What did you do to your TJ today? - Page 191 - JeepForum.com
 474Likes
post #2851 of 112301 Old 10-17-2006, 08:36 PM
YJ-Mike
Finalized the deal today on the 06 Wrangler X I am picking up tomorrow.
Mike
2006 TJ X (Stock - w/ Borla Cat-Back Exhaust)
Built a YJ from the ground up:
- '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors.
-----> Build thread can be read here:
YJ-Mike is offline
post #2852 of 112301 Old 10-17-2006, 09:02 PM
i_am_wood
changed the speedo gear- no more figuring speed in my head thanks for the help guys
BLUE JEEP CLUB MEMBER #207
i_am_wood is offline
post #2853 of 112301 Old 10-17-2006, 09:08 PM
98TJSport
Originally Posted by firejeeper
Found water again on the pasenger floorboard. I will have to take the cowl off tomarrow to see what is going on.
that might be the AC drain tube, some people notice that at high speeds
the wind will push the condensation back in the jeep. that is fixed by
putting a 90* elbow on the drain tube
==KF7HBV==
2004 TJ X
98TJSport is offline
post #2854 of 112301 Old 10-17-2006, 09:16 PM
Jeepin_Al
Just taking it easy!
I haven't driven my Jeep in weeks, let the wife drive it to work one day and she won't give it back............
"rejected by the signature police"
Jeepin_Al is offline
post #2855 of 112301 Old 10-17-2006, 09:25 PM
purplewindworm
Stripped down my new half doors in preparation for paint, dropped the lock cylinders off at a locksmith to have them rekeyed. $30 for the pair ..... OUCH!!!
purplewindworm is offline
post #2856 of 112301 Old 10-17-2006, 11:05 PM
VICTIM_OF_PAIN
VICTIM_OF_PAIN's Avatar
Leave her right away!
Ex - 2001 Wrangler, 2" BB, 32" BGF AT's. JKS Quicker Disconnects, Oil Pan Skid, Steering Box Skid. Hard Top, Soft Top, Safari Top, Olympic Mountaineer Rack.
Current - 2008 Unlimited Wrangler Rubicon. Rock Krawler Stock Mod 2.5" lift, 35x12.50x15 Cooper STT's on Pro-Comp D-Windows, Husky Floor Liners, Mastercraft Grab Handles, Weathertech Side Window Deflectors, Hitch mounted D-Ring, Rancho Oil Pan Skid, Rugged Ridge E-Disco Skid, and a Skid Row Evap Canister Skid plate.
It is better to keep one's mouth shut and be thought a fool.... than to open it and remove all doubt.
VICTIM_OF_PAIN is offline
post #2857 of 112301 Old 10-17-2006, 11:14 PM
jeeprz kreeprz
Got in late from work, but had enough time to set up the plan (easiest available to me) to add additional pipe to the roll cage over the driver & passenger. About 1/2 way done with all the welding....after that, it's just cleaning up the joints, spraying black, and ordering the new padding.
02' Sahara Owner
jeeprz kreeprz is offline
post #2858 of 112301 Old 10-18-2006, 08:52 AM
Monkeylube
I took off all my fender flares, so they wont get ripped off at Greyrock ORV this weekend.
Monkeylube is offline
post #2859 of 112301 Old 10-18-2006, 12:40 PM
UTWeezul
Installed my AtoZ Rocker Guards and covered up my snorkel hole. I used some diamond plate that I painted black like the rocker guards to cover the snorkel hole. I think it turned out nice. Trying to decide if I want to put the diamond plate on the other side to even things out. I don't really want to drill the hole in the Jeep though.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #2860 of 112301 Old 10-18-2006, 12:43 PM
Fritz R.
Put a new amp in for my sub. Sounds much better!
Fritz
'97 TJ, 4.0L, AW-4, Flipped D300/4:1, ARB's, D44, Swayloc, RK LA, PC coils, Rancho 9000's, 33x12.5 Trxus, etc.
Fritz R. is offline
post #2861 of 112301 Old 10-18-2006, 12:53 PM
DVS TJ
DVS TJ's Avatar
Tried to do new spark plugs, wires, and distributor cap and snapped the tab for the screw on the distributed cap on the distributor itself.
DVS TJ is offline
post #2862 of 112301 Old 10-18-2006, 01:37 PM
igofshn
Locked @ both ends
igofshn's Avatar
New alloy usa chromo shafts for the front, had front driveshaft straightened and balanced.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #2863 of 112301 Old 10-18-2006, 01:47 PM
icu_runnin
Put the 36" TSL's on and fix the front lower control arm brakets on the axle. Also cleaned the K&N since the snorkel tends to suck in leaves from trees near by. Today I will be replacing the rear pinion yoke and drive shaft. YAY!
icu_runnin is offline
post #2864 of 112301 Old 10-18-2006, 05:02 PM
YJ-Mike
Bought it, drove around awhile with a big smile on my face, and then reluctantly came back home.
Mike
YJ-Mike is offline
post #2865 of 112301 Old 10-18-2006, 05:10 PM
Materdaddy
Materdaddy's Avatar
Not to be an ***, but it looks like your diamond plate goes under your rockers... you might want to re-think that as it will mess with the preload (if you did pre-load) on your rockers. That could spell damage to the tub, which is what I presume you're trying to eliminate with the rockers in the first place!
O|||||||O
Materdaddy is offline
modifications , tj
Heretic122
