What did you do to your TJ today? - Page 3822 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 10-15-2011, 03:25 PM   #57316
chux72vette
Changed out my muffler as I have to get my inspection this month and also tired of hearing it leaking. Got a Thrush Turbo for $30 bucks @ Advance. Did some other mock ups for my Rock Sliders and still not sure how I want them. Just know that I want to build them and then I know they're Made in the USA!!! Now me and the Better half are going to a club Meet & Greet at QS&Lube.
[B][I]1998 Jeep TJ and in the building process..Hope the Wife doesn't read this ![/I][/B]
[COLOR="DarkRed"][B][I]RED JEEP CLUB[/I][/B][/COLOR] [B][I]#640[/I][/B]
[B][I]Zombie Outbreak Response Unit #300[/I][/B]
chux72vette is offline   Reply With Quote
Unread 10-15-2011, 03:43 PM   #57317
greene69
Beach Bound
greene69's Avatar
Rotated the tires, last time i did that i drove a 1/2 and it wouldn't stay on the road, so i put them back. Since then i have replaced everything on the frontend and only got a little wobble around a few curves at about 50, but the Duratracs went from relatively quiet to sounding like super swampers. Guess the uneven wear going from the front to the back did it! They have 20k miles on them and the po never rotated them.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline   Reply With Quote
Unread 10-15-2011, 03:56 PM   #57318
BigYellow04
Originally Posted by austonreeves
Jeeps get you laid period
True true, I do get lots of stares from some hotties but I think the wife would chop me off below the waist if it turned into more than just stares hehe
BigYellow04 is offline   Reply With Quote
Unread 10-15-2011, 04:30 PM   #57319
RDHouston
Painted my front bumper sliver to match the back.
Before:
After:
Rear for reference:
" Insert really witty or insightful saying here. " - [COLOR="Red"][B]Red Jeep Club # 637[/B][/COLOR] - [B][COLOR="SeaGreen"]Colorado Jeep Club # 249[/COLOR][/B] - [URL="https://picasaweb.google.com/116230693616460044990/JeepAdventures?authuser=0&feat=directlink"][SIZE="4"]Lucy's Adventures[/SIZE][/URL]
RDHouston is offline   Reply With Quote
Unread 10-15-2011, 05:06 PM   #57320
77midget
Finally got the remaining parts from the dealer, so I was able to finish installing the new exhaust manifold, downpipe, cat, muffler and tailpipe. Also got the heater core finally installed, reinstalled the steering column and put the dash (mostly) back together. First time the jeep has run in a month! sounds nice and quiet. Missed the brake boost vac line and had an idle issue, but that was easily fixed with help from JF search. My airbag light is on, but I think that it is the clockspring switch, form what I have read. The switch assembly is a bit loose.
The rig is still a mess, but mechanically is much better. Still need to fix some messed up wiring, top off coolant, re-tighten the manifold bolts, and put all the trim etc back in.
77midget is offline   Reply With Quote
Unread 10-15-2011, 05:29 PM   #57321
JeepScrap
JeepScrap's Avatar
Installed a nice shiny new class III hitch. Just can't figure out what the deal is with those damn handle nuts. I just rolled them with pliers and tucked em up into the frame.
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline   Reply With Quote
Unread 10-15-2011, 05:50 PM   #57322
Kiwi Jeeper
Originally Posted by rikkards View Post
If gas was filled in the last little bit, most likely a loose gas cap
x2. I was worried when it happened first time. Undo and redo the cap and see if it goes away after a few start cycles.
'01 TJ Renegade I6 4.0L Auto D30/D44, BFG Muds, Currie springs, OME shocks, Brown Dog MML, ARB Front and Rear Bars, Rokmen Gas tank skid and LCAs, RE UCAs, JB Conversion Super Shorty with Truspeed and TW shaft, Warn 9.5xp
'03 WG Limited V8 4.7L stock standard
Kiwi Jeeper is offline   Reply With Quote
Unread 10-15-2011, 05:50 PM   #57323
rikkards
Today I went from this:
to this:
and ended up with this:
Tomorrow seal up the edges. I have the d-ring shackles coming in the mail and should have them hopefully by Tuesday or Wednesday. Tube for winch guard is also getting bent by a guy in my local club.
rikkards is offline   Reply With Quote
Unread 10-15-2011, 05:57 PM   #57324
wwch99tj
Low Output 2.5L
wwch99tj's Avatar
I got the codes checked its the downstream o2 sensor, I wish it was only the gas cap I couldn't be so lucky
Sent from my DROID 2 GLOBAL using Jeep Forum
wwch99tj is offline   Reply With Quote
Unread 10-15-2011, 08:32 PM   #57325
aw12345
Went wheelin at a local bunny trail, it was fun. Of course had to fix my buddy's heep first, it spit coolant at him and gave him a few somewhat
painfull burns. Once I got the fan working and some water poured in the radiator, we could air down and do some putting about.
His ole CJ did pretty darn good, the ole beast flexed pretty good for something on horse drawn wagon springs.
We met only a few other Jeepers and had a royal good time blowing through the trail. I got to to try out my grooved and trashed Krawlers that I bought for a song and am happy with those.
Here are a few pics of my buddy's CJ
Tinkertoy built thread
http://www.jeepforum.com/forum/f22/lil-bit-tinkering-aka-tinker-toc-1194198/
aw12345 is online now   Reply With Quote
Unread 10-15-2011, 08:35 PM   #57326
Hendrix
TJ Truck?
Hendrix's Avatar
Pulled the front axle out, cleaned all the brackets and old truss. Prepped for the new mid arm front.
Sent from planet X.
Hendrix is offline   Reply With Quote
Unread 10-15-2011, 08:44 PM   #57327
wytewolf00
Originally Posted by austonreeves View Post
Check your spark plugs and your TPS and your distributor cap, the rotory button inside your cap....all of those were a problem of my putterin problems
I checked the rotor and cap, as well as plugs 1 & 5 to see if there was anything wrong there...nothing seemed out of sorts, though.
Wouldn't TPS throw the CEL on if there was a problem? CEL isn't on, and didn't come on through the drive home. Though I found out that the front passenger U-joint is shot, too...
Zombie Outbreak Response Unit #295
wytewolf00 is offline   Reply With Quote
Unread 10-15-2011, 08:53 PM   #57328
herbiehind
replaced rear drivers side upper and lower ca brackets with piece from safety-cap . tomorrow is passenger side ; lucky me .
herbiehind is offline   Reply With Quote
Unread 10-15-2011, 09:45 PM   #57329
4x4Brit
Bought it and brought her home
2006 Rubicon Unlimited
It's pretty much stock right now. Looking forward to getting this built up the way I want it. I have been lurking here for a few months now and have done plenty of reading so have some ideas. In it's future are new rims or powder coat the stock rims, 33's, some kind of lift which I have yet to decide on, new bumpers and a winch.
I plan to do some smaller stuff first though, a cold air intake, new antenna and switching out the chrome headlight surrounds.
First up though is to get out on some trails and beat her up a little
4x4Brit is offline   Reply With Quote
Unread 10-15-2011, 09:54 PM   #57330
Jeremywrags
Installed my new rampage frameless soft top, love it and if you follow the directions and wait for a warm day it goes on no problem with just one person. It looks sweet to IMO
2000 Wrangler Sport 4.0L Auto, SYE, D44 3.73, 4.5" Lift, 15X10 MT Classic Lock, 35x12.50 Cooper Discoverer STT, Rampage Frame less top
Jeremywrags is offline   Reply With Quote
modifications , tj
