'm not getting a good ground. The bolt that I drilled through the body is good to go, but the mount itself won't conduct. Now I realize that the paint insulates and tried to scratch it off, but haven't gotten deep enough yet.
Hopefully tomorrow after a half day at work I can get her tuned and running. I want to have it working right for the 9 hour drive I have from the Keweenaw down to Detroit, later that day. MMM how I love road trips in the jeep. It makes me happy on the inside.
Sairys is offline   Reply With Quote
Old 08-30-2007, 07:06 AM   #7515
jeepskinc
Fender flares came off last Sunday. Will be cleaning them up tonight in preparation for painting with Krylon Fusion this weekend. Three of the five AR62 Outlaw II wheels I have on order showed up yesterday. The other two wheels and Rubicon Express 2 inch BB should show up today or tomorrow. You can probably guess what my weekend plans are!
jeepskinc is offline   Reply With Quote
modifications, tj
Glock Forum
