What did you do to your TJ today? - Page 4647 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 06-24-2012, 05:10 PM   #69691
FernBchJeep
The punk made my day.
FernBchJeep's Avatar
Bad day in the shop today. Was gonna do the Transgo shift kit, but the stoopid solenoid connector on the pass side of the trans conspired against that. Chrysler couldn't have made it any harder to get to. :
Wound up abandoning that plan and just did fluid and filter.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 1924
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
FernBchJeep is offline   Reply With Quote
Unread 06-24-2012, 05:22 PM   #69692
janesy86
Gotta be Fresh
janesy86's Avatar
Replaced both inner axle seals today, because I noticed some oil dripping out the end of the axle tube since a U-joint decided to lose one of it's bearing caps and let the shaft chew it up a little... Not too bad of a job for being the first time I really got into the diff. Ended up just pulling the inner shaft for now and stuffing a rag in there, till my RCV's show up early this week. Then its on!
Also did the ZJ tie rod upgrade while I was at it, since I tweaked the stock tie rod last time out.
03' Rubi: 2" BDS, 1.25" BL/MML, Hylined rollin' on 35" MTR's
Hylined '03 Rubi Build
Western MA 4x4
janesy86 is offline   Reply With Quote
Unread 06-24-2012, 05:46 PM   #69693
alex211
Originally Posted by BioTex View Post
Good day in the shop today! Installed the new Savvy rear adjustable tracbar & bracket, so now I was finally able to move my rear axle 1/2" farther to the rear, and 1/2" over to the driver side. It is finally centered!
Then I adjusted my pinion angle a little more up, and went for a test drive.
OMG! No vibrations, no uneasy feel to the wheel, she drives like brand new, really. Brand new 35s, and brand new bilsteins were installed last weekend, so a lot of it is due to that I'm sure.
I have the same track bar, with all johnny joints in my suspension now it drives better than new. One hand on the wheel doing 75 down the interstate.
03 TJ
Build thread - http://www.jeepforum.com/forum/f9/my-rubicon-build-thread-slow-1255392/
alex211 is offline   Reply With Quote
Unread 06-24-2012, 05:46 PM   #69694
LJMJ
Originally Posted by gnaber9
Here is a a more detailed picture lol.
I would prefer to have a the same exact rivet that is on the passanger side, I cant seem to find somewhere that sells it. If I cant find the same one I would prefer to replace both ..but where can I get some quick disconnects or rivet s that will work. I would leave the nut and bolt as a last resort.
PS. Thanks for the help its greatly appreciated.
JKS makes pins like that. They came with my Discos. They may sell them separately.
OT: washed the trail dirt off it, discovered how close to carnage I came when I high centered it on a ledge drop off. Trans skid plate pushed right up to ~1/16" of the pan, whew.
Also picked up a 3"x30' recovery strap to replace the 2" one that broke trying to pull a Raptor out of the mud (had to let a Rubi with a winch get him out - still cool though)
LJMJ is offline   Reply With Quote
Unread 06-24-2012, 06:11 PM   #69695
ArmyFireFighter
Ripped out every component of the dash, center console and door trim, PAINTED IT BLACK! (and re-assembled). Overall turned out better than I thought it would. I just couldn't take the "khaki" interior any more, it was not quite Gray, not quite Tan... hated it. Still need to figue out what to do with the passanger side grab handle, for some reason the material didn't take to the paint as well as the rest of the interior parts.
ArmyFireFighter is offline   Reply With Quote
Unread 06-24-2012, 06:22 PM   #69696
Jason65
My wife made me three tool pouches that has 10 slots each and rolls up then ties off. Filled them up with tools and stuck them in the rear Tuffy box.
Jason65 is offline   Reply With Quote
Unread 06-24-2012, 06:29 PM   #69697
Rubikahn
Rubikahn's Avatar
Originally Posted by threeb
Maybe they have been reported and will get deleted.
Edit:
I wheeled with a small group.
Love that Manik grille. Too bad you can't get a winch on there. I had a line on one about two months ago on the Western Ma. Craigslist. I was ready to drive two plus hours to pick it up.
OME ZJ/LJ lift, 33" MT MTZ on AR-23 wheels, front and rear JKS trackbars, 1" seat risers, MORE 1" BL and MML, factory Ipod adapter. Light khaki jeep club #72
Rubikahn is offline   Reply With Quote
Unread 06-24-2012, 07:00 PM   #69698
pmcjeep
Installed swaybar discos!
01 tj 4.0,custom suspension,ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,Highlined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline   Reply With Quote
Unread 06-24-2012, 07:10 PM   #69699
XxJeepOrDiexX
Not sure where you can replacements, although the nut and bolt would most likely be fine because that is similar to what came with mine...see:
XxJeepOrDiexX is offline   Reply With Quote
Unread 06-24-2012, 07:16 PM   #69700
XxJeepOrDiexX
Actually, come to think of it, I believe these are quick discos ( from prev owner) bc I have pins on top and bottom of shaft as in pic, but I get a "clanking" noise while driving and when I push up and down on front bumper I can tell noise is coming from the lower attachment on that rod on the passenger side, bottom attachment. I have tightened it as much as possible, but I can't get the noise to go away completely...guess its something that's inevitable...any ideas?
Unread 06-24-2012, 07:21 PM   #69701
bloodwar
Changed the Water Pump and while I had the shroud off degreased and cleaned up the front of the engine.
bloodwar is offline   Reply With Quote
Unread 06-24-2012, 07:50 PM   #69702
alex211
Sandblasted my axles and loaded them in the truck to take to the gear shop tomorrow.
The front axle u-joints were a ***** to change. I usually cut the cross out with the torch and then the caps drive right out of the axle shafts, but on the one stub shaft it didn't want to budge. Got it out but ended up bending the ear, so it took about 4 tries of installing the u-joint and gradually straightening the ear until the c-clips would go in. Living in the rust belt sucks.
03 TJ
Unread 06-24-2012, 07:51 PM   #69703
taztj
Installed Currie adjustable track bar.
taztj is offline   Reply With Quote
Unread 06-24-2012, 09:24 PM   #69704
1990JPYJ
Swapped out my leaky Gear box and installed the JKS BL/MML. Good day- Only 1 broken bolt.
2001 TJ 4.0 NV3550 D30/44 3.73's, 33" BFG KM2's on Soft 8's, 2" RE BB, 1.25 JKS BL, 1" JKS MML, RC Quick Disco, XRC8, K&N FIPK.
1990JPYJ is offline   Reply With Quote
Unread 06-24-2012, 09:28 PM   #69705
Hendrix
TJ Truck?
Hendrix's Avatar
Finished up the trans crossmember for my flat skid.
Can not get much flatter than this.
Hendrix is offline   Reply With Quote
modifications , tj
