What did you do to your TJ today? - Page 194 - JeepForum.com
 1082Likes
post #2896 of 113828 Old 10-20-2006, 11:51 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
PB blasted one last time before my lift goes on tomorrow. wish me luck with them rear shock bolts
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #2897 of 113828 Old 10-20-2006, 11:52 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Originally Posted by purplewindworm
Took my Half Doors (that I recently bought used) to a few paint and body shops for estimates to prep & paint them to match my jeep. Both doors have a very minor ding in them. I removed ALL the hardware. Maaco quoted $331, A-1 ( a guy that has done great work for me in the past in Arlington TX) quoted me $150 and Marino's quoted me $200.
why dont you prep them yourself. thats 2/3rds the labor cost.
-Andrew
Marn is offline
post #2898 of 113828 Old 10-20-2006, 11:52 PM
Awshux
Cynical Bastard
Awshux's Avatar
Good luck! Have fun with the rear trackbar relocation bracket too...that was the single biggest PITA when I did mine!
You live and learn. At any rate, you live.
-Douglas Adams
Awshux is offline
post #2899 of 113828 Old 10-21-2006, 02:10 AM
wheelinman03
New uppers with glass sliders and new soft top... too bad they sent me clear windows instead of tinted like I ordered
98 TJ- Kilby gastank/ steering box skids, Sky jacker high clearance tcace skid, 1'' BL, M.O.R.E. 1" MM's, Poison spyder rocker guards and sport cage, Warn XD9000i on A to Z fab Winch plate, RE 2" BB, Nth Diff slider, Quick disco's, PSC Rock Ring, JB Conversions Super short SYE kit, and a burly CV Drive shaft.
LOTS more to come
I wave, Do you?
wheelinman03 is offline
post #2900 of 113828 Old 10-21-2006, 11:07 AM
firejeeper
building a bracket for the highlift that goes on the rear rollbar.
firejeeper is offline
post #2901 of 113828 Old 10-21-2006, 11:20 AM
Pags54
Battery just up and died with no warning so from hearing good things from you all I installed a Red Top Optima battery . Next week new radiator goes in because every seam on the original is starting to leak.
2000 TJ
Pags54 is offline
post #2902 of 113828 Old 10-21-2006, 11:46 AM
ScottJ83
Swapped out soft top with hard top, washed bird s--- off the hood
ScottJ83 is offline
post #2903 of 113828 Old 10-21-2006, 12:18 PM
FL 4.0L
Picked up 3 NAPA Gold filters for the next 3 changes. Six-something a filter. Internals look substantial. Although I plan on keeping this rig for a long time, I wonder if I'd get the same results with the $2 silver line filter and Coastal oil from Advance every 3K. About $10 cheaper a change.... 50 changes in the next 150,000 miles...$500 saved?
FL 4.0L is offline
post #2904 of 113828 Old 10-21-2006, 12:44 PM
davenjeip
davenjeip's Avatar
Just swapped in some YJ front brake lines.
Going to finally unpack it and wash off the dirt from last weekend. I'll also give it the after trip once over and see if I broke anything.
Also going to check the mileage. Due for an oil change soon, but might be good for one more trip.
2003 TJ
www.davenjeip.com
davenjeip is offline
post #2905 of 113828 Old 10-21-2006, 01:21 PM
andwes03
Inatalled my new radiator, installed my new wiring harness for my Lights and changed the oil
2001 RED TJ with GC/CV lift, 33x12.50 Pro Comp Mud Terrains on black steelies, OH and cant forget the STEALTH TOP
andwes03 is offline
post #2906 of 113828 Old 10-21-2006, 02:47 PM
SomeGuysName
Finally mounted my CB solid and sanded the paint around the antenna mount where it bolts on so it gets a good ground. Then I spray painted it with some clear coat to seal it back up once I had it tightended down good. Gonna strap a lot of the body pieces to the frame tomorrow and do the same with those then set the SWR again.
SomeGuysName is offline
post #2907 of 113828 Old 10-21-2006, 03:18 PM
PM Thor
Custom User Title
PM Thor's Avatar
Location: Banging your head against a wall uses 150 calories an hour
kicked it and told it that I was pissed. My hands hurt.
It's simply useless to argue on the interwebs. It's akin to arguing with a toddler. Doing so only makes you look silly and they always poop their pants.
PM Thor is offline
post #2908 of 113828 Old 10-21-2006, 04:29 PM
sevise
Mo****rless
sevise's Avatar
Hanson Tire Carrier, LiteDOTS, and LitePlate.
sevise is offline
post #2909 of 113828 Old 10-21-2006, 04:35 PM
YellowNJTJ02
Tie wrapped my front Driveshaft to my ENGINE SKID.... AAAAHHHHHH - the vibes are all gone!!!
02 Yellow TJ
RE 4.5" SF, Teralow
D44 Rear Detroit, Alloy USA Chromo shafts - ZJ discs - 4.56
D30 Front Powertrax No-Slip - 4.56
33" BFGs, Snorkel, Warn x8ki w/ 5/16" synthetic
Bulletproof Bumper up front, Warn Rear SOTC
YellowNJTJ02 is offline
post #2910 of 113828 Old 10-21-2006, 05:53 PM
wheelinman03
Got some new tires on her... ooo looks soo good
LOTS more to come
I wave, Do you?
modifications , tj
rcroane
