What did you do to your TJ today? - Page 14 - JeepForum.com
 563Likes
post #196 of 112798 Old 02-10-2006, 02:32 PM
jonwood
Yesterday I bought some more parts for it and stretched the winch cable and todat I re-installed the CB antenna and worked on a friends to get it ready for saturday run
03 Rubicon on 36's and LONGFIELD CV's
jonwood is offline
post #197 of 112798 Old 02-10-2006, 02:55 PM
quitelifted
quitelifted's Avatar
Changed the pre cat o2 sensor. Reset the check pockets light. went to work and the check pockets light came back on. Prob. the other o2 sensor. only $75 more bucks.
Shopped arourd for an 8.8
quitelifted is offline
post #198 of 112798 Old 02-10-2006, 02:55 PM
UK 4X4
Ordered the RE3.5" lift and wasted the afternoon at work designing my storage
draws for the back of the jeep.......seat out...250mm high new floor with 3 drawers
underneath and ice box fitted in and a nice flat surface for the dog !!!!
He already has a harness and seat belt.....now thinking of his own roll bars he can stand inbetween to lessen the momentum.....
UK 4X4 is offline
post #199 of 112798 Old 02-10-2006, 03:51 PM
Peccavi18
In the last 24 hours I wired up my winch, lubbed up the door latches and hindges, Scraped stickers off and cleaned up slopped DuraBack, (which I might add is junk I can scrap it off with a credit card) and no I didn't put it on, I bought it that way. Next is a pressure wash followed by some wiring for Hella 500's
Peccavi18 is offline
post #200 of 112798 Old 02-10-2006, 06:04 PM
Xtoyaddict
I just ordered my lift, should be in next week and on that weekend. Here is what I ordered.....
1 x TJ 4.5" Super Flex Kit + DT3000 Shocks (RE7000) = $2,178.75
Year of Vehicle 03+ TJ
Options Adj. Front Lower Control Arms
Options Adj. Rear Lower Control Arms
Options Extended Rear Brake Line
Options NP231 AA HD SYE + TW CV Shaft
Options Bolt-On Rear Shock Relocators
Options OME Nitrocharger Shocks
Xtoyaddict is offline
post #201 of 112798 Old 02-10-2006, 06:06 PM
BEANS
BEANS's Avatar
I adjusted the transfer case shifter linkage for the snow thats coming!!
2001 SPORT 4.0 AUTO EMPTY GAS TANK
2 1/2"O.M.E. 1"Body LIFT
33" DUNLAP'S
JSK QUICK DISCONNECTS THAT I'LL NEVER DISCONNECT
LIMITED SLIP WITH 4.11'S FRONT AND BACK
S.Y.E
7'6" SNOWAY POLY PLOW
Elect Radiator fan on a Delta control
Borla Header, Catback Exhaust By Volant 304SS
BEANS is offline
post #202 of 112798 Old 02-10-2006, 06:41 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
Originally Posted by RedRubiconLJ
re-did my winch line for BigWaylon...
And me...I didnt like it either....
looks good!!!
Originally Posted by BigWaylon
pulled the gas tank out today...installed a fuel cell in the tub...clearing room for the stretch in the next couple months...
also had a couple more bars added to the rear of the cage...
Greg
figure I'd add a couple pics...
first, the cell:
it wasn't completely done in that pic...but it was close...just another blue AN cap where the red plastic cap is, plus we found the missing connector and removed the temporary hose clamp off the hose going to the pump, and also cable-tied it all down...
and the two new rear bars (already had the rear cross bar and the two lower diagonal bars...the new ones come from the front spreaders to the rear corners):
sorry for the bad angle...kept taking them by hold the camera up and out, and that was the best of the bunch...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #203 of 112798 Old 02-11-2006, 02:02 PM
jungleplant
jungleplant's Avatar
just put 8x15 with 33x12.5 with 4.3/4 backspace on the tj and now they only stick out 1/2 inch , very happey
jungleplant is offline
post #204 of 112798 Old 02-11-2006, 02:23 PM
TexanTJ
2014 JK Wrangler
I just ordered some OME HD springs from swiss mountain 4x4. Now ill just patiently wait.
2014 JKU Sport - Wife's Mall Crawler on 35s. Badlands Winch, 2" Coil Spacers, 1" PA BL
1999 F250 7.3 - 290K Miles and Counting
"I am not going to censor myself to comfort your ignorance."
TexanTJ is offline
post #205 of 112798 Old 02-11-2006, 03:03 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Put some Hella 500s on the front bumper today.
I'll be Savvy someday!
neZZr is offline
post #206 of 112798 Old 02-11-2006, 03:22 PM
tommaho
tommaho's Avatar
Put YJ brake hoses on the front, re-cut & welded the rear track bar rotating the axle end forward so it doesn't bind so bad in the RE CV bracket. The rear was riding hard before because of the bind and first impressions are that it's better now. It still seems rougher than before, but the only other thing I did was invert the shocks (they're DT3000s).
Oh, and I picked up three cheapo recovery straps (no hooks) from one of those gypsy tools shows: 2 3"x10' 20k lb straps for 10$ ea. and a 3"x50' 20k lb for $50. I'd rather have a 20' or 30' instead of the 50', but it's all they had. They're cheap and blah blah blah, but they're better than nothing.
Tom
[edit: these are recovery, not tow straps ]
tommaho is offline
post #207 of 112798 Old 02-11-2006, 04:47 PM
KY TJ
KY TJ's Avatar
All I did was drive mine 50 yards to the gas station on the corner for a pack of smokes.
-Matt
99' 4banger 102" WB 36" IROKs
KY TJ is offline
post #208 of 112798 Old 02-11-2006, 05:49 PM
Roothog
All I did was put the top down and go for a ride up the coast in beautiful 75 degree sunshine. Too bad a cold front is on the way:
'02 Black 4.0L 5 speed
3.5 RE adj front track bar and rear adj control arms
33x12.50x15 Nitto AT Terra Grapplers 15x10 Ion Wheels
Warn bumpers & tire carrier 3. 07 gear member #666
SYE/CV driveshaft
Roothog is offline
post #209 of 112798 Old 02-11-2006, 06:01 PM
jungleplant
sweet, and more to come
post #210 of 112798 Old 02-11-2006, 06:42 PM
Flatbroke
installed beadlocks with tires.
Yellow 02 Sport
Originally Posted by XRussoX
Haha
I actually look at a Jeepers nuts to see how informed they are. Ditch your nuts man!
Russo
Flatbroke is offline
modifications , tj
