What did you do to your TJ today? - Page 1056 - JeepForum.com
 1384Likes
post #15826 of 114282 Old 01-18-2009, 09:34 PM
jinx44
Found more shoddy work done by the previous builder...
Yesterday: I put new bolts in the bellypan after the others fell out friday night. I found some more bolts that hadn't been tightened. Took it out for a drive and had another bolt fall out of the front sway bar where the disconnects go into the tab on the axle. I also wired a MM wireless control into my Smitty XRC8 winch, and attempted to install SFW rockers but ran into an issue with my body mounts/lift.
Today: Finished the switch install for the ARB locker, put the rear seat cover on, pulled off a tire that needs repaired, then found the cause of a severe death wobble I encountered this weekend. The tie rod end hole had been sleeved (and not correctly either) and the weld holding the sleeve in place had broke.
jinx44 is offline
post #15827 of 114282 Old 01-18-2009, 10:46 PM
kjs tj
I threw the chains on it as it is sheer ice around my house.
As you can see they do a pretty good job of diggin in haha
04 Gold Jeep X
High School Jeeper Member #2
kjs tj is offline
post #15828 of 114282 Old 01-19-2009, 01:10 AM
Strizzy
I made a wire harness to go along with the IPF conversion headlamps and fatboy bulbs that I put in a few months ago. The difference is stunning. The OEM harness can't nearly supply the power needed to make these lights shine.
Strizzy is offline
post #15829 of 114282 Old 01-19-2009, 03:27 AM
USMCJarbee
Started removing my fenders for my new xrc tube fender install any halpfull hints to ease the install let me know
USMCJarbee is offline
post #15830 of 114282 Old 01-19-2009, 05:22 AM
rikkards
rikkards's Avatar
I mentioned that to my mom and she said that my dad that with a quilted blanket back in the 50's with a bugeye sprite. Then she started talking about how it was the only place they could go to make out when they were both in the air force before they were married. At that point I decided to turn my brain off and just answer yeah, uh huh.
Originally Posted by Chester405 View Post
the fleece actually helps. i havent really noticed a difference in road noise, but i have in how well the jeep keeps the heat in. before when i would turn the heat off, i would be cold again in about a minute. now the heat lingers a bit. ive also noticed that it is warmer when the sun shines on the jeep for a while.
rikkards is offline
post #15831 of 114282 Old 01-19-2009, 11:16 AM
BK2004LJ
friday nite and sat. I installed a BDS 3in lift. Sunday I installed the 33x10.5x15 bfg at's...LOOKS GREAT
BK2004LJ is offline
post #15832 of 114282 Old 01-19-2009, 11:20 AM
dabrogger
i trimmed and painted my stock fender flares, they look great! i pulled off all five of my m/t aluminum wheels, scuffed them, and painted them, they look great too. also touched up my bumpers. i used krylon fusion satin paint on everything so it matches good, looks great, and is easy to touch up. i'll post pictures if anyone is interested. thanks moprr71 for letting me use your shop once again.
dabrogger is offline
post #15833 of 114282 Old 01-19-2009, 11:55 AM
Soonerinkc
ordered a mis-alignment spacer for my short arm on the skyjacker lift.
wheelin next weekend at Randolph...gots to be ready!!!
BOOMER SOONER
Soonerinkc is offline
post #15834 of 114282 Old 01-19-2009, 01:30 PM
bebout
bebout's Avatar
2004 KJ Liberty
Well I trimmed my front fenders. I decided not to use the flares, since the tires don't stick out as far as I thought, thanks to 5.5" backspacing. Still need to touch it up a bit but I like it a lot better.
bebout is offline
post #15835 of 114282 Old 01-19-2009, 01:35 PM
tjmdr
I've been playing in the snow for the past week, so I took it to the local coin op & washed it top to bottom. I hate cold weather & salt.
tjmdr is offline
post #15836 of 114282 Old 01-19-2009, 02:10 PM
scooterchef
i installed a set of rough country 2.2 series shocks, holy cr#p does it ride better, also lowered my belly pan to get rid of the vibes from my 3.5 inch opj lift! its like a new jeep again!
scooterchef is offline
post #15837 of 114282 Old 01-19-2009, 02:34 PM
MC_NickP
took mine snow wheeling for the first time. im also debating lifting or not for the time being
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
MC_NickP is offline
post #15838 of 114282 Old 01-19-2009, 02:47 PM
muskoka
TJ
muskoka's Avatar
Hey
Can you show me a closer look at your "homemade snorkle"
Thanks
Low Output 4 Cylinder Jeep Club #36
muskoka is offline
post #15839 of 114282 Old 01-19-2009, 03:05 PM
alecmcmahon
Originally Posted by MuskTJ View Post
Hey
Thanks
like wise, can you post more pics, and or write up?
looks real nice.
alecmcmahon is offline
post #15840 of 114282 Old 01-19-2009, 05:10 PM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
Went wheelin this weekend. Parked it in the garage last night and left it so I could watch my Steelers beat the Ravens!
Gotta unpack tonight.
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
modifications , tj
