What did you do to your TJ today? - Page 4987 - JeepForum.com
 1024Likes
post #74791 of 113793 Old 09-28-2012, 03:50 PM
Doubblea
Yes! Just waiting on the 30's install kit
"The beauty of the Second Amendment is that it will not be needed until they try to take it." -Thomas Jefferson
Doubblea is offline
post #74792 of 113793 Old 09-28-2012, 05:33 PM
Ron2003x
Put carpet on the trunk I made Sunday afternoon. Turned out ok
Ron2003x is offline
post #74793 of 113793 Old 09-28-2012, 05:46 PM
yabo71
Pretty HAPPY
Well the last couple of weeks my Jeep has been sounding more and more like a Diesel... With a new Tick.... I feared Cracked Manifold even though its a 2 pc, Piston Slap, Or just getting tired and needing some major work (165000 Miles)
Well I decided to take a couple oz of seafoam and run it through the Brake Booster Vacuum Line and see if smoke would poor out the a potential crackin the manifold... And oh WOWWWWW did it. Engine compartment was full of white smoke within seconds.. That told me the it a maifold/exhaust issue... I just need to find it... Well after inspecting it the best I could I found nothing wrong... UNTIL I bumped the rear Flange.... It was So loose it almost wasn't bolted together... 10 Minutes later snug as a bug..... SWEET... Sounds like it should and took care of the ticking and Dieseling sounds.....
yabo71 is offline
post #74794 of 113793 Old 09-28-2012, 06:55 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
That's a great find. Mine has sounded like a diesel for years. Maybe this is my problem, rather than a piston slap or lifter.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #74795 of 113793 Old 09-28-2012, 07:48 PM
XxJeepOrDiexX
Worked 3 hrs on the jeep and got 2 of the 7 u-joints changed. Rear driveshaft is done but I still have to do front driveshaft. I was also going to go ahead and change front axles joints, but they don't look bad at all and are not loose, so I'll wait on those. It took so long because we had to get skid plate off, take driveshaft off, and after using press to break the joints loose, we still had to cut with torch to get joints all the way out of driveshaft. Is there a better way to do this? Most people I've read about and the videos I watch either use torch or grin an angle on the cap then wedge it out.
XxJeepOrDiexX is offline
post #74796 of 113793 Old 09-28-2012, 08:22 PM
JeSimmers
JeSimmers's Avatar
Received my 4l60e transmission to transfercase adapter from Advance Adapters and new aluminum conversion radiator for my 5.3 Vortec swap. Now just waiting for my motor mounts from Advance Adapters ship, then the fun begins.
Red Jeep Club Member #454
JeSimmers is offline
post #74797 of 113793 Old 09-28-2012, 09:32 PM
Maverickxeo
With mine I used a u joint press. I rented it from an auto parts store for $200 (then when it was returned, got my whole $200 back! ) I tried it without the press and it was next to impossible. Even with the press though, I happened to bend the ear on one of my axle shafts (I did bend it back with a spring compressor set backwards).
Why did you need the skid plate off though to take off the rear shaft? Ive done it like 3 or 4 times, and not once was the skid plate in the way.
Maverickxeo is offline
post #74798 of 113793 Old 09-28-2012, 09:37 PM
0IIIIIII0
Finally installed my PSC trail corners and began installation of flush mount tail lights... I hate these short days of fall >
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #74799 of 113793 Old 09-28-2012, 09:46 PM
XxJeepOrDiexX
I went ahead and removed the skid plate because tomorrow I have to replace u-joints on front driveshaft, plus if I have time and can get the chain, I'm going to replace the transfer case chain, so skid plate would have been in the way. Glad I did drop the skid though, it was full of dried mud, I'm going to sand and repaint before I put it back on
post #74800 of 113793 Old 09-28-2012, 10:40 PM
Maverickxeo
Ah, makes sense. Just so you know, though, you can take off the front shaft without removing the skid. Its kind of a pain, but easier than dropping the skid, IMO.
post #74801 of 113793 Old 09-28-2012, 10:54 PM
XxJeepOrDiexX
Nice to know, and if I wasn't working on t-case I probably wouldn't have removed the skid...broke off one of the little bolts tying the t-case into the skid plate...I hate rust
post #74802 of 113793 Old 09-28-2012, 11:50 PM
ivester1992
Got a stock air box to replace a cheapo short ram that came with it. Very glad to have a proper set up
4.88s, 35 bfg a/t, 4.5 inch rubicon express springs, rear 4 link, single radius front, 6 inch rc 2.0 shocks, rc quick discos, eautogrilles rockers and corners.
ivester1992 is offline
post #74803 of 113793 Old 09-29-2012, 12:07 AM
Mortalis5509
Learned I twisted the rear pinion splines and bent a rim. o, yeah someone put my retaining plate on backwards for the rear shaft and I didn't pay attention to it when i installed it causeing it the spray diff fluid and toast a bearing.
Go DAWGS
Mortalis5509 is offline
post #74804 of 113793 Old 09-29-2012, 06:08 AM
PacificNWJeeper
New Stretch tank
My 97 TJ Hemi Build: http://pirate4x4.com/forum/showthread.php?t=850159
PacificNWJeeper is offline
post #74805 of 113793 Old 09-29-2012, 06:31 AM
RedwoodRubi
Originally Posted by OsteKuste
There's one on Fleabay right now. Any model from a '46 to a '71 should be the same I think. Walcks specializes in Willys parts and has a repop for $60.
Thanks!
OT: Stayed up late to finish PSC hood louvre. Up too early to start the fun all over again working on the lawn mower... Priorities!
RedwoodRubi is offline
modifications , tj
Bayou
