What did you do to your TJ today? - Page 2097 - JeepForum.com
 438Likes
post #31441 of 112205 Old 04-08-2010, 10:08 PM
2003X
Originally Posted by stuff2c View Post
I had a WWF world title match with my rear suspension... staarted the RC LA install... damn thats a lot of work for the home wanna be mechanic. But I'm having a blast try it you'll like it
You should post your build pics in the RC LA thread.
My Build
2003X is offline
post #31442 of 112205 Old 04-08-2010, 10:14 PM
sanchagrins
Originally Posted by jrhord6 View Post
When i bought my 2002 TJ it had new tires and my fiance wouldn't let me get bigger tires until the ones I had were worn out. The time has come and I was able to put some 31x10.5 with the stock rims on my jeep. She saw the results and told me I needed bigger tires next go round......looks like she just approved a lift and 33's.
Nothing beats a supportive wife! It takes some time to get my Mrs. warmed up to certain jeep mods, but after showing her some of the nicer Jeeps here on JF and then seeing some them in action while wheeling she almost always comes around. I think it is a woman's competitive nature, she doesn't want to be out on the trail with the guy in the little jeep. I just got my approval for the tube fenders, and body lift so I can stuff some bigger tires under my rig.....after I get a bit more armor (she said she didn't want to be breaking down on the trail). That's pretty much the green light to do all the mods I want!!!! All it took was some time on JF and a few wheeling trips
sanchagrins is offline
post #31443 of 112205 Old 04-08-2010, 10:53 PM
SFT2
Originally Posted by little_Jeep View Post
I have used the piss out of that grinder...... probably one of the best purchases I have ever made.
Just make sure all the screws are tight. Mine lost a pair of the screws right behind the wheel. Still works, but makes a ton of noise. I need to go get a new one before I start chopping up my front bumper.
SFT2 is offline
post #31444 of 112205 Old 04-08-2010, 11:19 PM
Sgt.Fuzz
After much agonizing, I finally pulled the trigger on this:
My build:
Sgt.Fuzz is offline
post #31445 of 112205 Old 04-08-2010, 11:43 PM
Mitchin
Hmmmmm lets see here went on some trails today then the marsh.Then had to put doors and top back on after a beautiful 6 days with them off =(. The day before a new rear u-joint and oil change and well look down at pics you will see...
NIGHT CREW #16
Yellow Jeep Club #67
My Build Thread-
Mitchin is offline
post #31446 of 112205 Old 04-09-2010, 12:51 AM
TYLER_USCG
No pics = it didn't happen
i knew i should of snaped some pictures, but i was pretty focused on just getting out of there lol
Originally Posted by EaglesSJ View Post
I am disrespectful and my rude comment has been removed by a moderator
TYLER_USCG is offline
post #31447 of 112205 Old 04-09-2010, 01:28 AM
Mitchin
Originally Posted by TYLER_USCG View Post
i took it into a parking garage in new orelans and got stuck, it was classic. i guess my jeep sits taller than 6'4" bahaha
reeeeeeeeeeTARD haha
NIGHT CREW #16
My Build Thread-
Mitchin is offline
post #31448 of 112205 Old 04-09-2010, 04:59 AM
Boundless
Originally Posted by SFT2 View Post
I have one of those brackets that I'll be putting on next week it seems. Looks like my axles moved more than I want to live with when I put on my 2.5" lift Monday. All the bracket does is raise the axle end of the trackbar... some amount... let me go measure it... right at 2.5". I'm betting that the difference in 2.5 and 3 inches won't be huge.
What are you doing with the front trackbar? My front axle is off by a pretty good bit, and I'd like to fix it. Is there an adjustable trackbar out there that works?
After reading mudb8's http://www.jeepforum.com/forum/f9/tj...it-fit-738948/ I would say no, not without 2" bump stop extensions up front, I dont want to limit my up travel that much if I don't need to.
So my plan is to weld in some extra material to the track bar bracket on the diff side and relocate the mounting bolt hole over 3/4". I have a Dana HP30 I am building to swap in, so I may just do it to it only and keep my LP30 stock and put it up for sale.
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #31449 of 112205 Old 04-09-2010, 05:31 AM
SFT2
I'm not sure there needs to be more material. Looks like there's a pretty good bit of room over there already. I might wind up drilling mine this weekend when I put in the rear bracket.
SFT2 is offline
post #31450 of 112205 Old 04-09-2010, 07:05 AM
krahnilogikal
NICE!!! I've been eyeballing that 9.5ti myself. Just don't have enough coins to get it yet.
words, things, stuff
krahnilogikal is offline
post #31451 of 112205 Old 04-09-2010, 08:13 AM
Disconnect
Remember that if it is shifted towards the driver's side, you need to move the hole towards the driver's side (where there should be 2-3" of room)
Disconnect is offline
post #31452 of 112205 Old 04-09-2010, 08:21 AM
Hemi2Jeep
Ripped my dash apart looking for the short that randomly causes my "BRAKE" light to blink and the beeper to beep while I'm driving down the road and make me CRAZY. Unplugged the e-brake sensor and it kept doing it. The light blinks rather than coming on solid, so that indicates the issue is not a brake system problem but an e-brake ground (according to 02 FSM). After taking the center console apart, I found the sensor wire (white with a black stripe) and traced it into the dash where it quickly got lost.
Took the instrument panel apart and found the only white wire with a black stripe going in to the wiring harness and unplugged it.
That wasn't it. I guess the sensor wire goes to the computer and another wire comes from the computer to the dash, so I resorted to my last-ditch effort to stop the maddening beep. Can you tell the difference between this:
and this:
Damned thing won't beep at me any more.
Previous Jeep: '89 Wrangler Islander 5 Speed (AX-15) on 33's, Shackle Reverse w / 3" Lift, 2" BL, Locked Rear, 4.56 Gears, Custom Roll Cage, Warn x8000i, Posi-Lock Front CAD
Current Jeep: '04 Rubicon - Stock for now
Hemi2Jeep is offline
post #31453 of 112205 Old 04-09-2010, 08:42 AM
NorthWhiteWolf
lol nice ...
NorthWhiteWolf is offline
post #31454 of 112205 Old 04-09-2010, 08:43 AM
krahnilogikal
^^ Well done sir!
post #31455 of 112205 Old 04-09-2010, 08:45 AM
Sgt.Fuzz
Yeah, I've waited a long time to finally get a winch. I almost settled for a Smittybilt xrc8 winch a couple months ago, but I think I'll be much happier in the long run with the Warn. Plus it's made in America!
My build:
Sgt.Fuzz is offline
modifications , tj
churchofjt
