What did you do to your TJ today? - Page 4491 - JeepForum.com
 1018Likes
post #67351 of 113780 Old 05-07-2012, 08:37 PM
bclark11
Ordered a new tailgate lock mechanism cover after I broke off the top plastic tab while adjusting my lock actuators. Only $20 from the local dealership so it wasn't too expensive of a mistake.
Who Dat?
bclark11 is offline
post #67352 of 113780 Old 05-07-2012, 08:44 PM
Co0kieMoBster
I haven't had an issue with my front one like this... However it helps being a PoPo and having coworkers across the country... 😃
Co0kieMoBster is offline
post #67353 of 113780 Old 05-07-2012, 11:09 PM
maddox2338
changed diff lube to 85w-140, front and rear. after the re-gear and about 500 miles, started hearing a grinding, popping noise from rear axle but only after it heated up from driving. checked oil in diff and it looked to be really thin. changed to thicker oil.....no more noise!
maddox2338 is offline
post #67354 of 113780 Old 05-07-2012, 11:26 PM
2006_Sport
hooked up my IPF 968csg lights. Hybrid driving/spot beam with 100 watt bulbs. Paired with my trucklite LED headlights, i have more light than I need.
All light kind of washed out the camera on my phone. 100 times better in person. This is the LED highbeams with the IPFs on.
2006_Sport is offline
post #67355 of 113780 Old 05-08-2012, 05:50 AM
f18wrangler
Originally Posted by piglife68TJ99 View Post
What is the law on having your license plate bent like that in N.C.? I wanna do the same thing and haven't seen anyone around here with their plate like that, you are the first one. Any trouble with the law/vehicle inspection in N.C. (I see that you are now I Virginia beach). Thanks in advance.
I have had it that way for almost a year now and havent had any problems with it. And yes, i passed my last inspection with it like that
f18wrangler is offline
post #67356 of 113780 Old 05-08-2012, 06:53 AM
MCDavis
Over the weekend I:
1. Switched from the hard top to the Rampage bowless top for the spring/summer/fall.
2. Replaced the broken console tray in my console.
3. Replaced the blown sub in my console.
4. Reinstalled the console and sub.
MCDavis is offline
post #67357 of 113780 Old 05-08-2012, 07:08 AM
JBTJ
Thicker than 140w
JBTJ is offline
post #67358 of 113780 Old 05-08-2012, 07:24 AM
MKfarm
2011 JK Wrangler
Everyone talks about what they have done and I have done a lot over the past two months on my 98 TJ.
1.) new brake lines
2.) new calipers
3.) new gas line vent
4.) repaint frame
5.) replace floor pans
6.) repair body mount channel
7.) Repair/repaint bottom of tub.
8.) repaint the suspension including gas skid plate
9.) replace stock radio
10.) replace soft top and door skins
11.) new wipers
12.) repainted front brush guard
13.) started body work on both front fenders
14.) started body work on passenger door
Things to do.
1.) fix heater control that is stuck in defrost
2.) replace all speakers
3.) repair small surface rust, just a few easy spots to do
4.) replace current 33 tires with 31 tires
5.) replace shocks
6.) maybe update /replace some suspension parts they are getting long in the tooth
Total cost of updates is around $2,000 so far. Not bad since this is what I had estimated when I bought the TJ back in March. So far I am under budget with the purchase and repairs of this old girl. The last three on the list will be the high ticket items.
Here is what it looks like today.
MKfarm is offline
post #67359 of 113780 Old 05-08-2012, 07:26 AM
chux72vette
Originally Posted by MCDavis View Post
Over the weekend I:
I was wondering about the tray as haven't seen one and might be a cool addition. Is it OEM or homemade?? Any pics?? Thanx
1998 Jeep TJ and in the building process..Hope the Wife doesn't read this !
RED JEEP CLUB #640
Zombie Outbreak Response Unit #300
chux72vette is offline
post #67360 of 113780 Old 05-08-2012, 07:33 AM
MCDavis
It's the OEM tray that comes with the subwoofer option in the console. Not a lot of storage, but mine was broken when I bought the jeep and I wanted it usable again. Once the sub blew, I decided it was time to replace both.
I don't have any pictures, sorry.
MCDavis is offline
post #67361 of 113780 Old 05-08-2012, 08:19 AM
xndrxw
Installed a new head unit, speakers and an amp in the glove box. Had to go test it out.
Found a few of these.
xndrxw is offline
post #67362 of 113780 Old 05-08-2012, 08:30 AM
piglife68TJ99
Thanks!!
"The cure to the insurgency is the massacre" ~Alexander the Great~
Born in Detroit, Baptised on the beaches of Normandy.....Jeep!! Legends belong with legends.
piglife68TJ99 is offline
post #67363 of 113780 Old 05-08-2012, 08:38 AM
hallsofstone
Made some calls last night and located a Durango box for my swap. Out of a 99 4x4 (non-plow) with 95k miles at $75, tested and no leaks. Refurbished Durango units are double that and then some. Used TJ Wrangler boxes are double that and leak same as mine. Refurbished Wrangler boxes are 4x that. Kind of a no-brainer here for my budget. Headed to pick that up at lunch and maybe installing tonight. If all else fails and I can't leave work, they can deliver it Wednesday morning with their normal parts run to my home town or I can have my scrap hauler pick it up this afternoon should we send a load that way.
The adjustable track bar I had them install makes contact with my differential cover on the D30 with uptravel. It seems the bend was for a taller lift, so this will work well when I stuff my taller lift kit under my heep. For now, it seems to have cured my death wobble, but I still get some tire vibes at about 58 or 60 mph. Will have to have these new tires mounted and balanced to see if that cures it.
Cashflow is running super low though. With any luck, I'll see that commission pay I've been expecting to "bridge the gap" between checks. Nothing like living with no contingency, aye?
Jeeping Ohio Every Day
00 TJ Sport - Ever evolving DD/Rig
85 Suzuki GS700 - ugly
K.C.C.O.
hallsofstone is offline
post #67364 of 113780 Old 05-08-2012, 08:46 AM
Mboelts
WTF? Seriously that would be awesome...and maybe the next mod on the Jeep if I found one of those!
-"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." - Frank Sinatra
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
KCCO!
Mboelts is offline
post #67365 of 113780 Old 05-08-2012, 09:01 AM
xndrxw
There is supposed to be 24 or so of these cannons. I saw 3 of them. Couldnt float them back on the kayaks. I think we are going to need a bigger boat.
http://www.expeditionnola.com/
xndrxw is offline
modifications , tj
