03-27-2012, 08:14 PM
#65221
We all do stupid things some times. I remember I had a Yukon with 12” of lift. I noticed there was a rattle and after investigating, I realized the center caps were loose so I got the bright of taking some door edge moulding and placing on the edge of the center cap before sliding through the hole in the wheel.
I put them in, used an impact gun and parked the Yukon.
The next day I got to work (I kept it at my shop) and backed it out of the shop. I could feel something loose on the wheels but I was busy and figured I’d check it out later.
Well, later never came and that afternoon one of my employees took my Yukon down to a store to pick up some argon in a bottle. On the way back, he said the rear end dropped and he saw a 36” tire bouncing past him going down the highway.
Apparently overnight, the door edge moulding compressed and made the wheel loose.
Stupid things we do....
Mark
03-27-2012, 08:18 PM
#65222
Bought the safari straps window net set so the pack can ride in the back with the top down. They look high quality. Also wired the switch for some LED cargo area lights. Hopefully install the lights by the weekend. Love owning a TJ
03-27-2012, 08:40 PM
#65223
Low Output 2.5L
Originally Posted by SlackJaw
changed plugs, cleaned airfilter...
Put some red gel inside the interior lights to make it look cool and be less annoying driving with the doors off.
You could take the fuse out and the lights wouldn't come on
03-27-2012, 08:53 PM
#65224
yeh someone just pm'd me the same - I had thought about pulling the bulbs, but it never occurred to pull the fuse
I'm try the red for a bit though, you know, since I put all that ******* effort into it, and then probably just pull the fuse
03-27-2012, 08:58 PM
#65225
You could even put a switch on it. Its really easy.
http://stu-offroad.com/electrical/elec11/domelight.htm
03-27-2012, 08:59 PM
#65226
Why not just buy a set of those little coil springs that go over the button? That way you can still use the interior lights when you need them.
No?
Makes it so simple.
Mark
03-27-2012, 09:13 PM
#65227
I need a good rear bumper with a trailer hitch..... I am gunna be pulling some heavy stuff sometimes, any good ones out there?
03-27-2012, 09:28 PM
#65228
all good tips for sure, I'm a jeep newb, this is why I come here.
I like that little wiring/switch install and may just do that....first time I lose the fuse
03-27-2012, 09:33 PM
#65229
Originally Posted by Slithering_Joe
Installed waterproof USB charger/jack and a 3.5mm audio waterproof jack.
(USB splash cover not shown)
Click here to purchase the 3.5mm jack http://www.amazon.com/Poly-Planar-iPod-Satellite-Radio-Adapter/dp/B001TXS7MU/ref=cm_cmu_pg_t
03-27-2012, 09:56 PM
#65230
I did my own switch  ...disregard the wires, I haven't tucked them yet
03-27-2012, 10:14 PM
#65231
Yes fuse 4 behind teh glove box
[B]TJ 2003 Wrangler Sport[/B]
33" BFGodrich KM2's | Ion Alloy 174 Rims | 4.5 Rubicon Express Lift | Currie adjustable control Arms | Advanced Adaptors SYE | Tom woods rear CV diveshaft | 4.0L I-6 Engine | NV231 Command-Trac Transfer case | Dana 30 w/ Aussie Locker | Dana 35c Rear w/ Trac-Lok Limited slip | 3.73 | ORO LED Tail lights | JKS Adjustable Trackbars and Quicker Disconnects | Black Magic Brakes | ZJ V8 Tie rod Upgrade | Uniden 520XL CB/PA system
[B]My Build Thread:[/B]
[URL="http://www.jeepforum.com/forum/f22/2003-wrangler-sport-4-5-re-lift-33-bfg-km2s-never-ending-wish-list-1312377/"]Click Here[/URL]
[B]Some of my Favorite Sites:[/B]
[URL="http://www.4x4xplor.com/mods-TJ.html/"]4x4xplor.com[/URL]
[URL="]http://www.stu-offroad.com/siteindex.asp/"]stu-offroad.com[/URL]
[URL="http://www.quadratec.com/jeep_knowledgebase/"]Quadratec Knowledge Base[/URL]
[URL="http://www.jeepforum.com/forum/f9/tj-tech-boot-camp-must-read-new-tj-owners-forum-members-722109/"]TJ tech bootcamp[/URL]
[B]Ask about my Custom Vinyl Decals![/B]
[URL="http://www.jeepforum.com/forum/f43/new-vendor-custom-vinyl-decals-1385910//"]Click Here[/URL]
03-27-2012, 10:16 PM
#65232
Originally Posted by robert_hollis
Had to call AAA to jump me when my Jeep decided to not start as I was trying to leave dinner. AAA guy ran a test, and said my 1.5yr old battery's gone bad...
I could not call AAA because I was on Company property. luckily a co-worker gave me a jump.
Now I have no turn signals at all...WTF?
Where is that dang flasher unit located?
03-27-2012, 10:29 PM
#65233
Wimpifed my TJ today. Went from 31x11.50x15 Trxus STS on 15x10 Eagle Alloy 118s to the 235/75r15 on stock 15x8 Canyon's.
Before:
After:
I plan on putting the Trxus STSs on the stock Canyons.
Also ordered some Moog cc874 springs for the front of my TJ. Should give me about 2.5"-3.0" of lift in the front all for only $73 including shipping off ebay.
97 TJ Sport, 2.5" front 1.5" rear lift, 31x11.5 15 Trxus STS on 15x10 Eagle Alloy 118s
03-27-2012, 10:47 PM
#65234
If I remember correctly, the flasher unit is under the steering column. I don't think it cost much more than $10. Just pull off the upper and lower dash panel, and then it shouldn't be too hard to get to and replace. (like i said, IIRC)
Good luck!
03-27-2012, 11:02 PM
#65235
Oil Change.
I know I'm supposed to love working on my baby. Normally, I do. This is just one thing that I haaaaaaaaaattteeeee doing. By the time I buy the supplies, drive home, do the change, clean up the mess, then drive the oil back to the shop for recycling, ugh. I know it's a cardinal sin to take it to a garage for just an oil change, but sometimes I almost wonder...
Next: plugs, wires, cap and rotor.
Ike
Her Highness High Maintenance, the Pinstripe Princess
I will NOT calm down! Machine guns affect my ability to perform and I do NOT like that! -- Ricardo Tubbs
The world is a mess... and I just need to RULE it. -- Dr. Horrible
Machete don't txt. -- Machete
