What is a CV shaft and why do I want one?
| Truck-Lite's New LED Headlamp Series | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! | Poison Spyder DeFenders™ - "Tubeless" Jeep Fende |
#61 | |
Sweet job man! Breakin it down for the everyday man
Patriot Blue Y2K XJ. Big plans, small wallet. http://www.jeepforum.com/forum/f22/00-xj-sport-daily-driver-build-thread-908084-new/ |
#62 |
whew, thats for the props guys...that was a lot of info to gather!
Diablo, feel free to link this where ever, or maybe an admin will move it someplace else. I'll link it in my sig along with all my other write-ups and i'll suggest it in the TJ Tech Boot Camp thread.I think most of that is correct, but it has been a long day...so if you see any glaring inaccuracies please let me know and i'll correct them.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 02-07-2010 at 10:29 AM.. |
#63 |
i may somehow incorporate this info into my sophmore design class
UNC-Charlotte Mechanical Engineering |
#64 |
Nice... stupendous...
C. |
#65 | |
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#66 |
Wait. What?
GREAT work Unlimited04!
#67 |
are you a M.E. too? im in my sophmore year at UNC-Charlotte
#68 |
haha very nice dude!! i had thought about going for that too. What university?
#69 |
great info
#70 |
Bravo! I've always had an understanding but this was a gap filler for sure. It sure is a shame the Thompson design is only good up to 2,500 RPM. It would be so perfect for vehicle applications.
/l ,[____], l---L -[]lllllll[]- ()_)-()_)-o-)_) Google me. |
#71 |
Gonna bump this because of the great info. My first time reading this fully and it helped me understand alot how vibes affect other things than just u joints and why I need an SYE with my small 2 inch lift. When he says that every Jeep is different, he is right. I had to have a 1 inch t case drop and still had slight vibes. The MML worked fine until I needed to change u joints then those slight vibes came back. Every jeep IS different.
SUPPORT THE TROOPS 2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear -Zach
#72 |
Very interesting Now I Know Thanks Excellent write upl
#73 |
Congrats! Excellent job!
Here's my question: I have a 4.5" lift with around 1.5" coil spacers. I have a SYE kit installed from Rubicon Express with a CV shaft from Tom Woods. I took care of my driveline angles as per your drawings above, but I STILL get vibrations though the seat when I'm around 1900-2100 RPM on a highway. Should I point my pinion towards the centerline of the t-case OUTPUT or towards the double cardan? |
#74 | |
that should automatically set where the double cardan lands. keep in mind with a SWB TJ & high lifts, you CAN run into the limit of a standard SYE...thats why JB conversions sells the SuperShort SYE. some say this limit around 6-8" of lift, depending how your getting that lift (TT, MML, SL, etc). Assuming your RE SYE is really the RE Hack'N Tap, it's actually slightly longer than a fixed yoke SYE, like the Advance Adapters or the JB Conversions SuperShort SYE. Meaning you're more likely to run into vibes at very tall lifts. But there are other factors that could the problem. Rear tire balance, out of round tire, bent rim, driveshaft balance, pinion or flange nut not torqued properly, motor mounts, trans mount, etc.
#75 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
