What did you do to your TJ today? - Page 1448 - JeepForum.com
 1219Likes
post #21706 of 114033 Old 07-18-2009, 01:40 PM
ActionJackson00
Originally Posted by Mini-Me26 View Post
Drove it, heard a clunk when turning the wheel (I suspect the TB bolt at the axle) and discovered 2nd is near impossible to get into. And killed a large daddy-long-legs spider that hitched a ride home with me from the trails. Harmless things, but ugly looking. Like Striders.
play a little HL2 i see...
it was sick to fight the striders in Ep 2
ActionJackson00 is offline
post #21707 of 114033 Old 07-18-2009, 03:00 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
thurs, installed my Hyline hood louver http://www.jeepforum.com/forum/f9/hyline-offroad-louvered-hood-panel-write-up-review-819438/
today, found out someone tried to steal my radio, all they got was the face plate
RnEmOvr is offline
post #21708 of 114033 Old 07-18-2009, 03:00 PM
Kinless
Not all done today but in the course of the last few weeks I have made some changes.
The way I bought it.
After my changes. Painted Hardtop, Rokmen Tummy, Engine, Fuel, Steering Box Skids. Rokmen rear lower adjustable control arms, Rokmen front bumper. Warn HS9500i, JKS 1.25" Body Lift, 1" Motormount lift
Kinless is offline
post #21709 of 114033 Old 07-18-2009, 03:08 PM
LGriffith
Found some melted fuel lines. Now I can't fill up without the handle clicking off every 2 seconds.
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith is offline
post #21710 of 114033 Old 07-18-2009, 03:16 PM
gseale
Finally received the tire carrier for my LoD bumper (14 weeks later ). Decided to mount my Hi-Lift on the tire carrier for now. Did not fit too well, as the bolt behind the wheel mount was not long enough to fit through the bar. Made a trip to Home Depot for a longer bolt, and got a butterfly nut. Still need to find a butterfly nut for the top bolt, as it's standard and they only had metric sizes in stock
Greg
~2006 TJ SE 2.4L~
~3" BDS lift, BDS Trackbar~
~LoD Heavy Duty Tire Bumper/Carrier~
~LoD Heavy Duty 44" Front Bumper~
~33/12.5/15 trXus STS Radial, 15X8 Pro Comp Series 8179's~
gseale is offline
post #21711 of 114033 Old 07-18-2009, 03:18 PM
bigj1974
bigj1974's Avatar
had the front driveshaft rebuilt.
bigj1974 is offline
post #21712 of 114033 Old 07-18-2009, 05:09 PM
jutgin
Rhino lined the chrome stepsides
Justin
2013 Wrangler Sport
Chattanooga, TN
jutgin is offline
post #21713 of 114033 Old 07-18-2009, 05:24 PM
Niceface
^^^ I like that look. Might do that with mine. Did you have to sand them down a lot, or does the liner stick to the crome?
Changed both axle diff's fluids. Checked all fluids and greased everythingn up.
Also fixed my t-case shifter linkage. Hopefully for the last time. Ready for the next 4wd trip!!!
Niceface is offline
post #21714 of 114033 Old 07-18-2009, 05:37 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I looked at it, came close to starting to drain both of the axles and transfer case to see what's making all the racket, then noticed my garage was already 99 degrees late morning and I was sweating profusely after being in it all of ten seconds. I went out to the pool instead.
Jerry Bransford is online now
post #21715 of 114033 Old 07-18-2009, 05:39 PM
ItsaFinRubicon
I got some rustolium high heat spray paint and painted my tail pipe. came out pretty good lol
|R.C. 4"|PSC|Smittybilt|35" KM1|QTec|R.C.|
Originally Posted by Dtowngoalie View Post
rausch frock rauschhhhhhhhhhhh
Originally Posted by ajamison View Post
trails frock trailssssss!
ItsaFinRubicon is offline
post #21716 of 114033 Old 07-18-2009, 05:45 PM
Lynch_6913
bought it... my 3rd jeep... 97 wrangler tj sahara fully loaded both tops i believe the d 44 rear and all for 4500 which is good up here in mn
Lynch_6913 is offline
post #21717 of 114033 Old 07-18-2009, 05:54 PM
Slithering_Joe
Wired in the Hella Supertone Horns to the alarm system. Loud.
4.0L TJ
Slithering_Joe is offline
post #21718 of 114033 Old 07-18-2009, 05:59 PM
jutgin
You know I dont know! I hope it will stick, it does at first ofcourse and seems like it will hold. I wouldnt trust regular paint but this rubberized stuff seems ok.
I didnt sand at all just cleaned really well then primed it.
Justin
2013 Wrangler Sport
Chattanooga, TN
jutgin is offline
post #21719 of 114033 Old 07-18-2009, 06:16 PM
gaTJgal
Today: replaced my spark plugs (1st time for me every doing that myself) and cleaned the air filter (K&N..also another 'genius' install by the PO--why couldn't he of invested all that money in a good lift for me?).
Tomorrow: oil change, thottle body cleaning, maybe removing the throttle body spacer installed by PO, cleaning the engine bay (shoulda done that first......)
gaTJgal is offline
post #21720 of 114033 Old 07-18-2009, 06:24 PM
SeaSick
Finished painting my front bumper and got it on. Put in my PSC steering box and also put in some Hella horns.
2000 Green Sahara
4.0L |32RH | Lift | 35`s | Skids |
SeaSick is offline
modifications , tj
Currently Active Users Viewing This Thread: 18 (9 members and 9 guests)
blubaru2002 , churchofjt , grogie , moemuledeer , Momamac , oscartj , Rougarou , schnelleee , toximus
