What did you do to your TJ today? - Page 494 - JeepForum.com
 1225Likes
post #7396 of 114040 Old 08-22-2007, 12:01 AM
NEVERSWEAT
Northman
NEVERSWEAT's Avatar
Well, I thought I was going to add HID lights. Last night that was the plan. The delta H-4 glass was going to house the bulbs. Not! The ones I almost bought had only 1 setting.. no high beam.. worst yet.. after they are inside the delta housing you cannot seal out moisture. Rubber gasket seal isn't designed to do so in such a manner. So on comes the H-4 delta with it's original bulb back in pace. It will not create a tight fit with steel ring in place??? What?? There was some slop. I tried moving the rings from one side of the jeep to the other and then back to the other side.. no difference. So away both light set-ups go and after 2 hours of non productive time, I am back to the OEM sealed beam lights. Question, do they make an after market ring for holding the lights in place? Question, could the lights themselves be the wrong size even though the info which the parts company looked up stated they should have worked ? Just because they say that they will fit a wrangler.. could there be a possibility that some may be designed just for a Rubicon?? Hell ,I don't know. After fitting the ring on the light itself before I put it in the light socket area it was not as secure a fit as the OEM was.. I was hoping that when the ring was tightened down my luck might change.. No dice. I am trying to think outside the box here. I will order a few sets and then attempt to use whatever works. any brands with H-4 ability. Other than delta? Not that delta is bad but the more the merrier.
Thanks
Uncle Willy, The InnKeeper #3
06 Rubicon locked and loaded....
NEVERSWEAT is offline
post #7397 of 114040 Old 08-22-2007, 12:11 AM
Stang_guru
Originally Posted by Panici
BTW, does anyone know if i can wirebrush the surface rust off the driveshafts and paint them with rustoleam? Will this throw off the shaft balance or something?
wouldnt imagine it would make any difference really, or no worse than it is now. taking off a layer of rust, and replacing it with a layer of paint. even trade. ive done it for years and never noticed a bit of difference.
2005 TJ, Rockey Mountain Edition, 4.0, D44, 6-sp, Patriot Blue.
2002 Mustang GT 'Vert, 5-sp, not stock, Mineral Gray.
2001 Ranger XLT , 4.0, 5-sp, White.
Rocky Mountain Edition Club Member #5
Blue Jeep Club Member #242
Stang_guru is offline
post #7398 of 114040 Old 08-22-2007, 01:32 AM
omgsideburns
adjusted my toe in.. made my tires quieter.. reduced my steering wheel vibrations..
man it was way off.
omgsideburns is offline
post #7399 of 114040 Old 08-22-2007, 04:33 AM
claytonandson
claytonandson's Avatar
fabbed bumper
not too shabby,lighting overkill.
yellow jeep club #343
IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51
claytonandson is offline
post #7400 of 114040 Old 08-22-2007, 07:25 AM
SpoiledRotten
SpoiledRotten's Avatar
Got my new bumpers on...
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline
post #7401 of 114040 Old 08-22-2007, 07:30 AM
brianw13a
brianw13a's Avatar
Added a powered sub under rear seat - quite possibly the best upgrade ever.
brianw13a is offline
post #7402 of 114040 Old 08-22-2007, 08:26 AM
Zoom By You
Zoom By You's Avatar
Changed oil and power steering fluid....
2001 TJ Sport Amber Fire, Dual Tops/Dual Doors, 4.0, Banks Ram-Air, Banks S.S. Monster exhaust, five speed, NV3550, A.A. SYE/Tom Woods, 4:56 D30/D35, Detroit Truetrac at both ends, Solid diff covers, 4.5 R.E. Super Flex W/3.5 springs, adjustable upper and lower control arms, adjustable front and rear R.E. track bars, TeraFlex shock relocation brackets, R.E. Mono tube shocks, R.E. front stabilizer, R.E. 3/4" front spacer, 33 X 12.5 TrXus STS, M/T Classic-locks, ShrockWorks Rock Rails, Hanson 52" front bumper, EPi9.0 Superwinch with wireless control, Olympic rear bumper, Olympic Mountaineer rack, Bushwacker 6" Pocket Flares, Optima yellow top, IPF headlights W/ Fatboys, upgraded relay/wiring harness, KC Slims, Bosch rear lights, Garmin c550 GPS, Garmin 76S GPS, Cobra CB 148GTL W/Astatic Mic, Pioneer Sound, 3A Racing fire extinguishers. Manhattan Rated....
Zoom By You is offline
post #7403 of 114040 Old 08-22-2007, 09:07 AM
Okiiashi
Okiiashi's Avatar
I changed my oil and air filter. Then Cleaned it to Sparkle till the Weekend.
|¯¯l,[___],
l---L--OlllllllO¬
()_) ()_)---)_)RED JEEP #446
“Even if you’re on the right track, you’ll get run over if you just sit there” - Will Rogers
Okiiashi is offline
post #7404 of 114040 Old 08-22-2007, 09:19 AM
shadowrider1946
Installed round eyes, what a difference it makes.
shadowrider1946 is offline
post #7405 of 114040 Old 08-22-2007, 07:06 PM
bblhead
Re-installed my Soft-top. It's getting a wee bit nipplely in the morning.
Ben
HIS: 97 Sport, 4" Rough Country X-Series, 33" Super Swamper LTB, Airaid Cold Air Intake, Banks Power Exhaust, Looking to "Fix" the axles soon
HERS: 09 Unlimited Rubicon Stock.... For now!!!!
bblhead is offline
post #7406 of 114040 Old 08-22-2007, 07:22 PM
PBR
PBR's Avatar
packed it up cuz im leaving for school tomorrow
PBR is offline
post #7407 of 114040 Old 08-22-2007, 09:07 PM
MtnHighTJ
MtnHighTJ's Avatar
Changed all fluids, bought a new Dana 30 w/ 456's and ARB locker, bought a new D35 w/ 4.56's, and installed new 7" fender flares. O.K. it might of been the last couple of days but it;s been a good week
5spd Banks Monster exhaust
Dana30 ARB Locker Dana 44 LSD 4.88's
4" Explorer Pro Comp lift
1 1/4 JKS BL Brown Dog 1" MML
RE monos Nasty's Disco's
15"x 8" soft 8's w/ 35"x12.5'' MT Baja MTZ
A to Z sliders. Nth degree oil pan skid
Rokmen gas skid steering skid Warn dif plate
Superwinch EPi 9000
Currie HD Tie rod
BESRK rear bumper w/swing out
Colorado Jeep Club Member #85
MtnHighTJ is offline
post #7408 of 114040 Old 08-22-2007, 09:41 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
ordered some 4.5" Nth Lift springs. Replacing my 4" skyjackers.
buy my 4" springs
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #7409 of 114040 Old 08-22-2007, 10:18 PM
XDS22
Gave her a wash...
2006 Sport Wrangler
XDS22 is offline
post #7410 of 114040 Old 08-23-2007, 02:20 AM
snellav
snellav's Avatar
Installed Old Man Emu 2.5 inch lift, OME Steering Stabilizer, JKS Quick Disconnects, and Fabtech Rocker Guards
Pics:
http://www.jeepforum.com/forum/f9/finally-got-lift-453274/
98 2 Door Cherokee SE 4x4 - Stock
00 TJ w/ D60s and lotsa other stuff - Gone but not forgotten
snellav is offline
modifications , tj
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
