What did you do to your TJ today? - Page 251 - JeepForum.com
 563Likes
post #3751 of 112786 Old 12-23-2006, 08:57 PM
fire239
Finally got my REBB, JKS 1.25BL, and MML on with my 33" Maxxis Buckshots
http://i142.photobucket.com/albums/r...9/SUNP0010.jpg
http://i142.photobucket.com/albums/r...9/SUNP0011.jpg
http://i142.photobucket.com/albums/r...9/SUNP0012.jpg
fire239 is offline
post #3752 of 112786 Old 12-24-2006, 05:29 AM
davenjeip
davenjeip's Avatar
Installed a set of JKS adjustable rear uppers, and used them to rotate my pinion angle.
That made me able to remove my 1/2" of transfer case drop, which solved several little problems all by itself.
Repaired my spare tire carrier by welding in one of the loose wheel studs so it doesn't just spin free.
Also, put a couple spot welds on my exhaust to hold together an old repair. It seems that when I would hit the exhaust on a rock, instead of the whole system having some give to it, it would just pop loose at the clamps on the patch piece. Hopefully, my booger welds will hold things together until I have to replace the system when I do my belly up in the spring.
2003 TJ
www.davenjeip.com
davenjeip is offline
post #3753 of 112786 Old 12-24-2006, 08:49 AM
jeeptraxx
Finished drilling all the holes in my home-made bumper and primed and painted it.
http://i112.photobucket.com/albums/n...5/100_1330.jpg
jeeptraxx is offline
post #3754 of 112786 Old 12-24-2006, 09:06 AM
Dogman
Dogman's Avatar
Click Free...
John 3:17
Dogman is offline
post #3755 of 112786 Old 12-24-2006, 04:38 PM
bheiser
bheiser's Avatar
2006 KJ Liberty
last week I installed RoundEyes headlamp upgrades. They're great - they have a more modern look than the stock lamps (but not outlandish) with a very clear glass, and the light beam, while not equal to a BMW's lights, is very good. It's fairly "white" and bright, and so far I haven't had any troubles with people flashing their lights at me (I did do an aiming after installing them).
I also finished installing my PIAA 520 fogs. As some of you may have seen in the electrical/audio forum, I tried installing a headlamp harness from suvlights.com, but couldn't get it to work right (the high/low beam filaments came on together). I spoke with them, they had an idea to try (which I did, but with same result), so I guess they can't resolve it for me. I need to talk with them again. Meanwhile I just removed the new harness, and wired the fog harness directly into the low beam lead in the factory harness (so the fogs come on only when the low beams are on, and shut off when I turn on the high beams). I did it without cutting the lead, so if for any reason I want to go back to "stock", I can do it without any trouble.
Here's what the RoundEyes and new fogs look like (note I didn't want the flashy white PIAA logo, so I painted the rock shields with Krylon semi-flat black).
bheiser is offline
post #3756 of 112786 Old 12-24-2006, 07:26 PM
BaddAndy
Fixed my little trim issues and made some of those strap type flashlite and fire ext holders. Helped my bud remove his hardtop so he can install his NW rollbars
BaddAndy is offline
post #3757 of 112786 Old 12-26-2006, 06:33 PM
Dogman
Dogman's Avatar
Installed my Rockcrusher 30
John 3:17
Dogman is offline
post #3758 of 112786 Old 12-26-2006, 06:37 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
still waitin on my rock krushers, bought some fog lights to mount on front axle, and a hand held GPS unit
RnEmOvr is offline
post #3759 of 112786 Old 12-26-2006, 07:06 PM
mud n rox
mud n rox's Avatar
Installed my LoD front bumper. Next week I'll hopefully get my Co2 tank installed.
2001 TJ Sport - With a little lift, some armor, four mud tires, and a few decals.
Caution: Rock and a hard place just ahead.
mud n rox is offline
post #3760 of 112786 Old 12-26-2006, 07:23 PM
EOJRR1
I installed a Skyjacker steering stabilizer...
Would have been a snap but the OEM one had been on there since birth I guess and it took quite a bit of persuading to come unattached at the drag link.
PB blaster, Pittman arm puller, PB Blaster, Pittman arm puller, PB Blaster, hammer, PAP, and it finally released. Talk about frustrating...
EOJRR1 is offline
post #3761 of 112786 Old 12-26-2006, 07:55 PM
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
Trash removal
Cleaned out the floor board I use as a dumpster. Forgot there was carpet on that side. Neat.
1948 CJ2a
Airborne4X4 is offline
post #3762 of 112786 Old 12-26-2006, 08:57 PM
C2kraft
C2kraft's Avatar
Today I got my hardtop installed. Winter is slowly coming around here and it was time to get it on. My dealership installed/wired all the electronics.
On a side note, someone throw a chew wad at my window this evening. Not cool! And if I would of been around there would of been some hell to pay.
Krafty
C2kraft is offline
post #3763 of 112786 Old 12-26-2006, 11:07 PM
AlTheKillerr
AlTheKillerr's Avatar
took the little guy out for a drive since the 1:1 is back in Co.
Photographer
AlTheKillerr is offline
post #3764 of 112786 Old 12-27-2006, 07:30 AM
BillR
BillR's Avatar
I installed a PA 1" body lift. Making room for the Atlas and the 35s!!
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #3765 of 112786 Old 12-27-2006, 07:46 AM
nat441
Put in some speakers and floormats I got for Christmas.
I know, exciting!!
nat441 is offline
modifications , tj
jski701 , kadehamilton
