What did you do to your TJ today? - Page 1009 - JeepForum.com
 1382Likes
post #15121 of 114274 Old 12-15-2008, 04:34 AM
Krautzy
Tarus Fan
Originally Posted by JeSimmers View Post
modified a Taurus fan to fit inside of my stock fan shroud.....installing tomarrow with a delta current control fan control.......
Is there any particular year Taurus for the fan upgrade? What all was done to the Jeep shroud? Is there a write-up with lots of good pictures? Sounds like a fairly simple upgrade that can wring a few more MPG out of my I-6!
Krautzy is offline
post #15122 of 114274 Old 12-15-2008, 06:22 AM
Rob in Arabia
Got it covered in mud (well, wet sand) taking a "short cut" on the school run.
Maroon 2001 TJ Sahara, 2.5 inch lift, 31" Cooper Discoverer STTs, Borla headers and catback, K&N cold air intake, Viking fastback top, Congo cage and rack, KC HIDs and daylighters, Raingler nets.
Blue 2005 TJ Sahara, 2 inch lift, 31'' Cooper Discover STTs, Viking top, KC HIDs and Daylighters.
Rob in Arabia is offline
post #15123 of 114274 Old 12-15-2008, 06:46 AM
jeff83
new front axle and UCA's
build it, wheel it, break it, repeat
1983 CJ 7 (traded for TJ)
1992 YJ Renegade (sold)
1999 XJ Classic (daily driver)
1997 TJ Sport (building)
jeff83 is offline
post #15124 of 114274 Old 12-15-2008, 07:12 AM
dwene
changes rear drum brake shoes...worn out all the way after only 25000 miles...crazy...also replaced a leaking piece of tubing,...it cracked
dwene is offline
post #15125 of 114274 Old 12-15-2008, 07:44 AM
sliseno
replaced my cracked exhaust manifold with a rugged ridge stainless steel header. Much better!!!
Roads? Where were going, we don't need...roads!
sliseno is offline
post #15126 of 114274 Old 12-15-2008, 07:58 AM
_TIM_
Originally Posted by wagster11 View Post
Now if i could just find the tiny leak in the rear of my hardtop that makes my tailgate area damp after downpours!!!
i believe that leak comes from the top of the rear glass where it meets the top. mine leaks the same way and on my buddys old sahara we could see the water drip down from there.
just so i don't completely hijack the thread.... i drove mine to school today
1998 tj|chili pepper red|
_TIM_ is offline
post #15127 of 114274 Old 12-15-2008, 10:33 AM
ET48
I started tearing down and cleaning the front Dana 30 for 4.10 gears late last night. I will also be installing a Aussie Locker in there too. Next week I will start on the rear. Then I can't wait for snow
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #15128 of 114274 Old 12-15-2008, 10:57 AM
gittman140
put the hitch on today, wanna put the electric fan in !!!!
gittman140 is offline
post #15129 of 114274 Old 12-15-2008, 01:08 PM
saylorjerry
Chiseled my doors open, warmed her up, and proceeded to ice skate my way across town in 4wd to work.
Look to the sky just before you die...it's the last time you will.
saylorjerry is offline
post #15130 of 114274 Old 12-15-2008, 04:07 PM
EvilM0nkey
EvilM0nkey's Avatar
backed it out of it's house and cleaned it up. Now I could fit a Jeep and a half in there.
-Ross
EvilM0nkey is offline
post #15131 of 114274 Old 12-15-2008, 05:29 PM
AlTheKillerr
AlTheKillerr's Avatar
drove it then made a thread about it
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV V
Photographer
AlTheKillerr is offline
post #15132 of 114274 Old 12-15-2008, 06:35 PM
LandoCommando
its been quite a while since something constructive was posted in this thread.
Signatures are for attention whores.
Oh the irony.
LandoCommando is offline
post #15133 of 114274 Old 12-15-2008, 07:17 PM
ThomasW
*productive post* I dropped my skid plate to remove my front drive shaft, need to fix the "angry sparrows". It took a 3-4ft breaker bar and an impact wrench the whole way for all 6 bolts in the skid plate, and I broke one bolt. It was one heck of a fight. Now I have the DS cleaned and painted waiting on the CV repair kit to come in.
1999 White TJ Sport:
3'' lift, JK 32" BFG KM's on 17" JK Moabs, Auto, 4.11's, 2 pairs of Hella 500's,
Cobra CB w/ PA, Warn m6000, Flowmaster 40, SpyderWeb ShadeTop, Viking Fastback Top
ThomasW is offline
post #15134 of 114274 Old 12-15-2008, 07:29 PM
PBR
PBR's Avatar
I had to pry the drivers side door open with a pry bar cuz it was frozen! It was 45 degrees last night and this morning well it was -10!
But this winter break I got a huge list of stuff im going to do to it!
Crusher corners and rear tube fenders
4.5" coils
Finish my roll cage with an overhead console
and work on my flat skid
PBR is offline
post #15135 of 114274 Old 12-15-2008, 08:06 PM
ET48
I just finished the installation of the front Aussie locker. Pretty easy to install.
ET48
ET48 is offline
modifications , tj
moemuledeer , Shark_13
