What did you do to your TJ today? - Page 195 - JeepForum.com
 438Likes
post #2911 of 112208 Old 10-21-2006, 08:09 PM
bheiser
bheiser's Avatar
2006 KJ Liberty
I spent the day waxing it using my favorite professional grade Meguiars products
And my license plates arrived yesterday so I put them on!
And lastly, I posted an ad to sell my stock 215x75x15 tires - but no takers yet :-(. I figured $200 for 5 nearly new tires would sell, but maybe not...
bheiser is offline
post #2912 of 112208 Old 10-21-2006, 08:11 PM
Torn66
installed my PA 1" body lift on the rubi, ooil change....putting in the BPE's i didnt have time to do when i did my BB a few weeks back.
then ski rack gets drilled on the hardtop for Killington!!
06 Rubicon
2in BB__1in BL__32 BFG Muds__SIRGCAL in seat box
Torn66 is offline
post #2913 of 112208 Old 10-21-2006, 09:36 PM
jonster
jonster's Avatar
2014 JK Wrangler
Installed my Jeep Medic Tummy Tuck.
2014 White JKUR
jonster is offline
post #2914 of 112208 Old 10-21-2006, 09:43 PM
stjjames
Bought her a 5.2 drivetrain
P.A.O.
Beauty comes with Dark Thoughts
stjjames is offline
post #2915 of 112208 Old 10-21-2006, 10:23 PM
stogie25
stogie25's Avatar
I put on my hard top.
To most guys the day after the Superbowl is the coldest day of the year. At least there is still hockey. To me the day I put on my hard top takes that honor leaving the day after the Superbowl as a close second. As this usually occurs in mid October, at least there is still football.
I also changed my downstream O2 sensor. The old one was as bad as I thought it was. That put the stroke back in stroker.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #2916 of 112208 Old 10-21-2006, 10:29 PM
SurfnSnow
2010 JK Wrangler
Painted and installed my Rockhard 4x4 bolt in cage
SurfnSnow is offline
post #2917 of 112208 Old 10-21-2006, 11:51 PM
soxlover
soxlover's Avatar
K&N cold air intake that I ordered weeks ago finally got put in, and I love the way it sounds. Now I gotta go back to remodeling the house.
soxlover is offline
post #2918 of 112208 Old 10-22-2006, 01:12 AM
Texas TJ
Texas TJ's Avatar
my first flop and a fractured foot and i snapped the front driver side inner and blew up the u-joint.
bent fender, dent right on the jeep logo, dented the hood, dented the windshield frame.
im sore and drugged up
you know how they say keep your hands and arms inside the vehicle at all times?
theyre right
2001 TJ YELLOW
I flopped and broke my piece
If it won't budge, get a bigger hammer, if it breaks in the process it needed to be fixed anyway.
Texas TJ is offline
post #2919 of 112208 Old 10-22-2006, 02:03 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
went to install my budget boost but was told i cant use the gararge. WTF
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #2920 of 112208 Old 10-22-2006, 05:15 AM
yepitsme
Removed the front swaybar bolts, drilled a hole in the shank for a pin and a hole through the head for some wire. Swaged the wire from the head of the bolt to the pin, installed and VOILA! Homemade quick disconnect!
Got some 3M 4" grey grip tape, cut it in the shape of the sides of the windshield frame and fold down bracket, applied. Covers the tree limb scratches, prevents more, and looks pretty good as my jeep is silver.
Installed a rear bumper I bought on ebay from a place called Beach Offroad. Cost me 177.00 to my door and came with d-ring brackets and a 2" receiver. It's a little bit bowed towards the top and the finish isn't all that great but man is it sturdy! 1/4" 2x4 steel with 8 grade 8 mounting bolts! D-ring brackets are passed through the bumper and welded front and back. Receiver is attached in a cutout at the bottom and is continouously welded top, front, bottom and back. Drilling the holes for the inner 4 bolts wasn't too hard, but installing the inner driver's side bolts was a BI*CH!!
Bought a Thule Adventure 1150 galvanized trailer for hauling camping gear and whatever behind the Jeep. Cargo box dimensions are 3 1/2' x 5' x 14". The trailer will carry 1100 lb and only weighs 220 lbs empty. Snagged it up for 400.00. Silver galvanized box and frame, with black plastic fenders and silver wheels. Matches my Jeep colors and looks cool behind it! Here's a picture: http://jmcamper.com/trailer/index.ph.../image/31.html Mine doesn't have the Thule plastic top and the tail lights are round, but you get the idea!
Mark
2005 Silver Wrangler X Auto, Rubi Tires & Wheels, Homebrew QD's, Tow Hooks fore & aft, Fisher LD Plow for the white stuff.
yepitsme is offline
post #2921 of 112208 Old 10-22-2006, 08:11 AM
YJ-Mike
Put on a Borla Cat-Back system. PITA to drop the skid and re-install, toughest part I think was getting the rubber hanger pieces off of the old muffler/tailpipe. Finally just broke out the grinder with a cut-off wheel.
Mike
2006 TJ X (Stock - w/ Borla Cat-Back Exhaust)
Built a YJ from the ground up:
- '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors.
-----> Build thread can be read here:
YJ-Mike is offline
post #2922 of 112208 Old 10-22-2006, 09:15 AM
Texas TJ
Texas TJ's Avatar
these are more better
http://noboundaries4x4.com/cart/inde...products_id=56
2001 TJ YELLOW
Texas TJ is offline
post #2923 of 112208 Old 10-22-2006, 10:40 AM
mytjtoy
CJ--my drug of choice!
mytjtoy's Avatar
1976 CJ7
Moved my Sirius box, installed my dome light bypass kit and wired in my hardtop harness for defrost, wiper and squirter!
Never say "I've got a gun." If you need to use deadly force, the first sound they hear should be the safety clicking off.
The average response time of a 911 call is 23 minutes, the response time of a .357 is 1400 feet per second.
mytjtoy is offline
post #2924 of 112208 Old 10-22-2006, 09:33 PM
I FLEX
I FLEX's Avatar
Started to manually sipe my tires. I had them originally done at the tire shop but the tread has worn past the depth they did them at, they said they could not go any deeper.
I've been doing it with a razor blade and following the cut s on the edge of the lugs from the original. Im hoping it will help the traction now that its starting to rain in Washginton. If all else fails i may cough up for new tires...
- Micah
Muddy TJ
2001 SE 5spd | 33x12.5x15 Toyo MT's|
RE.BB with RE3.5 shocks | Anti-Rock
#13
(they are some what updated)
I FLEX is offline
post #2925 of 112208 Old 10-22-2006, 09:36 PM
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
Red marker lights
I, with the help of my dad and his arsenal of tools, installed some red 2 inch led on the corners. I freaked when the darn things didn't work!! It took me a minute to realize I had the pigtails plugged in backwards. I switched them up and everything is golden.
Grote brand lights are bright!
1948 CJ2a
Airborne4X4 is offline
modifications , tj
