What did you do to your TJ today? - Page 3566 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 07-24-2011, 03:23 PM   #53476
wwch99tj
Low Output 2.5L
wwch99tj's Avatar
Originally Posted by wwch99tj View Post
dropped the top and removed the doors for the third time since i owned her
the storm clouds moved in befofe i got home I got soaked but it felt so good after the 100+ heat we have been having The wife wasn't too happy
2011-07-24_16-38-21_599.jpg   2011-07-24_16-47-45_779.jpg   2011-07-24_17-03-52_961.jpg   2011-07-24_17-03-59_977.jpg
wwch99tj is offline   Reply With Quote
Unread 07-24-2011, 03:36 PM   #53477
rikkards
Cut out some of the front floor on the driver side by my left foot. Rotted through right where the round drain hole is for about 4" forward and about 6" back. Have to get that patched up.
rikkards is offline   Reply With Quote
Unread 07-24-2011, 03:48 PM   #53478
TheDirtyGeneral
Originally Posted by Skaboosh View Post
Should have spent the few extra bucks for a smittybilt. Still chineese but mine works every time I flip the switch.
I had a smittybilt, blew the solenoid. Warranty was up after 30 days, smittybilt wasn't willing to work with me. Now I have one from harbor freight with 2 year warranty.
Chris. I miss driving my Jeep. Can't wait to get into another one.
TheDirtyGeneral is offline   Reply With Quote
Unread 07-24-2011, 04:01 PM   #53479
DUBDUB468
Yup, and Harbor Freight will take it back and take it back and take it back, no questions ask!
DUBDUB
DUBDUB468 is offline   Reply With Quote
Unread 07-24-2011, 04:13 PM   #53480
Jeff88
Reminds me of how we used to "rent" things from Walmart while in college.
Jeff88 is offline   Reply With Quote
Unread 07-24-2011, 04:19 PM   #53481
Cesaros
Fixed the popping noise I had when braking...idk how, I inspected and cleaned my drums, re adjusted them properly (turn star wheel until you get resistance and then stop haha...rolling forward and back hitting the brakes hard doesn't do crap I found out)..and now it doesn't pop every wheel rotation while braking. Hope to get someone to help bleed brakes soon too...should be good to go after that.
Cesaros is offline   Reply With Quote
Unread 07-24-2011, 04:37 PM   #53482
slick2570
Which model smittybilt was it?
-Eric
2003 TJ Rubicon - stock for now
1999 WJ - Gone
slick2570 is offline   Reply With Quote
Unread 07-24-2011, 04:44 PM   #53483
TheDirtyGeneral
src 8, Id rather have the option of taking it back. Now instead of being stranded and screwed I'll just be stranded...
Unread 07-24-2011, 04:48 PM   #53484
311LJ
311Popo
311LJ's Avatar
went wheelin'... and broke a rear upper control arm bolt.
John
04 TJ Unlimited, GenRight Armor, 37's Unlimited Build Thread
07 WK Overland, Hemi, Chrome bug deflector
[SOLD] Jimmer 01 WJ *2009 GCOTY* WJ Build Thread
*UTAH JEEPCREW #01*
I ♡ John
311LJ is online now   Reply With Quote
Unread 07-24-2011, 05:24 PM   #53485
Maverickxeo
1) Washed it
2) Reconnected left rear tail light (came unplugged somehow.. thankfully the fuel filler is easy to remove!)
3) Took off the 'nerf' bars; Ill probably put them back on later though, since my mother cant get in or out without them.
4) Took off the plastic rugged ridge rocker covers; since they were falling off anyways (does anyone know of anything to put where the flare extensions went to cover the holes, btw?)
5) (Not yet) Installed these lights: http://www.princessauto.com/trailer/...ry-spot-lights
6) Took off the doors and windows, and just cruised for slushies
Maverickxeo is offline   Reply With Quote
Unread 07-24-2011, 05:42 PM   #53486
whitelightning
Quick swipe with black caulk for those holes.
whitelightning is offline   Reply With Quote
Unread 07-24-2011, 07:42 PM   #53487
shoopie
Got my rough country 4" x-series lift with performance 2.2 shocks installed last night. Total time was about 10 hours. We ran into a couple snags. Left front lower control arm bolt was seized to the stock control arm so We had to torch the CA off of the bolt to retrieve the bolt. Also broke a rear upper shock bolt and had to drill it out and tap it. Throw in some dull drill bits and multiple distractions, it was a long night. Started around 7:30pm and got out of there around 5:15am. Only things I need now are front and rear end alignment and a motormount lift due to some new driveline vibes. I also found that my drivers side ball joints are shot and I need a passenger side axle u-joint so that's another few hundred I need to spend.
2002 TJ Wrangler 4" Rough Country X-Series lift with 2.2 shocks, 33x12.5R15 Dick Cepek FC-II's, 15x10 Unique 252 steelies
East Hampton, NY
shoopie is offline   Reply With Quote
Unread 07-24-2011, 09:15 PM   #53488
Maverickxeo
Can you paint that stuff? My Jeep is blue; but aside from that Im planning on masking off the area where the rocker covers were, and rolling on bedliner.
Unread 07-24-2011, 09:27 PM   #53489
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
You can paint the Latex kind, but paint wont stick to the silicone kind.
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig: http://i9.photobucket.com/albums/a95...n/DSC06310.jpg
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline   Reply With Quote
Unread 07-24-2011, 09:41 PM   #53490
RimDJsTJ
The river by us is finally dry so we got to wheel it again. Yay!
Rimmert
RimDJsTJ is offline   Reply With Quote
modifications , tj
