10-18-2011, 10:37 AM
#57436
Originally Posted by little_Jeep
Bubbles in radiator typically not a good thing. Does it get hot real quick? Rent a "Coolant system pressure tester" (basically a radiator cap with little bicycle pump & guage attached) from Auto Zone..... this will allow you to pressurize the cooling system and possibly see where coolant is going. This past weekend I used this on a Jeep a buddy was looking at and coolant was squirting out of the head under the intake manifold. Wasn't a problem as we already figured the engine was toast as PO had been driving it while overheated.
Thxs for that advice I'll def check it out but it wasn't going CRAZY just a lil bubble here and there and I'm not really leaking coolant anywhere or overheating at all. Then again i only let it run for a little bit. But i did blow the waterpump five miles from home drove it home and it didnt overheat at all
98 TJ 33"s 4"rancho with a blown up carrier and broken front axles =/ its a Jeep
TauKappaEpsilon
#57437
Drove it to work and called Bilstein and demanded they make a 5100 series steering stabilizer for us TJ/LJ guys. There is already one for the JK's. They say it's in the works and due around January. This after seeing the $105 price tag on the BDS stabilizer that matches the Bilstein look. Rip off.
"Science will win in a battle with religion because it works." -Stephen Hawking
10-18-2011, 10:46 AM
#57438
Originally Posted by robert_hollis
Finally, as a last ditch effort, I pulled my fog light fuse, and put it in the clutch override location.
Jeep started right up.
Guess this means my clutch pedal sensor switch has gone out on my 06 with NO warning what so ever... Man, I thought those switches lasted longer.
And it's a $65 part from rockauto. Maybe I'll drive around without it for the next 10 years...
See, the difference between you and me is that you blow up lots of little stuff, I blow up a few big things.
There's a clutch override location?
Mine- 2k TJ, RC 2.5 lift, .75 spacers, Soft 8s, 33" KM2s, winch, lights, and so on
Hers- 06 WK, bone stock until she leaves it and the credit card with me for an unsupervised weekend
You're the retarded offspring of five monkeys having butt sex with a fish-squirrel.
10-18-2011, 11:06 AM
#57439
I was wondering the same thing.
OT: Haven't done anything to mine in a while other then drive it.
Shaun
10-18-2011, 11:08 AM
#57440
I helped a buddy install a new belt in his tj but when we started her up the belt was squealing and smoking. We turned her off and I noticed one of his idler pulleys was seized. I took it off we bought another and put it all back on fired her up and she runs great!
He then rewarded me with some homemade rum pot and beer!
I enjoy working on jeeps even when I put in 4 new pistons in mine due to skirt drop.
I don't have pics of me helping my buddy but that was minor. Here is one of my broke skirt:
10-18-2011, 11:29 AM
#57441
Are you having other issues? It is possible that you just have air bubbles..... leave cap off, turn heat on high hot, and let it run.... if it doesn't get hot, doesn't puke coolant all over, or have other issues like coolant in the oil, you may not have an issue with head gasket.... the pressure tester (and a compression test) will will tell the story as if you can't hold pressure, there is a leak somewhere.
10-18-2011, 11:31 AM
#57442
Thats EXACTLy what I did lol it didnt over heat but the pressure in the hose wouldn't calm down thats why I'm thinking it might be the head gasket
TauKappaEpsilon
10-18-2011, 11:37 AM
#57443
Rent the coolant system pressure tester and do a compression test on the cylinders..... you will have a better idea once you do. FYI, the #3 cylinder seems to have a better chance than the others to be the problem.... test all of them, but #3 seems to be the issues more times than not for some reason.
10-18-2011, 11:42 AM
#57444
Sweet thanks A LOT Lil_Jeep! I appreciate all the help I'll let you know what it is once I do that!!!
TauKappaEpsilon
10-18-2011, 11:59 AM
#57445
If you can't hold pressure in the coolant system, then you have a problem. Sometimes you can remove the valve cover with system under pressure and see a crack in the head. Other times, you will actually see coolant dripping on the ground... there are a lot of reasons including a blown head gasket, pin hole in a hose, leaky heater core, etc., that can cause a cooling system not to hold pressure. However, if you have a cooling system that won't hold pressure and a cylinder with a compression issue, you can feel safe your problem is head gasket and/or head related. Good luck and keep us posted on what you find.
10-18-2011, 12:17 PM
#57446
After working 10 days in a row, I finally have a day off, so I adjusted my RC stabilizers, and painted the frame, , gas take skid, skid plate, front axle and components.
10-18-2011, 01:52 PM
#57447
Originally Posted by MemorEsto
I've been running these for almost 7 years.... no problems. That cotter pin looks tiny. That is what I use to hold my soft top on.
i reused the factory washers plus two thinner washers as shims and there are zero lateral movement to wear them out. I shall see how they wear though.
10-18-2011, 02:24 PM
#57448
Ordered a JKS track bar.
10-18-2011, 03:27 PM
#57449
Originally Posted by sjones26573
If that falls thru i got 2 alpine 10" and memphis amp ill sell u for 225 +shipping.. Im in charlotte,nc
10-18-2011, 04:11 PM
#57450
Sir there's no "Wodewick"
What type are the subs and amp? Model #s?
My local dealer has me wanting 2 JLA 10W3V3-4's with a JLA XD600/1 amp. So much bass and performance but for $950?
and I picked up the box today
