What did you do to your TJ today? - Page 1503 - JeepForum.com
 685Likes
post #22531 of 113135 Old 08-15-2009, 11:41 PM
djfuzzy
Went wheelin with a few buddies and some other guys with FJ's and monster JK's.
Almost flipped my TJ.
(Freeze frame from a video...sorry about the quality.
USMC 2006-Present
2000 TJ - some stuff
djfuzzy is offline
post #22532 of 113135 Old 08-15-2009, 11:49 PM
Tecks
^looks hella fun, you put the video on youtube or anything?
Tecks is offline
post #22533 of 113135 Old 08-15-2009, 11:50 PM
jdub64
Swapped worn out 35 MTs for 33x12.5 Goodyear Duratrac ATs - got more power available and incredibly smoother/quieter. Haven't been off the pavement yet but I'm liking the results for daily driving.
jdub64 is offline
post #22534 of 113135 Old 08-15-2009, 11:57 PM
jdub64
oh, and don't need to re-gear now with the smaller tires!
jdub64 is offline
post #22535 of 113135 Old 08-16-2009, 12:02 AM
GREASEMONKEY
I stood and stared at her as I procrastinated starting the job of regearing, and new axles!
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
GREASEMONKEY is offline
post #22536 of 113135 Old 08-16-2009, 03:56 AM
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
speaking of regearing...
I spent a large portion of tonight at work reading through regearing threads. I need to get 5th gear back and I want to be able to crawl on the trails when I take it offroad, so this is going to be attempted as soon as I can afford it. I have NO clue how much it will cost though
koolaid5 is offline
post #22537 of 113135 Old 08-16-2009, 07:50 AM
pierceandrew
has anyone ever made their own deck cover fron an old soft top
pierceandrew is offline
post #22538 of 113135 Old 08-16-2009, 07:54 AM
rikkards
rikkards's Avatar
Changed the oil on the KJ (for the first time) and got burnt on the exhaust. Much less cramped doing the TJ. Course it has a lift which helps.
On a lark, tried the blower on the TJ and it worked fine. WTF? Yesterday when I went in it wasn't working at all.
Originally Posted by rikkards View Post
Changed the oil, the KJ gets it tomorrow as well. Then started looking at the lack of heater blower. Pretty much all settings don't work.
I went through the FSM and the following is true:
1. Connectivity in the switch works
2. The relay works when putting power across it (tested it with a 9v battery)
3. Connectivity on the blower resistor is there but I think it is on its last legs.
I am planning on replacing the resistor but the blower is intermittent. After I fiddled with it all, all of a sudden it started working. Turned off the engine and then restarted and then it didn't. Although when it was working, the lowest speed was pretty much nonexistant.
Any ideas?
Machete don't tweet
- Machete
rikkards is offline
post #22539 of 113135 Old 08-16-2009, 08:25 AM
EvilM0nkey
EvilM0nkey's Avatar
Either the blower motor is bad or the resister went bad. Sounds like you have a blower motor issue. Try connecting 12V to it and see if it runs.
EvilM0nkey is offline
post #22540 of 113135 Old 08-16-2009, 10:12 AM
TJJEEPER
TJJEEPER's Avatar
Originally Posted by JBWood05TJ View Post
I installed an ARB compressor and ran the harness in the engine bay. In cab wiring and airlines tomorrow. Man I hate doing (read: suck at) the electrical stuff...
Installed mine a couple of weeks ago, not near as much trouble as I expected. I'm not sure about the 05's but on my 97, I just drilled a hole in an existing rubber plug in the firewall right behind the motor, used one of the switch blanks already on the dash for the switch, and hooked the power wire to the hot cigarette lighter wire, and the light wire to the heater control light with the splice that came with the ARB kit.
JEEP, Not Just a Vehicle. A WAY
97 TJ, 4.0, 5sp, OME Susp., 1 3/4 coil spacers, 1" BL, 35" Xterrains, Dynatrac Trail 60 with ARB, D30F, 4.56's, LockRite F, Discs F&R, K&N, Borla Header, Flowmaster Super 44 Off-Road Muffler, Front LineLock, Diehard Platinum P-1...
06 Commander
TJJEEPER is offline
post #22541 of 113135 Old 08-16-2009, 10:20 AM
rikkards
rikkards's Avatar
I don't think it is the motor as it was running fine this morning. Last night when I went in after trying to figure it out, it wasn't working , no air blowing at all. This morning I went out and tried again and it was working flawlessly. Turned it on and off and no change. However I would like to see if I hook it up to the battery directly what happens. I have a feeling it may be a combo of the relay and the resistor are getting flakey. Either that or there is an intermittent connection. Question is, without pulling the whole dash apart, where is the connector that directly connects to the blower motor?
Edit: Read the FSM and found the steps needed (p34 in the HVAC section). Looks relatively simple.
Machete don't tweet
- Machete
rikkards is offline
post #22542 of 113135 Old 08-16-2009, 10:59 AM
jim_bert
Said goodbye to the hard top...looks like I'm going soft top year round...
2001 Yellow Sport, I6, Dana 44 3.73 gears, 31x10.5 procomp AT on cragar soft 8s, silverstar headlights, black headlight bezels, raingler full netting system, raingler roll bar handles, EK motorsport maglite holder, Tuffy door lockers, Tuffy glovebox, stepshield door entry guards, 130w Halogen KC Daylighters on windhield mounts, kenwood kvt-819dvd, 5.25" front speaker conversion, door switch defeat, U-Pol Raptor liner, Dynomax Super Turbo Cat-Back Exhaust, Iggee seat covers, SAVVY LED Taillights.
jim_bert is offline
post #22543 of 113135 Old 08-16-2009, 11:18 AM
jeeptrash
Hit 50k in the LJ yesterday! Yes i was driving at the time, no i didnt take the picture
jeeptrash is offline
post #22544 of 113135 Old 08-16-2009, 12:02 PM
hydroman19
First mod! Popped out the links and put in some JKS disconnects..... after 3+ hours with the tie rod end puller + pickle fork
GO BIG RED
hydroman19 is offline
post #22545 of 113135 Old 08-16-2009, 12:39 PM
Kenbo-Slice
Today wasn't a day for MY Jeep, instead we did work on my buddys. New front brakes, took off the front flares, and added a touch to his rocker guards. NEXT WEEK my brakes get done... EBS drilled/slotted rotors, Yellowstuff pads, and extended stainless brake lines.
Here are a couple pics when we finished.
Jeep build up...ONGOING
Kenbo-Slice is offline
modifications , tj
