What did you do to your TJ today? - Page 1994 - JeepForum.com
 678Likes
post #29896 of 113124 Old 03-07-2010, 05:29 PM
little_Jeep
Originally Posted by cheapjeep06 View Post
Those are the LATCH system...there is also a strap with hooks to hold the carseat to the jeepseat.
They hold only the seat, not the child,, correct? Reason, I ask, is when you install a 4 or 5 point harness system in a vehicle, you have to be careful not to secure the straps too low compared to the shoulder level of the person in the seat as it could cause major injuries to the persons back. In the vehicle situation, the straps are the same straps that go thru the seat back and across the shoulds and down to the latch between the legs... As long as these straps are not part of the harness that holds the child in, you are good to go.
little_Jeep is offline
post #29897 of 113124 Old 03-07-2010, 05:34 PM
curlytj3582
i was informed the my 8.8 brackets from MORE are at the house and waiting on me when i get home from offshore!!!!!!
curlytj3582 is offline
post #29898 of 113124 Old 03-07-2010, 05:40 PM
Deacon
Shining Adonis
Deacon's Avatar
Originally Posted by RiponredTJ View Post
And all the wiring is nicely tucked away.
Little holes are sealed with an o-ring.
Hmmm... Is that some sort of kit you order, or is that something you figured out yourself? I'd like to do the same. Any info you can share would be much appreciated!
Deacon is offline
post #29899 of 113124 Old 03-07-2010, 05:49 PM
Mike_Motorbike
All child /baby seats (Except infant and booster seats) has a way to secure it with either the stock seat belts or straps that go from the chair to metal hoops in the lower part of the cars seat (if equipped) My jeep is not.
They also all have straps the go to a lower point behind the seat.
If you look in the back seat of almost every vehicle you'll see two or three little loops made out of flat sheet-metal. Sometimes covered by a plastic cover. They are there for the baby seats...
In other words . Its a standard baby seat strap... They all have them..
If the don't through it away......
Originally Posted by little_Jeep View Post
Do these straps simply hold the car seats in, or are they part of the harness that restrains the kids?
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
Mike_Motorbike is offline
post #29900 of 113124 Old 03-07-2010, 05:56 PM
little_Jeep
Okay, you answered my question. Please keep in mind, I'm an old fart that hasn't seen a car seat in over 20 years I was just concerned about the design of the seats and if the design (not your install) was safe for your kids.
Like I said, you answered my question.
post #29901 of 113124 Old 03-07-2010, 05:58 PM
ih8pepl73
Originally Posted by krahnilogikal View Post
From the factory, when you flip on your high beams, the fog lights turn off. To get around this you have to bend post #1 (mine are labeled) on the fog light relay until it lays flat onto the side of the relay. This keeps it from plugging in and then you can have your fogs and high beams on at the same time. There is a write up somewhere out there that gives more details on exactly which post needs to be bent.
Doesn't work on some models. Can't do it on mine.
ALPHA/OMEGA OFFROAD, MD Chapter
Originally Posted by The_TwStD_1 View Post
Procrastination's a lot like masturbation. It's all fun and games until you realize you're only screwing yourself.
Originally Posted by TheRealKTrain View Post
The lines on half doors make extra sex compared to full doors
ih8pepl73 is offline
post #29902 of 113124 Old 03-07-2010, 06:29 PM
stuntjumper
Changed Tranny and Tcase fluid. Cat liter is your friend...
Finished install of JKS Disco's (storage pins)
stuntjumper is offline
post #29903 of 113124 Old 03-07-2010, 06:31 PM
RiponredTJ
Happy Member No. 1
RiponredTJ's Avatar
I just used trim panel retainers for the holes from the tire carrier and rubber bumpers. Needed two different sizes. Trim Retainers 1 / Regular or Bulk Packaging
A plastic plug button works well for the hole from the brake light wire.
Both readily available at any auto parts store.
Total cost: negligible
This City is what it is because our citizens are what they are.
RiponredTJ is offline
post #29904 of 113124 Old 03-07-2010, 06:40 PM
Disco69
2001 TJ Sahara
3.5" RE Superflex Suspension Lift -|- RE Adjustable Trackbar -|- 35x12.50 STTs on Eagle Alloy 15x10s-|- D30 w/ ARB and Superior Outer Axle Seals -|- D44 w/ Detroit Locker -|- Superior 4.88s -|- ROKMEN Mercenary Front Bumper -|- ROKMEN Sliders -|- Warn Rockcrawler Rear w/ Carrier -|- Warn M8000 Winch -|- JKS 1.25" BL -|- JKS 1" MML -|- Old Man Emu Long Travel Shocks -|- OME Stabilizer -|- ARB OBA -|- MetalCloak Arched Front Tube Fenders
Sienna Jeep Club Member #29
Disco69 is offline
post #29905 of 113124 Old 03-07-2010, 06:58 PM
Alkaline
I put her up on the wash rack for the first time since I've owned it.
It's amazing how much mud can stay plastered in an undercarriage.
After a hot pressure wash I found out the previous owner was nice enough
to spray rubber liner under it, but apparently ran out towards the rear.
☠ ʎɐqə ɯoɹɟ pɹɐoqʎəʞ ɐ ʎnq ı əɯıʇ ʇsɐl əɥʇ sı sıɥʇ ☠
'98 TJ (toy), '91 XJ Briarwood(DD)
Alkaline is offline
post #29906 of 113124 Old 03-07-2010, 07:12 PM
Martinsc
^ Damn I wish I had one of those. Probably makes cleaning the undercarriage 1000x easier.
My Build-
Martinsc is offline
post #29907 of 113124 Old 03-07-2010, 07:16 PM
AcidRainCheck
put a new tcase in flushed the tranny and diffs
Just Empty Every Pocket
AcidRainCheck is offline
post #29908 of 113124 Old 03-07-2010, 07:27 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
thats cool. i guess u have one at work?
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #29909 of 113124 Old 03-07-2010, 07:32 PM
little_Jeep
Tyler, if you would build one of these, I'd come over and use it
post #29910 of 113124 Old 03-07-2010, 07:38 PM
MedicJK
2015 JK Wrangler
Spent the last bit cleaning an egg off the grill because some ****ing punk decided it would be cool to throw an egg at my jeep.
Bastards, I wish I would of caught the little ****er.
Sienna Pearl Coat Club Member #24
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
MedicJK is offline
modifications , tj
Niteguy13
