What did you do to your TJ today? - Page 3101 - JeepForum.com
 394Likes
post #46501 of 111992 Old 03-20-2011, 10:48 PM
jhf56
Originally Posted by TJDaveX View Post
Yep, put it on jackstands and took of a tire.
Tore out a bunch of stuff to replace: SYE, control arms, D35 out, Rubi 44 going in, TW driveshaft, Poly outboarding kit going in, etc. etc.
sounds like fun
Rubicon, BDS, BFG, atoz, Rokmen, Riddler, Body Armor, UCF, etc
My Rubicon Build
http://www.jeepforum.com/forum/f9/2003-rubicon-build-1152937/
jhf56 is offline
post #46502 of 111992 Old 03-20-2011, 11:08 PM
north50
finished Zone 4" lift
Before
After
north50 is offline
post #46503 of 111992 Old 03-20-2011, 11:10 PM
jhf56
Before
After
looks great wat size tires
My Rubicon Build
jhf56 is offline
post #46504 of 111992 Old 03-20-2011, 11:11 PM
Wetnut21
Originally Posted by Jadetastic View Post
Sanded the surface rust off the hood, then spray painted to keep rust off till rhino-coat next month- then washed her & added wax for protection on soft top. she's so clean yay!
The hood looks much better now from your previous thread....
Wetnut21 is offline
post #46505 of 111992 Old 03-20-2011, 11:14 PM
Wetnut21
Put up some pictures when you get it Rhino coated on the outside. I was thinking about doing that to my jeep. How much is it supposed to cost you?
Wetnut21 is offline
post #46506 of 111992 Old 03-20-2011, 11:29 PM
north50
Thanks, I'm very happy with the lift quality for the price. For now I put some wore out 285/70R17 Firestone Destination M/T tires on while I try to decide on tires. leaning toward KM2's but just can't seem to pull the trigger.
north50 is offline
post #46507 of 111992 Old 03-20-2011, 11:48 PM
Rbloodhound
Drove it. Thinking about dropping the top tomorrow.
Rbloodhound is offline
post #46508 of 111992 Old 03-21-2011, 12:25 AM
DuckHunter
Just put on a new to me thrush welded muffler. Sounds pretty cool. Finally get to go to bed
DuckHunter is offline
post #46509 of 111992 Old 03-21-2011, 12:37 AM
Jadetastic
I'm getting the Solarmax done in fire- engine red. The difference besides thickness & softness in the material is that the top protective coat is mixed in with it. (if you think of Behr paint from Home Depot) similar method- the shine does not fade away. The difference in the rhinocoat is that Solarmax has more impact absorption and sometimes with rhinocoating it chips/peels off and Solarmax has a lifetime guarantee to the owner.
But the important part is getting someone to do it correctly and taking the time to do it. this is more of an investment for me bc I want give this jeep to my daughter when is old enough- then build a kit from the ground up.
The company quoted me $3500.00
For: Exterior, under-rail, frame & nerf bars
They will be using 2 different kinds Solarmax strength for the top & under.
Like I said "an investment" but whoever said quality paint jobs were cheap? Lol
I know there are different opinions from both sides of the fences- I think it just comes down to u & pocketbook.
-You wanna see how a "real" asian drives? let me show you
Jadetastic is offline
post #46510 of 111992 Old 03-21-2011, 04:54 AM
rikkards
rikkards's Avatar
Do NOT do that. Grind out the old nutserts and replace them. You will end up damaging the frame over time. You can find a couple of threads on here about the nutserts and what size you need. It's not hard nor expensive to do it right.
Also you don't need to drop the skid although it makes it easier. Either using a ratchet with an extension and angle thingie on it (for the life of me cannot remember the name right now) or a ratcheting wrench will work. Take the front end off and then put your head up against the rear tire and you can get at the rear end.
Originally Posted by flht_db View Post
Looking for a vibration that icreased with speed. Found a dent on the front Driveshaft. Figured I'd remove to se if that was it. Easy way would be to drop the TC Skid and pull the drive shaft. WRONG. stripped 3 of the 6 frame nuts. Cut the bolts out will pick up longer bolts to go all the way through the frame and drill. Then I will test drive to see if vibration is gone. Regardless will get driveshaft fixed or replace it.
rikkards is online now
post #46511 of 111992 Old 03-21-2011, 05:20 AM
verman
I installed hockey puck front bump stops and replaced a bunch of rusted bolts with Grade -8s.
verman is offline
post #46512 of 111992 Old 03-21-2011, 06:54 AM
Porgie
Just took my doors off for the first time ... Did it just to drive for a couple of hours cuz it's gonna rain hear but I was dying to take them off
Porgie is offline
post #46513 of 111992 Old 03-21-2011, 06:57 AM
little_Jeep
There is nothing better than driving a top less / door less Jeep.
little_Jeep is offline
post #46514 of 111992 Old 03-21-2011, 07:22 AM
Holm-z
Holm-z's Avatar
Ordered some KC Slimlights, tow hooks and a Quick release mirror for the days with the doors/top off!
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #46515 of 111992 Old 03-21-2011, 07:27 AM
Mainejeepin
Staring out the window waiting for UPS to deliver my 4 Goodyear MTR with kevlar. Finally getting my 35's
Mainejeepin is offline
modifications , tj
