What did you do to your TJ today? - Page 114 - JeepForum.com
 1227Likes
post #1696 of 114048 Old 07-03-2006, 06:12 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Originally Posted by jcd
I finally pulled out the box of Rollbar Rapz I've had on the shelf for a month, cut them to fit around the Rock Hard cage and installed them in place of the factory covers on the over the door bars.
They aren't a perfect match to the factory covers on the rest of the cage, but unless you get your face up in them to compare, they look spot on... easy install and at just $23, how can you go wrong?
For $23, how much of the cage were you able to cover?
I'll be Savvy someday!
neZZr is offline
post #1697 of 114048 Old 07-03-2006, 06:14 PM
Negative6
do you have any pictures?
97 TJ Green 4.0 Sport
2" Skyjacker, 33" BFG MTs, LOD tire carrier
Negative6 is offline
post #1698 of 114048 Old 07-03-2006, 06:20 PM
jcd
jcd's Avatar
I just needed to do the two bars between the windshield frame and the main hoop as the factory padding was looking pretty rough around the Rock Hard cage - I had to zip tie them together as a temporary fix
2008 Jeep Sahara Unlimited
Terraflex 4" 35's 5.13
jcd is offline
post #1699 of 114048 Old 07-03-2006, 06:40 PM
frumpy
frumpy's Avatar
got her nice and mudy
frumpy is offline
post #1700 of 114048 Old 07-03-2006, 06:47 PM
jcd
jcd's Avatar
Here's a couple of snapshots showing the Rapz in place. Since the stock padding is so fitted, the stretchy neoprene Rapz made the install really easy - just cut to length and then cut notches for the bars. I'm definitely happy with how it turned out as having these two pieces custom made was starting to look expensive
The velcro on the inside sticks right to the the neoprene making it really easy to create a nice, clean seam that lays flat. I'm glad they did it this way rather than having to mate to another piece of velcro.
Here you can see the factory padding at left and the Rapz at right... not too bad looking and damn hard to tell the difference without looking close (like this).
jcd is offline
post #1701 of 114048 Old 07-03-2006, 11:54 PM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
So...where's the 'muddy' picture?
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #1702 of 114048 Old 07-03-2006, 11:55 PM
Steelman
Steelman's Avatar
Herculined the tub today!
Gotta put everything back together tomorrow...
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
post #1703 of 114048 Old 07-04-2006, 09:19 AM
TJZep
Along with my newly herc'd tub, I installed a trick pair of flush led taillights to complete my clean rear look!!
97 tj, 33's and a 4 inch lift, locked front and back, 4 banger and proud of it!
Low Output 4 Cylinder Jeep Club Member # 42
TJZep is offline
post #1704 of 114048 Old 07-04-2006, 11:36 AM
deebo
deebo's Avatar
Rokmen Mercanary bumper and Warn M9000.
deebo is offline
post #1705 of 114048 Old 07-04-2006, 12:48 PM
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
After my LED tail/turn/stop light mod my flashers were way too fast. Sounded much like a machine gun. Anyway, pulled that relay out from under the steering wheel and cut the appropriate curcuit and it was all golden then. Flasher working normal again. Thanks Stu, for the write up on that.
Airborne4X4 is offline
post #1706 of 114048 Old 07-04-2006, 02:54 PM
rockhi
rockhi's Avatar
put 2 washers behind bump stop...hey it was hot outside
2006 Rubicon unlimited--6 speed--4" Skyjacker lift- AR Wheels 16x8-MT Baja claw 33x12.50- Jeeperman Frt. & Rear Bumpers- -Rock Crusher Diff. covers X2 -Powertank CO2-
rockhi is offline
post #1707 of 114048 Old 07-04-2006, 03:50 PM
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
2013 MJ Comanche
carved up a plywood hard tonneau to serve as a prototype for an aluminum one. scratched up the roll cage while i did it though.
also switched out the factory bestop windjammer buckles and nylon with straps and side release buckles from strapworks.com .... now, i can leave the windjammer in the jeep, and when it rains, buckle it right up. takes seconds.
lj
ಠ_ಠ
LoneJeeper is offline
post #1708 of 114048 Old 07-04-2006, 04:12 PM
Frooch
Plugged a tire.
Frooch is offline
post #1709 of 114048 Old 07-04-2006, 05:06 PM
MT3Geiger
Cleaned the camping gear outta her today.
2005 Silver Rubicon, 6 speed, Dual Tops + bikini,
2" BB, 1" BL, 33x12.5x16 Boggers, Cobra 75, KC 130W slimlights, OR Fab Rock Doors, and some poison spyder diff guards
MT3Geiger is offline
post #1710 of 114048 Old 07-04-2006, 05:30 PM
BluesMan
BluesMan's Avatar
Washed the bugs off the window after spending yesterday at Hell's Canyon.
...Don't follow Chili Palmer into the trees...
BluesMan is offline
modifications , tj
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
blubaru2002
