What did you do to your TJ today? - Page 2061 - JeepForum.com
 377Likes
post #30901 of 111934 Old 03-28-2010, 07:29 PM
kc5niy
Fab'd and installed cut-off switch for the power cable that goes to the winch. I like it a lot better that having no fuse to the winch.
KC5NIY, Tupelo, MS [
2004 Wrangler TJ - YELLOW JEEP CLUB MEMBER #127
kc5niy is offline
post #30902 of 111934 Old 03-28-2010, 08:18 PM
jesse18
^Im a newbie, what the real advantage to making a cuttoff switch for it???
1999 TJ Sport built. sold
1995 Grand Cherokee Limited. Sold
1994 Cherokee Sport. Present
jesse18 is offline
post #30903 of 111934 Old 03-28-2010, 08:23 PM
krahnilogikal
Pulled put my blown transmssion. Found a pretty good deal on a reman unit. I've been thinking of upgrading the clutches and bands and putting a shift kit in it. My trans guy says it probably isn't worth it. Any opinions?
words, things, stuff
krahnilogikal is offline
post #30904 of 111934 Old 03-28-2010, 08:24 PM
samv1368
Mounted a hi lift jack on hoodon a homemade mount, arb rear diff cover, some grab bars(best mod soo far)lol, painted my headlight bezels black. post pics tomo!
samv1368 is offline
post #30905 of 111934 Old 03-28-2010, 08:25 PM
little_Jeep
I suspect that your transmission guy knows best.....
little_Jeep is offline
post #30906 of 111934 Old 03-28-2010, 08:28 PM
igrok
Originally Posted by SYN ACK View Post
It wasn't today but I picked it up from the body (butcher) shop with my new upgraded bumper installed. I just need to do the wiring for the fog lights.
what bumper is that? It looks pretty good!
Common sense is surprisingly, not that common.
igrok is offline
post #30907 of 111934 Old 03-28-2010, 08:39 PM
SYN ACK
SYN ACK's Avatar
Thanks! It's the Smittybilt XRC it has a built in winch plate, light mounts, and D-ring mounts. The welds could be better but they're not bad. It looks really sturdy as well. The best part is it isn't too expensive.
Are you new? Own a TJ? Want a TJ?
Everything you need to know is here:
SYN ACK is offline
post #30908 of 111934 Old 03-28-2010, 09:09 PM
kc5niy
Since the winch may pull over 100 amps during a hard pull, a fuse is kinda of out of the question or you would be replacing fuses all the time.
Without a fuse the cable remains 'hot' all the time and a short could blow the battery or cause a catastrophic fire and burn your jeep up.
Not Good!!
So the switch allows the cable to remain 'cold' until the winch is needed.
Thanks for asking, I'm a newbie also, had the jeep for about a year.
kc5niy is offline
post #30909 of 111934 Old 03-28-2010, 09:17 PM
w9kh_kevin
what's the info on the switch? manufacturer, model, load rating?
'90 YJ - stock, long since sold
'97 TJ - 4 cyl, ax-5, np231, 2"bb, 31's, Vortex winch, stock axles, soft on the top-hard on the bottom.
2005X
i knew if didnt get what i could afford now i would end up blowing the money on something else
w9kh_kevin is offline
post #30910 of 111934 Old 03-28-2010, 09:17 PM
jesse18
That makes perfect sense to me now. Nice trick. Once i get a winch i will probably copy your idea!!! THanks man.
jesse18 is offline
post #30911 of 111934 Old 03-28-2010, 09:44 PM
kc5niy
12 volt 350 amp got one similar at auto zone. Here is a url with one close to the one I got,
Longacre Economy Battery Disconnect Switch - RacingPlus.com
kc5niy is offline
post #30912 of 111934 Old 03-28-2010, 09:46 PM
sanchagrins
Removed the back seat to accommodate my spare tire and camping gear for this weekends wheeling trip!
sanchagrins is offline
post #30913 of 111934 Old 03-28-2010, 09:47 PM
kc5niy
Cool, good luck!!
kc5niy is offline
post #30914 of 111934 Old 03-28-2010, 09:49 PM
jchou
I gave the key to my daughter so she can learn manual transition for two hours... Well, I stayed with the key to teach
And yeah... she will get her driving test on a Jeep, not on a car
jchou is offline
post #30915 of 111934 Old 03-28-2010, 10:30 PM
2003X
Finnaly installed my currie HD and RC track bar. Pics to follow tom.
My Build
2003X is offline
modifications , tj
Currently Active Users Viewing This Thread: 8 (5 members and 3 guests)
carbert , Heretic122 , ladytex70 , tjkelowna , tworley
