What did you do to your TJ today? - Page 192 - JeepForum.com
 675Likes
post #2866 of 113121 Old 10-18-2006, 04:25 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Got rear ended going to work this morning... at first I was worried he mangled my rear crossmember since I don't have a rear bumper right now... but luckily it was a lowered Civic and he went under me. A good bit of damage to his hood from my gas tank skid though
I'll be Savvy someday!
neZZr is offline
post #2867 of 113121 Old 10-18-2006, 04:34 PM
JSBlu974X4
ha, he just paid your new tire carrier I take it?
anways, i worked on welding my 8.8 brackets
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #2868 of 113121 Old 10-18-2006, 04:38 PM
alexor
In the last 5 days, I have turned Mr. Jeep into Matriarch Jeep!
I painted the fender flares with Krlyon Fusion Ultra Flat.
I FINALLY got the back-up lights working by replacing the neutral safety switch.
I got in a CD player, wired and mounted it myself. It doesn't even skip off-road!!
The feeling of euphoria I had while driving it down the road with the top down and music playing was overwhemling.
alexor is offline
post #2869 of 113121 Old 10-18-2006, 05:24 PM
Piratejonh
Piratejonh's Avatar
I removed, had welded, and replaced the cracked header. Holy smokes, I'm not a mechanic so it only took 2 days, 6 beers, 14 bandaids, and an apology to the neighbors for the cursing and hammer chunking. Cool though it didn't cost anything but time, and I learned something about my jeep. Till next payday.....
Piratejonh is offline
post #2870 of 113121 Old 10-18-2006, 09:03 PM
jeeprz kreeprz
Originally Posted by Materdaddy
Not to be an ***, but it looks like your diamond plate goes under your rockers... you might want to re-think that as it will mess with the preload (if you did pre-load) on your rockers. That could spell damage to the tub, which is what I presume you're trying to eliminate with the rockers in the first place!
What made you decide to remove the snorkel? Just curious....
I finished fabbing and welded (almost all) of the front roll cage.....ran out of wire with two more welds left....isn't it wonderful when you forgot that you already used the spare wire roll after everyone closes?
Gotta order the padding and ties. Only thing left on the cage is to weld the rear bar where the five point will mount. That will wait until the cash flow allows me to get the seats I want.
02' Sahara Owner
jeeprz kreeprz is offline
post #2871 of 113121 Old 10-19-2006, 10:35 AM
Lostj
Lostj's Avatar
(yesturday)
I put in some aux. back-up lights. I just slpiced them with the reverse light wires so they come on when I reverse.
I dont like how they look that much and will probably replace them later on with some white rectangle lights, but for $14 you cant beat it.
00'TJ
74'CJ5 For Sale
Lostj is offline
post #2872 of 113121 Old 10-19-2006, 10:55 AM
98TJSport
Originally Posted by oreo
(yesturday)
that looks like a cool spot for them, cuz i know from experience that on the bumper they will just get ruined from water.
==KF7HBV==
2004 TJ X
98TJSport is offline
post #2873 of 113121 Old 10-19-2006, 11:31 AM
Materdaddy
Materdaddy's Avatar
You quoted the wrong guy... I didn't remove the snorkel, I was pointing out the problems with his "cover-up" and preload on his rockers, it was UTWeezul you should have quoted
O|||||||O
Materdaddy is offline
post #2874 of 113121 Old 10-19-2006, 03:01 PM
jlawson382
(2 weeks & 2500 miles retroactive post) I bought it!
jlawson382 is offline
post #2875 of 113121 Old 10-19-2006, 06:17 PM
jeepster4.0
i put on a new set of goodyear wrangler silent armour 31''x10.5 after having stock tires,man what a difference looks like a real jeep, next time ill go bigger!!
jeepster4.0 is offline
post #2876 of 113121 Old 10-19-2006, 07:35 PM
Rick98TJ
1997 XJ Cherokee
I repainted my headlight bezels black.
RJC #380
98 TJ Sport
CV/ZJ/JK Frankenlift:
ZJ front coils w/ 2" Daystar spacer
JK Shocks front and rear
CV Rear coils
Rick98TJ is offline
post #2877 of 113121 Old 10-19-2006, 08:34 PM
FL 4.0L
6 qts. of dino 10W-30 out, 6 qts. in. Used the last Motorcraft filter I had. I'll use a NAPA Gold filter from here on out. Since my new tires only have 1500 miles on them, I'll wait for the next oil change to do the rotation.
FL 4.0L is offline
post #2878 of 113121 Old 10-19-2006, 08:34 PM
blacktjsport
Ordered a set of the $200 smittybilt flat fenders!! Also got another piece of my frankenstein 4" lift (front trackbar). I have a lot of projects going on this winter (front and rear Waggy D44's w/ ARB's and 4.88's, 4" lift, SYE & CV shaft, flat fenders and prolly more!!)
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline
post #2879 of 113121 Old 10-19-2006, 09:53 PM
jerico
jerico's Avatar
Had my new BFG. 31"s and rock crawlers installed today. Looks "GREAT."
jerico is offline
post #2880 of 113121 Old 10-19-2006, 09:55 PM
eclipse27
Put a flip out stereo in it, putting gps in it tommorrow
eclipse27 is offline
modifications , tj
