What did you do to your TJ today? - Page 2997 - JeepForum.com
 395Likes
post #44941 of 112001 Old 02-18-2011, 08:40 AM
tchaap
a week ago, so it wasn't today...
Installed my Dirtworx bumper/tire carrier/jerry can carrier:
TC
tchaap is offline
post #44942 of 112001 Old 02-18-2011, 09:38 AM
Disconnect
Originally Posted by hustler905 View Post
I got mirror movers, and they sucked so much I took them right back off. The mirrors vibrated like crazy, and the passenger side was entirely useless.
Best bet is a set of Harley style mirrors stuck in the empty hinge pocket.
That leaves you in a bind if you want to run doors (the wif loves rock doors, and in questionable weather we carry soft doors stuffed behind the seat..)
I have tried just about every alternate mirror at quadratec, and at the end of the day they all sucked. "Quick release" (both versions) means "..at 45mph on a twisty road". The relocation bracket was decent (looked like hell, but it worked) until I took it off last fall and they were completely rusted all over (ate up the paint pretty good..)
Thinking of trying Rugged Ridge Dual Mirror Set. Gotta do something..
(BTW re mirror vibration, my driver's mirror was mostly useless the entire time I've had the jeep.....until I swapped the motor mounts. Suddenly it steadied right down. Dealer refused to even look at it, I was convinced it was a flawed mirror..)
Disconnect is offline
post #44943 of 112001 Old 02-18-2011, 09:40 AM
unlblkrubi
Originally Posted by tshuelsman View Post
Finally solved the rear main seal leak... Until next time
Just noticed mine is starting to.
Black 13 JKUR 10th Annivsary
White 13 JKUR
___________________________________________
unlblkrubi is offline
post #44944 of 112001 Old 02-18-2011, 09:43 AM
hustler905
I agree, you can't always control when they quick release.
Right now I am running Bestop new TJ style mirrors, and will likely find a way to mount the old OEM ones when I get another set of half doors, and leave the Bestop mirrors on the full steel doors.
... as if that made any sense at all.
hustler905 is offline
post #44945 of 112001 Old 02-18-2011, 09:46 AM
Finsup
drove it to work topless!
Oh No....a drug dealer is here!
Low Output 4 Cylinder Jeep Club #453
Finsup is offline
post #44946 of 112001 Old 02-18-2011, 09:54 AM
Scramblerguy
They are trash I had them went through 3 sets in one year 98 tj DD. If let you find something good please let me know
Scramblerguy is offline
post #44947 of 112001 Old 02-18-2011, 10:15 AM
Disconnect
Damn. Maybe this idea will work better.. think I'm gonna try it..
Oh, and what I did (will do..) today:
- after work, JKS BPE kit goes in (broke my 3rd bar pin in the passenger rear, gotta be something else wrong but for now this will beef it up)
- warranty-replacement myride adjuster goes in
- oil change (going over to turbodiesel)
- call the local bike shop about temp harley mirrors so i can doorless for a bit while figuring out a more permanent solution (maybe the above link..)
- film it spitting gas everywhere for a fox news story (interview is wed, gonna collect some video ahead of time)
- Hopefully order my new tires
post #44948 of 112001 Old 02-18-2011, 10:26 AM
Mud Machine
Jeep Addict
Mud Machine's Avatar
Replaced oil pan dented by rocks and fixed leak between transmission and transfer case.
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, Rock Hard Cage, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #44949 of 112001 Old 02-18-2011, 10:29 AM
Talton
waiting on the Big Brown Truck to Drop off my Metal Cloak complete package so I can start paint. The anticipation is killin me!
Talton is offline
post #44950 of 112001 Old 02-18-2011, 10:46 AM
Gina
oops..
"Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.."
2000 tj sport 5 speed 4.0+97 TJ 4 inch RC with 33x12.5 BFGS, SYE,+46 CJ2A..
Gina is offline
post #44951 of 112001 Old 02-18-2011, 11:00 AM
Javey
Uuuuhhh....Looked at it in the drive way as I backed out to go to work...
But I did finish my rear bumper and tire carrier install yesterday...!!
Javey is offline
post #44952 of 112001 Old 02-18-2011, 11:49 AM
rikkards
rikkards's Avatar
I have these:
http://www.quadratec.com/products/13125_00.htm
They aren't bad but I don't know if they will fit on 03+. If not, I am surprised they don't have the same for later models. I put them on in spring when I put the soft top on and take them off when the hard top goes on.
rikkards is offline
post #44953 of 112001 Old 02-18-2011, 11:52 AM
Disconnect
Originally Posted by rikkards View Post
I have these:
They kinda do and kinda don't have them - the problem is that the later model mirrors don't come apart, so you end up with the movers I posted earlier (the rusted ones) that take the entire mirror assembly, including the big plastic door piece. (If you can find earlier mirrors cheap, those movers should fit.)
post #44954 of 112001 Old 02-18-2011, 12:25 PM
rikkards
rikkards's Avatar
My original mirrors ended up having the threads rusting away. I picked up a new (to me) set from Davey's Jeeps for $35. I think that would work as well assuming the bolt pattern on the hinges are the same. At that point you then have to decide to try to get the torx bolts out which can be a hazardous undertaking.
rikkards is offline
post #44955 of 112001 Old 02-18-2011, 12:29 PM
chrisml
I learned how not to remove a d30 fill plug. Thanks to every person who's ever offered the advice to remove the fill plug before the drain plug.
On the other hand, I'm probably correct to think the axle fluid has never been changed in this prior to me owning it.
chrisml is offline
modifications , tj
