What did you do to your TJ today? - Page 211 - JeepForum.com
 395Likes
post #3151 of 112004 Old 11-03-2006, 12:58 PM
sethfosho
Originally Posted by Ryuu600
they are worthless for protection and are what "mall rated" jeeps run to try and look hardcore.
wow
what do you suggest?
sethfosho is offline
post #3152 of 112004 Old 11-03-2006, 01:34 PM
SomeGuysName
I finally moved my winch control box under the hood. It makes the front of the jeep look a lot cleaner. Next I plan to build an in-cab winch control if I can find the parts lying around the house (broke again, sigh)
SomeGuysName is offline
post #3153 of 112004 Old 11-04-2006, 03:49 PM
Vacant Stare
Installed a skyjacker transfer case shifter linkage bracket, a 1" body lift, and a 1" motor mount lift. The motor mount lift was 'challenging'.
Busy day for me...time for a beer.
Vacant Stare is offline
post #3154 of 112004 Old 11-04-2006, 03:59 PM
solbergg
Today I made my TJ, well.......mine!
solbergg is offline
post #3155 of 112004 Old 11-04-2006, 04:48 PM
bheiser
bheiser's Avatar
2006 KJ Liberty
I installed a locking gas cap which arrived yesterday from jeepworld.com. I'd considered one of those fancy aluminum locking doors, but couldn't justify spending $100 on it when the locking cap is only $15. I also considered the locking cap which can be keyed to use my ignition key, but even that would have been $50 or more by the time I got through. The $15 cap with an additional key will work just fine
bheiser is offline
post #3156 of 112004 Old 11-04-2006, 04:55 PM
RUNIT
I painted my headlight trim rings black. It was the only chrome on my rig, so it had to go.
RUNIT is offline
post #3157 of 112004 Old 11-04-2006, 04:56 PM
TexanTJ
2014 JK Wrangler
I put my bikini and duster back on. The weather is getting really pretty here.... mid 70's and sunny.
Last night I ordered some 3" black diamond springs to replace my 2.25" spacer in the front.
2014 JKU Sport - Wife's Mall Crawler on 35s. Badlands Winch, 2" Coil Spacers, 1" PA BL
1999 F250 7.3 - 290K Miles and Counting
"I am not going to censor myself to comfort your ignorance."
TexanTJ is offline
post #3158 of 112004 Old 11-04-2006, 06:04 PM
davenjeip
davenjeip's Avatar
Cleaned, adjusted, and bled the brakes. Feels great and stops awesome, even running a set of heavy 32's on steel wheels.
Realized that my turning radius issues weren't from my crossover steering conversion, but were due to adjustments I did a couple years ago, when I was running stock. Fixed that and got back turning I should have had. Plan to check my clearances tomorrow in the light and see if I have room to make it even a little better.
Started swapping out my bent spare tire carrier for one I had lying around in the garage. Realized that backing into a tree will not only bend your carrier, but can also bend your tailgate. Had a few issues because of that, and still have to modify it a little bit to work like I want, so this simple five minute job will have to be finished up in the morning.
Helped a newbie to my club install a set of rockers on his YJ. Easy install, and he was very happy with the results.
Tomorrow will be used to finish up the stuff I started today, along with an oil change. Also start packing up for next weekends wheeling trip.
2003 TJ
www.davenjeip.com
davenjeip is offline
post #3159 of 112004 Old 11-04-2006, 06:27 PM
jonster
jonster's Avatar
2014 JK Wrangler
I did the Rubicon locker mod. Waiting for the snow!
2014 White JKUR
jonster is offline
post #3160 of 112004 Old 11-04-2006, 06:44 PM
Trebor
what is the rubi locker mod?
Bobby T...Out!!!
Trebor is offline
post #3161 of 112004 Old 11-04-2006, 07:15 PM
Pags54
New RadiatorBarn radiator installed. A big improvement in quality compared to the stock radiator.
2000 TJ
Pags54 is offline
post #3162 of 112004 Old 11-04-2006, 08:52 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
makes it so you can lock without being in 4-low i believe
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #3163 of 112004 Old 11-04-2006, 08:54 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
got my new 32's mounted, and finally did my CB antenna mount too.
-Andrew
Marn is offline
post #3164 of 112004 Old 11-04-2006, 09:01 PM
jonster
jonster's Avatar
2014 JK Wrangler
The one where you can use the lockers in 4-hi and 4-low.
2014 White JKUR
jonster is offline
post #3165 of 112004 Old 11-04-2006, 09:09 PM
Ryuu600
removed my back seat and all the mounting brackets and seatbelts so I could install my rear storage box.
Built the rear storage box and installed it. I will post pics tomorrow. It turned out really nice.
/l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_)
'06 TJ X Blue w/dark khaki top, 4.0L, 6 spd, 3.73, 30x9.5R15 Wrangler GS-As mounted on Ravine wheels, Soft-top w/half doors, 4 100w ProComp Offroad lights(2 bumper, 2 windshied), Cobra 29 LTD w/4' Firestik, Custom rear storage box.
Ryuu600 is offline
modifications , tj
