What did you do to your TJ today? - Page 1014 - JeepForum.com
 536Likes
post #15196 of 112597 Old 12-20-2008, 03:03 PM
rkwfxd
I used my power washer to clean the undercarriage and transmission.
Let me explain.
I purchased my '04 used about a month ago with 55,000 miles on it. I noticed dirty oil on the rear of the oil pan and all over the transmission and a drop of oil about to fall from the oil pan drain bolt. So now the question has been, "Is my drain plug leaking? Is my rear main seal leaking? Have a bunch of slobs done the service on this vehicle for the past four years?" So......
.....now that it is all clean and purdy under there I can hopefully get an answer to those questions. My fingers are crossed that it is all just a bunch of residual oil from 10-15+ oil changes over the years as the rest of the vehicle seems to have been well maintained.
rkwfxd is offline
post #15197 of 112597 Old 12-20-2008, 04:59 PM
BoatCop
Originally Posted by prd_cdn View Post
Gladly sell you some so you can have for your scrap book ... Cheap !!!
But that's Canadian snow.
At the current exchange rate, 1 foot of Canuck stuff will only be about 8 1/2 inches of US snow.
Alan
2001 Wrangler TJ
2009 Chevy Tahoe
2007 Ford Expedition (Work Truck)
1999 Fleetwood Southwind 34' MH
BoatCop is offline
post #15198 of 112597 Old 12-20-2008, 05:17 PM
raybob
New Rear
Started removing Dana 44 so i can install a Solid Axle HP 60. Can't wait. BTW 44 is listed on ebay if anyone needs one.
raybob is offline
post #15199 of 112597 Old 12-20-2008, 06:14 PM
ET48
I finished up the front Dana 30 with the 4.10 gears! Woot!!! I have the rear apart and will start tomorrow setting it up for the 4.10s.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #15200 of 112597 Old 12-20-2008, 06:27 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Put my XM radio back in today. Have one of the suction cup mounts and attached it to the windshield, ran the wires through the dash. Looks good and I can easily remove it so it won't get stolen. Man did I miss it.
As for the fluffy white stuff, don't miss it. Lived in NY for 20 years and it got old after a while. I'm convinced that the snow plow drivers sat up the street and waited to plow the shoulder until after I cleaned out my driveway.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #15201 of 112597 Old 12-20-2008, 07:29 PM
PBR
PBR's Avatar
sprayed it down with WD40
PBR is offline
post #15202 of 112597 Old 12-21-2008, 12:18 AM
RobFromRI
my XM is stuck on channel 202...
1999 Jeep Wrangler TJ 4.0 5 Speed Chili Pepper Red
2003 VW GTI 1.8T 6 Speed
Jazz Blue 20th Anniversary Edition #3177 of 4000
RobFromRI is offline
post #15203 of 112597 Old 12-21-2008, 12:31 AM
LJameson
I krylon fusioned the center bezel. I love the way it turned out
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #15204 of 112597 Old 12-21-2008, 11:49 AM
flexsaharatj
so I was just messing around in the snow and I see a blue bmw 5 series stuck (RWD), turns out it's one of my good friends, ask if he needs help, so happy had my tow straps, he hooked up his tow hook in the rear of his car, strapped the rope to my rear bumper, and in 2 seconds was out
I was incredibly impressed he was pretty deep in snow and I was in first gear, not even about 3xxx RPM and he came right out
flexsaharatj is offline
post #15205 of 112597 Old 12-21-2008, 11:55 AM
jakecarder
i pressure washed mine. i forgot how white it looks with a good cleaning. i got used to the brown look
jakecarder is offline
post #15206 of 112597 Old 12-21-2008, 12:05 PM
muskegonjohn
Stopped a Chrysler 300 M from spinning on the road after it crossed into my lane!
muskegonjohn is offline
post #15207 of 112597 Old 12-21-2008, 12:45 PM
bigj1974
bigj1974's Avatar
shimmed up my tire carrier. a bit. the tire hangs out a bit too far and the weight, I think, is causing a small tear in the body near the anchor on the bottom right. It's not bad right now, and a fellow Jeeper did read end me on the trail a month ago and that's when I noticed the crack...don't f they're related or not.
So anyway I extended the top right rubber bump stop to give the upper bar more support.
next thing I will do is drill into the carrier and add a bump stop to it to help support the tire a bit more. the stop can rest on the wheel.
bigj1974 is offline
post #15208 of 112597 Old 12-21-2008, 12:55 PM
vtjeepguy97
moved it so i could plow the driveway
vtjeepguy97 is offline
post #15209 of 112597 Old 12-21-2008, 02:19 PM
AlTheKillerr
AlTheKillerr's Avatar
put in a new battery (last night) and she starts now
Photographer
AlTheKillerr is offline
post #15210 of 112597 Old 12-21-2008, 02:41 PM
PBR
PBR's Avatar
drove it in a blizzard! I hate how Jeeps are soo loud when its -30 degrees out haha!
PBR is offline
modifications , tj
WeldedUp
