What did you do to your TJ today? - Page 1451 - JeepForum.com
 536Likes
post #21751 of 112596 Old 07-19-2009, 07:17 PM
ET48
Took my front shock boots off. Freed up my tailgate hinges with WD-40.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #21752 of 112596 Old 07-19-2009, 07:45 PM
unsung
unsung's Avatar
I removed the Warn front bumper off my 06 Rubicon and replaced it with a Rokmen Merc. I have a Rokmen on my 97 as well, but I must say this one was a pain to get lined up right. The first went on with no issues, I had to beat this one on.
unsung is offline
post #21753 of 112596 Old 07-19-2009, 08:04 PM
bill adams
replaced my ac/heater blower motor resitor.
took about an hour after i found where it was.
have all four fan speeds now.
bill adams is offline
post #21754 of 112596 Old 07-19-2009, 08:07 PM
bddisi
Washed and cleaned the jeep, after last weekends Windrock trip.
Scorpion-Offroad-Concepts
bddisi is offline
post #21755 of 112596 Old 07-19-2009, 08:13 PM
bill adams
replaced my ac/heated blower motor resitor.
post #21756 of 112596 Old 07-19-2009, 08:26 PM
_TIM_
lets see.....
yesterday i finished my hi-lift jack hood mount and mounted my new hi-lift
today i changed my dif fluid and had a question......
why would there be a small gouge in the inside if my dif cover? everything was tight and looked to be in great shape so i don't think there is anything wrong with the axle. i was just a little curious about how that could happen
2nd question....i want to put a new muffler on the jeep and am looking into the flowmaster 40. the only one i've been able to find locally has a 2.5 in inlet and i was wondering if there was a way i could make it work? the only reason i ask is b/c i don't really feel like ordering one i just want to kind of pop it on....if it wont work, no big deal i was just curious so i figured id ask
1998 tj|chili pepper red|
_TIM_ is offline
post #21757 of 112596 Old 07-19-2009, 08:30 PM
fsSnowboard
installed my RE 3.5" lift over the weekend. Still not quite done.
fsSnowboard is offline
post #21758 of 112596 Old 07-19-2009, 08:38 PM
LesterM
Adjusted my steering stops so my 31's will stop rubbing. $0.35, great mod.
2000 Wrangler.
LesterM is offline
post #21759 of 112596 Old 07-19-2009, 10:15 PM
Xaos88
Got my arb compressor mounted and switches cut in to mount just ahead of my auto transmission shifter, looks like its going to be a good location and haven't seen any others mounted there. A little tricky to work around two cables running to the shifter but should be all good.
Then I finished stripping out the interior and sanded everything down and washed down again. Tomorrow I'm taping things off, wiping down again and waiting for the UPS truck to drop off my upol rapter and its spray time!
Xaos88 is offline
post #21760 of 112596 Old 07-19-2009, 11:02 PM
SHAKEnBLAKE
rinsed, washed, clay barred, rubbed, waxed, photoshoot.
Ohio4x4.com
SHAKEnBLAKE is offline
post #21761 of 112596 Old 07-19-2009, 11:44 PM
flexsaharatj
installed the 33s with american racing rims!!
flexsaharatj is offline
post #21762 of 112596 Old 07-19-2009, 11:46 PM
Apex
Recon death squad
Apex's Avatar
Blake, when did you sell your Jeep and get a new one
Holy **** does that look nice.
Apex is offline
post #21763 of 112596 Old 07-20-2009, 12:03 AM
Streetskirt
Busy jeep day-
Gave her a bath inside and out
Changed the diff fluid, transmission fluid, and transfer case fluid. Should have done the transmission fluid 20,000 miles ago when it was new, went with the Pennzoil Syncromesh and it seriously has never driven better.
Re did my alignment using the angle iron/barstock method, and it is driving much better, hopefully this fixes my death wobble problem since I put on the lift.
Did the roll bar High-lift mount with muffler clamps.
Justin
Streetskirt is offline
post #21764 of 112596 Old 07-20-2009, 12:17 AM
Dirtrider5490
Well today I knocked the honey comb out of the cat cause it was rattling (no check engine light yet!) then welded a 40 series Flow master directly to it with a 4 turn down out of it. It honestly is too loud and not a good sound being only a 2.5L. But this weekend i put Hella 500FF on, BDS 1 3/4 coil spacers on front cause the RC 2.5" 4cyl kit was sagging, Mounts to move my fog lamps to A-pillar, and a sweet sticker for Tarheel 4wd Center, Charlotte NC, since he flipped a tire and patched another one for me for free (honestly a great shop/store and guy).
Dirtrider5490 is offline
post #21765 of 112596 Old 07-20-2009, 12:19 AM
Dirtrider5490
Originally Posted by Streetskirt View Post
Busy jeep day-
I put a 2.5" on my and had death wobble. A cheap easy fix is to get a pitman arm off a ZJ its like a 1.5 longer drop and cures it. Even took some bumper steer out.
modifications , tj
