Quantcast What did you do to your TJ today? - Page 1736 - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
Old 11-18-2009, 01:28 PM   #26026
B2CARPEN
Jeep Junky
B2CARPEN's Avatar
Originally Posted by idiot magnet View Post
I searched a ton of sites for a stock replacement bracket to replace the bent one I have, but had no luck.
Do you know who sells one?
I'm planning a lift next year, so I was trying to find a good solution that would brace the track bar and it would be a bolt on and easily reversible.
Do you really think it would break the differential?
If you are just looking for a new rear track bar relocator mount then you can call up Rough Country. Mine has held up very well and I haven't heard of any issues from the other members running RC.
I have no idea if it would bust the diff but I would just look into it to be sure. If you are experiencing enough stress to bust the track bar mount, then I wouldn't want to revert that stress to the differential if you know what I mean.
Edit - And by looking at your jeep info it appears you have a YJ... but you posted in the TJ thread Do you also have a TJ that this will be mounted to?
JFI member #1
Built not bought member #153
IndyORV
Extreme Jeep Club
Down and Dirty Off-Road
My Build Thread - axle swaps and long arm madness
B2CARPEN is offline   Reply With Quote
Old 11-18-2009, 01:36 PM   #26027
idiot magnet
Canadian for life... eh!
I'm rebuilding an 05 unlimited and I drive a 95 YJ. It only lets you put one vehicle in the info page.
idiot magnet is offline   Reply With Quote
Old 11-18-2009, 01:37 PM   #26028
B2CARPEN
Jeep Junky
B2CARPEN's Avatar
Ahhh that makes sense... gotcha!
JFI member #1
IndyORV
Extreme Jeep Club
Old 11-18-2009, 01:53 PM   #26029
idiot magnet
The bracket was bent from a side impact accident to the rear drivers side tire which shoved the bracket over and bent the track bar (I have a replacement track bar already).
I've found tons of relocator brackets for TJ's with lifts from 2" to 8", but no plain jane replacement brackets for a stock vehicle. I can make brackets to weld to the axle housing to strengthen it if you think that's better than this bolt on unit. I have a plasma cutter, chop saw and several welders, so that isn't an issue, but I am concerned now that it will do damage to my housing/axle if I go that route. I tried calling the company just now to get more info, but with no luck of getting a person on the phone.
Can anyone get me a measurement from the differential cover bolts to the center of the T55 bolt for the track bar to make sure my measurements are correct?
A rebuilt '05 Unlimited w/ 6 spd, 4.0, 3" BDS springs, front locker, warn front bumper, PS corners, rock sliders and the list goes on and on.
Former Jeeps: 79 CJ7, 81 CJ7 Renegade, 85 CJ7 and a 95 YJ.
Project car: Big Block 4spd 69 mach 1 (it's back on the rotisserie for the final time).
Indyorv.com
Old 11-18-2009, 01:54 PM   #26030
johnny9
washed,waxed and tryed to get some deep scratches out..after 2 waxes i think it helped..maybe it will slide thru the 4 wheeler trails better now lol..
gotta get this hill carved out so the jeep will fit this weekend..top priority after saturdays fun at hard rock ocala..
about a 150 ft drop after what ya see in the pic and was made by 4 wheelers..i can do it..i think i can anyway..
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build- http://www.jeepforum.com/forum/f22/punishers-ezgo-build-thread-1065655/
johnny9 is offline   Reply With Quote
Old 11-18-2009, 02:02 PM   #26031
B2CARPEN
Jeep Junky
B2CARPEN's Avatar
Then in that case even if you installed a relocator bracket it still might not line up right if the main bracket is bent and shifted. The only other thing I can think of is try and see if you can pick one up from a junkyard, or try and knock the original it back to the original position and weld bracket supports to the axle housing like you mentioned.
I also wouldn't exclude the idea of your bolt on unit... but I would just look into it more before going that route.
JFI member #1
IndyORV
Extreme Jeep Club
Old 11-18-2009, 02:15 PM   #26032
MisfitSeven
MAIL Crawler.
MisfitSeven's Avatar
before:
after:
i did this about a month ago:
i cut sipes into all the tread blocks because the sipes dont go all the way through the tread. they are really starting to open up...bring on the snow!
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1.
*85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces.
Originally Posted by Patton View Post
You won the nicest mail jeep award.
I'm typing this real slow to try and help you.
NEW and USED parts for sale. PM me.
MisfitSeven is offline   Reply With Quote
Old 11-18-2009, 02:40 PM   #26033
will228
Originally Posted by MisfitSeven View Post
before:
after:
what did u use to sipe your tread?
will228 is offline   Reply With Quote
Old 11-18-2009, 02:50 PM   #26034
MisfitSeven
MAIL Crawler.
Old 11-18-2009, 02:56 PM   #26035
NoVaHunter
I know this is a dumb question, but what does siping do?
[QUOTE=KHoff90;11392897]Has anyone really been far even as decided to use even go want to do look more like?[/QUOTE]
NoVaHunter is offline   Reply With Quote
Old 11-18-2009, 03:14 PM   #26036
timberwolf0122
Timelord Victorious
timberwolf0122's Avatar
It creates loads of little ridges and teeth that increase grip on snow and ice.
Atheist Jeep Club Member #2
MacGyver Club Member #1
Doctor Who has died 10 times, is on his 11th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline   Reply With Quote
Old 11-18-2009, 03:41 PM   #26037
EugeneTheTJ
Homeless guy, savvy?
EugeneTheTJ's Avatar
Siping also reduces heat on your tread blocks, thus, it can give you a little longer tread life
EugeneTheTJ is offline   Reply With Quote
Old 11-18-2009, 04:14 PM   #26038
ih8pepl73
The last three days, I changed my diff fluids, sandblasted the diff covers and painted them, painted my disconnects (I hate my discos), and installed an HD radio that was in my wife's car...
Originally Posted by The_TwStD_1 View Post
Procrastination's a lot like masturbation. It's all fun and games until you realize you're only screwing yourself.
Originally Posted by ih8pepl View Post
Jeeps are one vehicle that should never have anything stamped with "Made in China" attached to it!
Definitely a 2004½ Unlimited.
ih8pepl73 is offline   Reply With Quote
Old 11-18-2009, 04:30 PM   #26039
SeaSick
Picked up my tube fenders from being powder coated, came out awesome. One step closer to putting them on, hopefully this weekend.
2000 Green Sahara
4.0L |32RH | Lift | 35`s | Skids |
My Jeep
Rausch Creek 10/17/09
SeaSick is offline   Reply With Quote
Old 11-18-2009, 04:34 PM   #26040
Jeepball
^^^^wow that is some crazy paint! looks awesome bro!
[B]HUMMER RECOVERY TEAM[/B]
Low Output 4 Cylinder Jeep Club member #173
[URL="http://www.cardomain.com/ride/3047000"]http://www.cardomain.com/ride/3047000[/URL]
[url]http://fuh2.com/[/url]
Jeepball is offline   Reply With Quote
modifications, tj
Glock Forum
