What did you do to your TJ today? - Page 391 - JeepForum.com
 1384Likes
post #5851 of 114282 Old 05-26-2007, 10:58 PM
highrisetj39.5
well today im getting pissed at my arb locker system because the rear locker wont work and all it does when i hit the rear locker switch is blow a fuse to where ever i have the red and yellow wire hooked up!!!
2000 Tj 4.7L supercharged, with a nv3500 and SYE np231. Currie Hp 9"s w/ 4.56 and arbs, rubicon express 4.5" SF, 1" BL, 35" BFG M/T, warn m8000, all custom armor, cage and bumpers front and rear with tire swing away, CB, Currie HD steering, and some other things
highrisetj39.5 is offline
post #5852 of 114282 Old 05-27-2007, 12:05 AM
BaddAndy
Somethings shorting to ground highrisetj39.5.
Tried to find annoying squeek under dash to no avail. Put in rubber floor mats
BaddAndy is offline
post #5853 of 114282 Old 05-27-2007, 12:14 AM
FL 4.0L
Water pump, t-stat, gaskets, and coolant. Worst gasket removal experience ever from around the pump opening on the block. I had just finished the water pump on my Jetta and saw the coolant accident my Jeep had on the garage floor. I had a lot more energy then, when I decided to jump right into it, than I do now.
'97 TJ Sport, 4.0L, AX-15, D30/35, BFG TA KO 183K
'12 F30, '03 E46, '06 Rabbit, '13 Jetta
FL 4.0L is offline
post #5854 of 114282 Old 05-27-2007, 12:19 AM
blkhwk20k
blkhwk20k's Avatar
not potty trained yet?
-Mike
'96 XJ 2-Door
blkhwk20k is offline
post #5855 of 114282 Old 05-27-2007, 04:51 AM
JFrank1968
Let's see.......replaced both the front and rear brakes, installed the correct speedo gear and then noticed the steering box was leaking. Replaced that....what a PITA I love living in the rustbelt!!
2002 TJ Sahara, 4.0L, 5spd, Sienna Pearl, RE 3.5", 35x12.5 Maxxis Trepadors, LoD Extreme Bumper w/Carrier, LoD "Shorty" bumper with guard, JKS Quicker Disconnects, Skid Row Radiator Skid, Tera Oil Pan Skid, AEM Brute Force Intake, B&M oil cooler, PS cooler, RuffStuff diff covers, OR Fab cage, Mile Marker PE8000 winch, 1" BL, Currie 1" MML, Aluminum shroud & radiator w/electric fan. "Bling": Hurst shifter and heated seats. Sienna Pearl Club #32
JFrank1968 is offline
post #5856 of 114282 Old 05-27-2007, 08:20 AM
meha11
meha11's Avatar
I wired my lights.
meha11 is offline
post #5857 of 114282 Old 05-27-2007, 09:35 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
so far i drove it today. I'm going to kick the front axle out a little just for the heck of it.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #5858 of 114282 Old 05-27-2007, 10:17 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
added side marker lights to the back (was few days ago) to go along with my LEDs i added few years ago
RnEmOvr is offline
post #5859 of 114282 Old 05-27-2007, 10:27 AM
RnEmOvr
RnEmOvr's Avatar
forgot to mention i spidered my windshield removing my aftemarket shift light
RnEmOvr is offline
post #5860 of 114282 Old 05-27-2007, 11:09 AM
JeepRocks86
I kicked the front axle out about 1/2" from where it was. Seems to steer a little better now and it doesn't rub the TRE. Should be sitting at about 95" woo hoo a whole 1.5" of lengthening lol
For Sale:
post #5861 of 114282 Old 05-27-2007, 11:31 AM
PhulesAu
Tried to get rid of angry sparows, swapped out front DS u-joints and CV centering bearing..... And they are still there, Gotta be something wierd. Not any of the usual suspects.
PhulesAu is offline
post #5862 of 114282 Old 05-27-2007, 11:42 AM
hoorah
Washed it and took the doors off. Used the window roll by clover patch for the first time. A tiny bit of the unlimited side window (no plastic though) sticks out of the felt, but fit easily into the cover. I highly reccomend it for unlimiteds Cruiesed around town. go wheeling with my buddy tomorrow.
hoorah is offline
post #5863 of 114282 Old 05-27-2007, 01:10 PM
highrisetj39.5
got my arb lockers working again!!!
post #5864 of 114282 Old 05-27-2007, 06:08 PM
Indy TJ
went to the badlands,got her muddy and played on the rocks.
2002 wrangler x,fog lights,tow hooks,cb,daystar 3" rockcrusher spacerlift,pa.1"bl,33x12.50 dayton timberline mt,skyjacker disco's more to come.member JeepsGoneWild offroading club.
Indy TJ is offline
post #5865 of 114282 Old 05-27-2007, 06:20 PM
TJay
TJay's Avatar
Watched it sit in the driveway again. No driving till the SYE and CV go in and I find out what I knocked loose at SPG. The death wobble is pretty frequent and the drive line vibes are terrible after bashing in the trans case skid.
TJay is offline
modifications , tj
