What did you do to your TJ today? - Page 4360 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
Amsteel Blue Synthetic Winch line Free ShippingTravelling with Pets?Steering and more from Ruffstuff!
Unread 03-30-2012, 07:43 AM   #65386
2003X
Originally Posted by JeepScrap
Did the same. Great price but still waiting for them almost two weeks later.
Oh man, I dont want to hear that. Have you contacted him?
2003X is offline   Reply With Quote
Unread 03-30-2012, 07:46 AM   #65387
geiman
A local dealer is waiting on a set of Bilsteins he ordered a while back as well. He was told Bilstein themselves are on backorder, so I'm not sure what's up. We thought it was just BS, but since now others seem to be having the same problem I guess not.
geiman is online now   Reply With Quote
Unread 03-30-2012, 07:49 AM   #65388
JeepScrap
JeepScrap's Avatar
Yup...he said they ship directly from bilstein and it takes about 5 business days just to submit and ship them. Guess thats the price we pay for a good price.
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline   Reply With Quote
Unread 03-30-2012, 07:59 AM   #65389
SlackJaw
SlackJaw's Avatar
Installed disconnect sway bar links. Well sort of, haven't drilled and tapped for the disconnected holders yet. That will come when I have the wheels off for front axle u-joints, which is next.
SlackJaw is offline   Reply With Quote
Unread 03-30-2012, 08:13 AM   #65390
2003X
Ok, in his email he said he will ship them asap. The communication so far has been great.
Unread 03-30-2012, 08:54 AM   #65391
Scramblerguy
Originally Posted by little_Jeep
I'm not sure at this point that the alternator needs to be tested, but it won't hurt anything to test it. The high idle issue is probably a separate issue. This problem came out of the blue, not a problem that has been going on for a while. Correct? I noticed that you seem to have replaced a lot of parts in the recent months, are you in the process of a build? What have you done real recently to your Jeep and is it possible that during a repair and/or modification, there was collateral damage?
In january I replaced the top half of the motor, all the seals/gaskets, sensors, exhuast, and tuned it up. After a cylinder misfire and and some
sensors going out
Scramblerguy is offline   Reply With Quote
Unread 03-30-2012, 09:08 AM   #65392
JeepScrap
JeepScrap's Avatar
Yes he is good with communication. I just wish he had the parts in stock. I have read nothing but good things about kolak so we'll see. I was a little hesitant to order from him being he doesn't even have a website up and running.
Unread 03-30-2012, 09:35 AM   #65393
XJpax
Got the Congo Cage on today - boy that is a visual improvement over a bone-stock TJ.
Got some YJ soft doors to begin modifying.
Anyone have an opinion on removing the stock sidesteps? I know it won't do much, but i don't know if i ever will use them
XJpax is offline   Reply With Quote
Unread 03-30-2012, 09:50 AM   #65394
smotrs
Originally Posted by KevKaos View Post
Funny.
haha, hope you know I was just messing.
Shaun
smotrs is offline   Reply With Quote
Unread 03-30-2012, 09:56 AM   #65395
2003X
I was thinking the same thing, but saw others ordered so I felt ok.
Unread 03-30-2012, 10:10 AM   #65396
Deacon
Deacon's Avatar
What "stock side steps" are you referring to? Post a pic.
Anything that bolts to the frame will get torn up if you wheel it, and even aftermarket stuff tends to have problems due to the basic physics involved of dropping weight on the end of a lever...
Deacon is offline   Reply With Quote
Unread 03-30-2012, 10:29 AM   #65397
SideshowBob024
Yep, huge waste of $$
SideshowBob024 is offline   Reply With Quote
Unread 03-30-2012, 11:01 AM   #65398
mbybee
I think you mean bolts to the body. Nearly everything I've seen that bolts/welds to the frame has been really solid.
Not sure where the stock ones bolt, but I've seen those plasticy POS factory ones bend pretty dramatically without breaking.
I'd remove them just to be sure
mbybee is offline   Reply With Quote
Unread 03-30-2012, 11:13 AM   #65399
SlackJaw
SlackJaw's Avatar
what happen there, panda bear?
Unread 03-30-2012, 11:16 AM   #65400
Deacon
Deacon's Avatar
No, I didn't, and you need to get out more apparently...
modifications , tj
