What did you do to your TJ today? - Page 1046 - JeepForum.com
 809Likes
post #15676 of 113353 Old 01-11-2009, 11:33 PM
Apex
Recon death squad
Apex's Avatar
Thank you krautzy. Will post pics asap. Oh and I have larry helping me, I am moe. So it's a lot of laughs the whole way through.
So today we finished the front end. The ZJ tie rod assembly. RE steering stabilizer. I now have 10.5 inches of space between my 30's and my flare in the front. 33x10.5x15 will happen when the snow starts letting up.
Drilling the holes in my frame for the track bar bracket was a doozie. Lemme tell ya.
Dismantled 90% of the rear in about an hour. The track bar and upper shock mount bolts WILL NOT BUDGE. we sprayed half a can of kroil on them and were gonna have a go again tomorrow. Much better day today. Other than my 5 trips to the local autozone.
Ps. I want to co-sign the notion that there is no set adjustment for your LCAs or UCAs. It really is a jeep by jeep basis.
Apex is offline
post #15677 of 113353 Old 01-12-2009, 12:50 AM
mrlacy2
Originally Posted by Trombino View Post
Put on a used Warn winchplate, grill guard, and XD9000i. Thanks Craigslist for the great deal.
You need to re-spool it, before you use it!!!
99 TJ Sport 4.0 5 spd. Rusty's 3" lift,& BL, Rubicon D44's Front & Rear, Hand Throttle, Advanced Adapter's HD SYE Kit, Tom Woods Shaft out back,Modified Warn Frnt. bumper/Warn 8000, Kilby gas tank skid, And The Rear Bumper/Tire carrier that I built.
mrlacy2 is offline
post #15678 of 113353 Old 01-12-2009, 05:01 AM
spiderman637
PB Blaster is WAY better than Kroil! and the multiple trips to autozone always suck but they are much better when you can ride in your friends vehicle instead if trying to throw whatever you need into a backpack on your motorcycle!
Friends help you move, good friends help you move bodies
spiderman637 is offline
post #15679 of 113353 Old 01-12-2009, 07:19 AM
NotOfThisWorld
2006 KJ Liberty
Drove it to work in eager anticipation of my front bumper being at my door when I get home!
Blue Jeep Club Member #151
Arizona Jeep Club Founder
NotOfThisWorld is offline
post #15680 of 113353 Old 01-12-2009, 09:12 AM
ET48
Drove it today to the college and parked on the snow pile
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #15681 of 113353 Old 01-12-2009, 10:44 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I walked past it in the garage. Tomorrow I'm going to work on it to get it ready for this weekend of wheeling. Need to replace a TRE, re seat the tires, put the 36s on the jeep, replace a dana 30 shaft with the chromo replacement, and what ever else I find that I need to do to it.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #15682 of 113353 Old 01-12-2009, 11:01 AM
default_user2
like the people who park their lifted truck or Jeep with one wheel on the curb... Makes me laugh when I see that... So stupid...
default_user2 is offline
post #15683 of 113353 Old 01-12-2009, 11:03 AM
cgmrdc
1988 MJ Comanche
put my RE rear uppers and lowers on and fixed my pinion angle... now no more vibes, noises, or crazy shudder on take off! also replaced u joints
cgmrdc is offline
post #15684 of 113353 Old 01-12-2009, 11:24 AM
apollojeep
today
Not much but did install my painted shackles on my front d rings. It took them a while to dry since it was so cold and damp yesterday. Then...drove it to work...not much you can do at dark-thirty AM.
apollojeep is offline
post #15685 of 113353 Old 01-12-2009, 11:39 AM
cvdberg13
Replace my blower motor resistor and switch
2" 4WD Hardware Lift kit.
Rugged ridge seat covers.
Duplicolor Roll on bed liner.
cvdberg13 is offline
post #15686 of 113353 Old 01-12-2009, 12:13 PM
apollojeep
Originally Posted by flexsaharatj View Post
it came out better then I expected, if you have any questions just ask, or if you want better pics, I got the idea from another forum and just modified it to my needs
as you can see (hopefully) I have my CB there with the speaker facing down, my fire extinguisher nice and accessible, flash light on top 12v is to the left along with my pocket knife and scanner
oh and my valentine radar is up there too
Did you bolt this into the holes in the roll bar And you used square tubing? Looks similar to the arizona cb mount which I was going to mimick
post #15687 of 113353 Old 01-12-2009, 12:33 PM
flexsaharatj
nope used shelving rack, and 2 hose clamps on either ends
flexsaharatj is offline
post #15688 of 113353 Old 01-12-2009, 01:20 PM
Sia Bani
Yay, I can finally contribute.
I did the modification to the rubber isolators to get the 31s with greater backspacing to fit against the rear door snuggly so that they're supported and the tire carrier doesn't bounce around with the weight of the wheel/tire.
TJ Rubicon
Sia Bani is offline
post #15689 of 113353 Old 01-12-2009, 02:12 PM
spiderman637
It's not so much about showing off as it is pissing off your superiors. They really hate it
Decided that with everyone talking about ripping off control arm mounts It wouldn't be a bad idea to take some plate steel and make reinforcement brackets to weld to the axle/ existing mounts. No to see what supplies are left over at work...
post #15690 of 113353 Old 01-12-2009, 03:22 PM
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
Originally Posted by dale88 View Post
Although i am having new rocker guards being made now that are bigger i put these on this weekend and painted my gas cap cover.
Originally Posted by JPROBSON3 View Post
Took off all the stickers
Talk about opposites! LMAO!
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
modifications , tj
Solohammer
