What did you do to your TJ today? - Page 3802 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
Why yes, we do still offer our Jeep Forum discount--code i2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit1997-1998 Jeep Grand Cherokee (6 Piece) Headlight, Corner
Unread 10-09-2011, 07:08 AM   #57016
BigYellow04
Yesterday I drove it til the gas light came on, filled it up and found out I was getting 16.6 mpg with stock gearing, 33s and a 5 spd. Not too shabby, still waiting for rokmen to ship my Novak kit.
BigYellow04 is offline   Reply With Quote
Unread 10-09-2011, 07:11 AM   #57017
little_Jeep
Your speedometer and odometer are not reading correctly due to the larger tires, did you adjust for this in your math?
little_Jeep is offline   Reply With Quote
Unread 10-09-2011, 07:34 AM   #57018
rikkards
Originally Posted by wytewolf00 View Post
I cut a driver side floor panel patch from 12g steel. Plan to weld it in tomorrow.
Wow since the floor is only 18G that is a thick patch. I did the same thing on both sides of my jeep this year. Next time I am just buying replacement floor pans.
rikkards is online now   Reply With Quote
Unread 10-09-2011, 07:48 AM   #57019
USMCTJ
http://www.prestigebillet.com/footme...op%20page.html
Small footman loop: They are like $7.00 a piece.
The come with attachment screws as well to attach the loop to in the inside of your door.
USMCTJ is offline   Reply With Quote
Unread 10-09-2011, 07:49 AM   #57020
dodgerex
I installed a 3 inch lift on my TJ Yesterday, then drove it home. Now looking at adjustable rear track bar or rear upper control arms
dodgerex is offline   Reply With Quote
Unread 10-09-2011, 08:55 AM   #57021
Rubes
Rubes's Avatar
Installed Autopal 7" H6024 6014 H4 Euro style headlights...got tired of not seeing in the dark. The difference was night and day. Also installed new Gabriel Ultra shocks in the rear. The Ranchos I bought 2 months ago were too long and not enough stroke.
Rubes is offline   Reply With Quote
Unread 10-09-2011, 11:41 AM   #57022
BigYellow04
How would I adjust this with my math? Odometer is spot on, 30 miles exactly to work. Say I'm at 66022 my odometer hits 66052 soon as I pull into the parking lot, take the same road to and from work every morning and night.(I used to drive my completely stock ranger back and forth to work and it was 30 miles exactly as well)
Unread 10-09-2011, 11:54 AM   #57023
little_Jeep
It's been a few years since I had this issue, but if I remember correctly, 33 inch tires, 3:07 gears, stock speedometer gear, my speedometer and odometer were 10% off approximately. When my speedometer read I was doing 50 mph, I was actually doing 55 mph... the odometer was off about the same. Use a GPS to get an accurate reading.
Unread 10-09-2011, 12:03 PM   #57024
skydiver30960
skydiver30960's Avatar
Renewed my JF Premium Membership for another year. So, more or less, this marks the one year anniversary of me really messing around with my TJ!
Ike
Her Highness High Maintenance, the Pinstripe Princess
I will NOT calm down! Machine guns affect my ability to perform and I do NOT like that! -- Ricardo Tubbs
The world is a mess... and I just need to RULE it. -- Dr. Horrible
Machete don't txt. -- Machete
skydiver30960 is offline   Reply With Quote
Unread 10-09-2011, 12:21 PM   #57025
jammasterjames3
Replaced clutch and slave cylinder, slave cylinder was a mother to get bled due to air in the system. Thanks mopar for for making my life difficult. But can't complain, it's better than walking
jammasterjames3 is offline   Reply With Quote
Unread 10-09-2011, 01:05 PM   #57026
04rockymnttj
3in lift rotated tires greased everything and did the alignment
04rockymnttj is offline   Reply With Quote
Unread 10-09-2011, 01:31 PM   #57027
03Jeeper
03Jeeper's Avatar
Im going to solder the pigtail for the 241 switch, also removing intake/exhaust manifolds to prep the block for painting.
Sienna Pearl Coat Club Member #24
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
My totaled TJ rebuild
03Jeeper is offline   Reply With Quote
Unread 10-09-2011, 02:08 PM   #57028
kyle_craig
Originally Posted by DaFuzz View Post
Not quite everyone's.
Alright alright....aside from Gribbles and Red_Smoke...it's different from almost everyone's.
Little TJ on leafs
kyle_craig is offline   Reply With Quote
Unread 10-09-2011, 02:09 PM   #57029
tinyjeep
tinyjeep's Avatar
i think flatlander has leafs too
Originally Posted by The_Blacksmith View Post
Remember, it was a shark attack when you dove into the ocean to save a trapped puppy, while you were doing charity work to help clean up a local beach.
tinyjeep is offline   Reply With Quote
Unread 10-09-2011, 02:14 PM   #57030
JohnW720
just got finished painting the frame, the jeep looks brand new now
JohnW720 is offline   Reply With Quote
modifications , tj
