What did I do to my trans? - JeepForum.com
post #1 of 5 Old 10-02-2010, 09:13 AM Thread Starter
1966cj5
2005 tj, automatic 4.0......I jacked up my front right tire from rocker guard. Having a couple of people talking to me I was going to put the jeep into 4wd to keep axle from turning while taking lug nuts off and for whatever reason I cut the key on and put the trans into drive. Well I continued to jackup each corner after getting done and all 4 tires were on the ground I noticed that the left side of jeep was sitting 1 1/2" higher than the right. Went to drive it and it wont engage. Something seems bound up. I went back and jacked up each side and tried shifting but got nothing. Any ideas?
2005 TJ 2.5" OME HD,1.25" BL,1.25" Spacer lift,PSC Rocker Knockers,Jeeperman Rear Bumper,35x12.5-16 MTZ
1966cj5 is offline
post #2 of 5 Old 10-02-2010, 09:39 AM
oakmckinley
I am not quite understanding? You cut the key on??
I think you might have screwed something up in the differential, maybe with the axel. I would take the cover off to inspect.
Going forward its best to loosen the lugs when the tires are on the ground.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #3 of 5 Old 10-02-2010, 09:51 AM Thread Starter
1966cj5
I had the tire off already, I was putting wheel spacers on. I turned the key on so I could move the trans out off park..stupid I know but like I said couple of people talking and had a brain fart there was ability no need for me to take it out of park. Now when I turn the jeep on and shift into driveI can just shift the selector up and down with no resistance and its not trying to engage at al l
1966cj5 is offline
post #4 of 5 Old 10-02-2010, 10:04 AM
otisdog
2008 WK
Well it sounds like the cable is screwed up. There's a cable that runs from the shifter to the tranny. Check it out - look where it hooks to the tranny while somebody shifts it and see if it moves. There's a white bushing on there that breaks.
http://www.jeepforum.com/forum/f9/ge...g-help-761603/
jim
08 Grand Cherokee Overland
otisdog is offline
post #5 of 5 Old 10-02-2010, 11:23 AM Thread Starter
1966cj5
That sounds like what it is, I'm working a 16 hr shift today so it will be tomorrow before I can crawl under there and look
1966cj5 is offline
Trans leak between trans and transfer case swampbuddy TJ Wrangler Technical Forum 6 12-07-2010 02:52 PM
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 09:30 AM
Trans Solenoid Problem ,Auto Trans Guys In Here gtospeeding TJ Wrangler Technical Forum 5 06-17-2010 07:33 AM
automatic trans bleeds trans fluid in 3rd gear if i drive over 60 mph GIJIM TJ Wrangler Technical Forum 2 08-13-2008 07:43 AM
Swap automatic trans for manual trans Hammer49 YJ Wrangler Technical Forum 3 01-29-2003 01:13 PM
