#24526 | |
powerwashed the entire inside of the jeep to get all the clay out in anticipation of hard top weather...booo
2000 Sahara TJ 1997 Limited ZJ |
#24527 |
ethan, make one for me too!
Shake & Bake with SHAKEnBLAKE - "Build Thread" www.ohio4x4.com 98 pile o' parts: 4.0L, 3spd auto, 4", 35" KM2s, XRC8, 4.10s, MCE flatties, KOZ cage
#24528 |
" Volkswagen "
Spent money on it...... Currie HD steering and new Spicer ball joints are on their way! Hopefully the slight steering wheel shimmy will be gone.
Jeep build up...ONGOING Jeep build up...ONGOING R.I.P. Tow Pig Dually build Rear bumper/spare tire carrier build Track bar bracket fabrication AtoZ cage install/build NeetoCJ was a generous guy and renewed my membership..... Blame him for your troubles! |
#24529 |
I'll start taking orders as soon as I complete mine and test it out.....
ET48 1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs. 1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s. |
#24530 |
not today but the other day i rolled on some truck bed liner on my rockers
./l ,[___], l---L – ()lllllll()- ()_) ()_)--o-)_) Black Jeep Society member Eagle Scout Jeeper #1 http://www.facebook.com/home.php#/profile.php?id=1587300482&ref=profile Mecklenburg Mudders Vice President |
#24531 |
I ordered my rear driveshaft and got the pieces to rebuild the front cardan joint.
#24532 | |
Purveyor of Funk
Well, today I finally got around to (rather sloppily) cutting up the ashtray blank in the center dash bezel to install the rocker switches that came with my Eaton E-Lockers. Left is front, right is rear. First time using a dremel, if you can believe that. I think next time I'll take my time and do it precisely right. Ah well, I'm a perfectionist sometimes.
For the requisite pics, here's a shot of them off, with the ugly flash making everything look crappy, and then a shot with them on, no flash, looking much cooler. PS Yes, they work great. ![]() ![]() Quote:
#24533 |
painted my brackets for my tail gate drop down kit
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER] |
#24534 |
~2006 TJ SE 2.4L~ ~3" BDS lift, BDS Trackbar~ ~LoD Heavy Duty Tire Bumper/Carrier~ ~LoD Heavy Duty 44" Front Bumper~ ~33/12.5/15 trXus STS Radial, 15X8 Pro Comp Series 8179's~ |
#24535 |
Canadian for life... eh!
Ground down the welds and removed the the engine mounts, then heated them up and bent them back into place then welded them back into place. Bent the brackets for the control arm and track bar back in place on both axles and welded them to be much stronger, removed the dented oil pan, removed the damaged drive shaft, replaced the front yoke, replaced power steering reservoir, removed fender, bent the transfer case bracket back into place, ordered new e-brake tensioner and my stock replacement parts arrived by Fed Ex today. . . WOOHOO
BTW I'm rebuilding a wrecked '05 unlimited. |
#24536 |
That's one heck of a busy morning! All I was able to do was take the side steps off in anticipation of the Body Armor coming this week.
#24537 |
Put on Some new Teraflex 9550 Shocks and put my KM2's back on.
#24538 |
Ordered new parking and side marker lights. Took off the old rusted out steps that were on it. Started looking in to painting the fender flares black.
#24539 |
That was in the last 24 hours, so technically one day, plus I gave the wife's car an oil change and installed new end links on a friends car and played some ice hockey. Busy day off work.
A rebuilt '05 Unlimited w/ 6 spd, 4.0, 3" BDS springs, front locker, warn front bumper, PS corners, rock sliders and the list goes on and on. Former Jeeps: 79 CJ7, 81 CJ7 Renegade, 85 CJ7 and a 95 YJ. Project car: Big Block 4spd 69 mach 1 (it's back on the rotisserie for the final time). Indyorv.com |
#24540 |
Purveyor of Funk
Used it to jump start my '07 F250 PSD. Surprisingly, it worked. Turns out there's nothing a Jeep can't do.
| Tags |
| modifications, tj |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
