What did you do to your TJ today? - Page 1352 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 06-04-2009, 02:01 PM   #20266
RyanEck
wash and wax....also had to do the wife's van. tried to find my vacuum leak, to no avail.
RyanEck is offline   Reply With Quote
Unread 06-04-2009, 02:24 PM   #20267
TXJeepster777
New bushings, springs, brakes, and last but not least... front and back ujoints lol
TXJeepster777 is offline   Reply With Quote
Unread 06-04-2009, 02:51 PM   #20268
johnny9
Originally Posted by lescobarz View Post
i did that fog light conversion and it work out pertty good, i also did that light when the door opens, i didn't have a paper clip so i cut off the end of the fishing hook, and worked perfect, then for a little extra i sanded the hook down and painted to match my jeep, yellow.
what thing with the light when the door opens??
i have a bad drivers side door button that makes my interior lights come on sometimes while driveing..just wondering if thats the same problem you had and how to fix it,thanks,john
johnny9 is offline   Reply With Quote
Unread 06-04-2009, 02:57 PM   #20269
97tjgunner
i took my roof rack off
97 TJ SE 2.5 inch lift 32 inch bfg ats---Gone
98 Cherokee sport stock for now
97tjgunner is offline   Reply With Quote
Unread 06-04-2009, 03:00 PM   #20270
cadencedad
pull the fuse it takes 3 seconds best mod ever
cadencedad is offline   Reply With Quote
Unread 06-04-2009, 03:22 PM   #20271
lescobarz
that button that turns on the lights on the sound bar, the door opens and it activates the lights on, so i drilled a hole while pushing the button in, and just put a small pin through it and lights stay off, or you can also pull the fuse, its the number 4 fuse inside the golve box forme
l33v1
http://s118.photobucket.com/albums/o103/lescobarz/
lescobarz is offline   Reply With Quote
Unread 06-04-2009, 03:43 PM   #20272
minges14
Installed my home-made light bar this afternoon.
minges14 is offline   Reply With Quote
Unread 06-04-2009, 03:46 PM   #20273
coreycoles
2010 JK Wrangler
i upgraded my deck and all five speakers in my tj.
coreycoles is offline   Reply With Quote
Unread 06-04-2009, 03:48 PM   #20274
johnny9
i dont wanna get rid of my interior light that works with the door,just want it to work right,haha..i will just buy a new button switch if i can find one..havent checked the local parts place as i figure its a dealer item on..its poor qaulity on the original buttons..passenger side still workin tho,john
Unread 06-04-2009, 03:53 PM   #20275
nsmerilli
Hows that look from the side and with the top off ?
nsmerilli is offline   Reply With Quote
Unread 06-04-2009, 03:54 PM   #20276
johnny9
i still want them to work right tho,haha..i will just have to get a new switch from the dealer..i was thinking someone had the same problem and fixed it easy..i think i just need a switch,thanks,john
Unread 06-04-2009, 04:37 PM   #20277
JohnnyCobra
Rusty's 2" BB with shocks, EBC Yellow stuff, and Brembo Rotors - yeah, pretty much stock still....SLOWLY building:
JohnnyCobra is offline   Reply With Quote
Unread 06-04-2009, 05:53 PM   #20278
flatlander757
Originally Posted by My_Heep View Post
Welds shrink when they solidify which causes the part to pull towards the weld. The best way to counter this is to add a few good tacks on one side while holding the part from twisting, double checking that the part is straight, then welding the other side. The tacks will keep the part from twisting
It wasn't just pulling the metal to one side or the other, it was physically bending on the flat part of the "T" joint(the plate that everything is mounted on).
I have been clamping my stuff down when possible(as was suggested) but still warps to some extent, though not as bad.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote
Unread 06-04-2009, 06:04 PM   #20279
wolfen
How hot are you running the welder?, You might be able to cool down a notch or two on yours and still get a quality weld, also if its warping try going about an inch and takeing a short break, thats what we do at work on thin metal, also leaveing it clamped down till its cooled down helps sometimes
gone somewhere else
wolfen is offline   Reply With Quote
Unread 06-04-2009, 06:06 PM   #20280
JstAnthrTJ
Nothing other than drive it. But hopefully my parts will come tomorrow!!!!
JstAnthrTJ is offline   Reply With Quote
modifications , tj
