What is a CV shaft and why do I want one? - Page 9 - JeepForum.com
post #121 of 174 Old 04-01-2013, 06:39 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by Martin_N View Post
So when installing a MML, would it be best to adjust pinion also with adjustable uppers (which I will need later on anyway when installing the SYE) to get everything as much in line as possible?
no, just leave the arms alone for now. see if the MML fixes the vibes, if not, drop the t-case down with some washers. if you're one of the unlucky folks where none of that helps, you'll just have to do the SYE.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #122 of 174 Old 04-01-2013, 10:33 PM
FireMedic82
Unlimited04 this is an awesome thread you put together. Very informative! Kudos to you sir!
I do have one thing that is leaving me confused and maybe I somehow over looked it, but here's my question. If the Rubicon's drive shaft slips within itself and has the fixed flange then why would I need to make any changes after a lift if the DC shaft also slips within itself? I think I may just found my answer.....is it only because of the double joints on the transfer case side? Also, you said that the Rubicon will most likely not need the DC, if not should I do a MML with a 2.5-3" lift first and start from there?
FireMedic82 is offline
post #123 of 174 Old 04-02-2013, 06:58 AM Thread Starter
Unlimited04
more suspension travel = more movement required of the driveshaft. DC shaft = more travel & movement capable than stock shaft.
Useful Write-Ups:
Funny:
post #124 of 174 Old 09-26-2013, 12:19 AM
pcwolf
Great write-up, thanks. I'll add my stupid question:
How exactly to get the axle to roll to set the pinion angle?
I understand the control arms set the angle, but don't the stock springs and shocks resist the change in angle?
Is it as simple as jacking the rear to take the weight off the tires then installing the adjustable control arms and cranking on the adjusting sleeve?
-Phil
Man out standing in his field
o|||||||o
pcwolf is offline
post #125 of 174 Old 09-26-2013, 05:28 AM
AllTerrainJK
Typically what I do is set my lower control arms where I need them to square the axle. The upper CAs are not connected at this point. Using an angle finder and hydraulic bottle jack I raise the pinion until it is directly inline with the DS. Then adjust my UCAs until the axle side bolts slide through by hand, then snug down. Next I pull the springs and cycle the axle looking for interference problems. Watch the axle on the gas tank skid and the shocks on the lower coil perches. If something hits you may need to readjust. If the shock contacts the spring perch the perch can either be notched or shock relocated. When everything clears torque all bolts and jam nuts.
Unless you relocate the upper coil perch the spring will develope a bow. The amount the axle was rotated will determine how severely the spring bows.
Roads? Where we're going we don't need roads!
AllTerrainJK is offline
post #126 of 174 Old 01-15-2014, 06:44 PM
TexasChris
Can anyone tell me if the above is a CV driveshaft? My buddy and I pulled this out of his front end but I have never seen a double cardan driveshaft (much less the SYE that would accompany it) in person so we would appreciate some input.
TexasChris is offline
post #127 of 174 Old 01-15-2014, 06:59 PM
AllTerrainJK
Yes that shaft has a double cardon (cv) joint. It's the joint with two ujoints.
post #128 of 174 Old 01-15-2014, 07:12 PM
TexasChris
Thanks AATJ. I wonder why his PO bought such a crappy drive shaft lol... that thing is a rust bucket and doesn't look near as pretty as the ones shown in this thread.
Does a SYE always complement a front CV drive shaft?
post #129 of 174 Old 01-15-2014, 07:16 PM
biffgnar
biffgnar's Avatar
Transfer case front output is a fixed yoke not a slip yoke so nothing to eliminate. The "slip" section for the front is in the middle of that drive shaft.
biffgnar is online now
post #130 of 174 Old 01-15-2014, 07:16 PM
Lazypitbull
Nice
Lazypitbull is offline
post #131 of 174 Old 01-17-2014, 12:39 PM
bbradUSMC
TJ's come stock with a front double cardon drive shaft. Probably the original which explains the rust. Still a good drive shaft though.
bbradUSMC is offline
post #132 of 174 Old 01-17-2014, 10:40 PM
geroux
Makes ya wonder why they just don't put one in the rear too.
geroux is offline
post #133 of 174 Old 01-17-2014, 10:59 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Because the TJ OEM NP231 comes with a slip yoke rear driveshaft output, it was cost effective...
Knuckelhead is offline
post #134 of 174 Old 01-17-2014, 11:51 PM
Maverickxeo
Is it really cheaper though? I mean, a replacement tailhousing and mainshaft is the same as a SYE kit; and the driveshaft is similarly priced isnt it?
Maverickxeo is offline
post #135 of 174 Old 01-18-2014, 12:07 AM
Knuckelhead
AFSOC Retired
The NP231 used in multiple vehicles was cost effective. Modifying it for the TJ to eliminate the TC slip yoke would have driven the production and logistic cost up...
Non-Rubicon driveshaft U-joints. Front shaft and rear shaft use the same? BWFBezerk TJ Wrangler Technical Forum 8 01-15-2010 06:23 AM
XJ front shaft for TJ rear shaft. Couple ?'s TJ311 TJ Wrangler Technical Forum 5 12-09-2009 03:48 PM
Can't get my drive shaft off of the output shaft, any tips/tricks? Dmcastino TJ Wrangler Technical Forum 6 07-23-2009 06:02 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
No front d-shaft-no problem...w/ d-shaft-death wobble and can't get to 50mph...help gadawgz71 TJ Wrangler Technical Forum 5 08-06-2008 03:12 PM
