What did you do to your TJ today? - Page 1490 - JeepForum.com
 1024Likes
post #22336 of 113792 Old 08-08-2009, 08:58 PM
GzrGlide
GzrGlide's Avatar
Cut the stock fenders off to start fabbing the new tube fenders.
Mike
<<< ya know ya want to!
98 TJ SE
RE 4.5SF with 3.5 springs & Tera QDFTs
Super 35 & Detroit in back w/4.88s
33x10.5 BFG KM2's
Cobra 75WXST w/4' Wilson Antenna
Warn M8000
(1) Rubber Ducky
GzrGlide is offline
post #22337 of 113792 Old 08-08-2009, 10:26 PM
mudking_ky87
i went to evansville, in and picked up a warn x8000i winch, 2 warn D-ring shackles, and a warn receiver tow shackle, and 2 more good tow straps. I know it isn't spooled correctly right now, the guy i bought it from broke his synthetic and put the steel cable on without it being on the jeep and I am going to re-spool it tomorrow!
mudking_ky87 is offline
post #22338 of 113792 Old 08-08-2009, 10:41 PM
atxzj
Fabbed up my upper frame bracket
Old stretch thread:
New stretch thread: http://www.rockymountainextreme.com/showthread.php?t=48591
atxzj is offline
post #22339 of 113792 Old 08-09-2009, 07:39 AM
80 CHOPPER
Installed my SAVVY gas tank skid.
DRAGON
80 CHOPPER is offline
post #22340 of 113792 Old 08-09-2009, 08:24 AM
ET48
Well, I haven't done much to the TJ lately. Haven't even drove it for almost 2 weeks now. I did paint the CJ though....(Pics in build thread)
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #22341 of 113792 Old 08-09-2009, 12:53 PM
dadstjaz
Installed 2" BB and Procomp shocks today so the 33's can roll. Still need to put spacers up front for full turn clearance. Cheapest way to go.
dadstjaz is offline
post #22342 of 113792 Old 08-09-2009, 01:08 PM
prd_cdn
prd_cdn's Avatar
Bought some 1/2 in NF Rod, some 1/2 in Rod Ends, Had my Sway Bar re-painted, changed the Oil and Air Filter, Thought the lower rad hose was leaking ~ drained and checked.. nothing! New Rad Cap though!
Super exciting @@!!
prd_cdn is offline
post #22343 of 113792 Old 08-09-2009, 01:23 PM
stogie25
stogie25's Avatar
After my little rescue adventure posted in Jeep Registry I had to fix my front axle. Both outer shafts were sheared off near the outer splines where the manual hub mounts. I got my new ones, and spent the day installing them. It also gave me the opportunity to change out u-joints, bearings and brake pads. It is good to have four wheel drive again.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #22344 of 113792 Old 08-09-2009, 05:19 PM
Yardman Harry
O
Yardman Harry's Avatar
Removed the mirror brackets, wire brushed them down, and slapped a coat of primer and black paint on them... they look sharp now
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #22345 of 113792 Old 08-09-2009, 05:46 PM
_TIM_
Cut up my front bumper into a stubby
1998 tj|chili pepper red|
_TIM_ is offline
post #22346 of 113792 Old 08-09-2009, 05:52 PM
Kenbo-Slice
Pics or it didn't happen Tim!
Today I ordered some EBC Yellowstuff pads, and slotted EBC rotors, along with some 6" over stock stainless brake lines. I hear that brakes are pretty important important, so I figured I should replace the **** that I have. I also never realized how insignificant the stock brake lines are now that I have discos, and all the flex.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #22347 of 113792 Old 08-09-2009, 06:18 PM
Ruckuss19
Installed 2" RE BB and 32x11.50x15 Kumho A/T's w/cragar steelies
Ruckuss19 is offline
post #22348 of 113792 Old 08-09-2009, 06:39 PM
PurpleTJ
re-painted my chipping mirrors! they look much better now.
Purple Jeep Club member #8
PurpleTJ is offline
post #22349 of 113792 Old 08-09-2009, 07:20 PM
JeSimmers
JeSimmers's Avatar
Diff fluid change and new steering stabalizer installed
Red Jeep Club Member #454
JeSimmers is offline
post #22350 of 113792 Old 08-09-2009, 07:34 PM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
Yanked the axles in preparation for the install of some D60s.
We save dogs:
JBWood05TJ is offline
modifications , tj
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
Greyhound06 , Marleyx1981x , Shiffty1
