Quantcast What is a CV shaft and why do I want one? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What is a CV shaft and why do I want one?
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 09-10-2009, 08:27 AM   #16
Fropleyqk
Nom Nom Nom
Fropleyqk's Avatar
Excellent write up. Shed a lot of light on things for me. Thanks.
Fropleyqk is offline   Reply With Quote
Old 09-10-2009, 08:54 AM   #17
Unlimited04
Unlimited04's Avatar
Updated to include a few more pictures and this section: When a Rear Double Cardan Shaft is Typically Required
Unlimited04 is offline   Reply With Quote
Old 09-10-2009, 09:08 AM   #18
JeeperFound
Excellent write up!!
My daughter just asked me if I can buy a motorcycle when I'm done with my Jeep!!
JeeperFound is offline   Reply With Quote
Old 09-10-2009, 09:16 AM   #19
Unlimited04
Originally Posted by maaghimself View Post
Anyone ever wonder why they put the fixed yoke with the double cardan shaft on the front with the longer (and less steep) driveshaft angle, and put the slip yoke on the rear of the transfercase and coupled it with a ridiculously short drive shaft?
I believe you can rationalize this one by noticing the front axle flexes more than the rear and the front axle's pumpkin is offset. When the rear axle articulates the pumpkin stays fairly centered, but when the front axle articulates the pumpkin travels a much larger distance - causing a more severe driveline angle when the drivers is at full droop.
Old 09-10-2009, 09:38 AM   #20
tuc
Great artical. At first I though this was about cv axle shafts like the RVC Performance which are the same as the longfield shafts, now if you have any insight on those that would be great. but still good read
tuc is offline   Reply With Quote
Old 09-10-2009, 10:03 AM   #21
Unlimited04
so as I described in post #1, CV's are Constant Velocity joints. A true CV axle would be an axle shaft with a CV joint in it.
Like this front wheel drive application:
Remember they work like this:
Notice there is a boot covering the mechanism. Remember, CV axles are stronger for their given size than a U-joint system, which is why they are used so frequently where space is premium - like Front Wheel Drive sedans and Independent Suspension systems.
Strength is always about two things - material choice and how much force you put across how much area of that material. CV's are stronger by design - they have more degrees of movement and more surface area to spread torque across. U-joints have two points of contact - each roational axis of the 4-pointed U-joint. Constant Velocity joints have the little ball bearings inside that spread the same force across a much greater area - think of it almost like a multiple-pointed U-joint.
The major downside to CV axles in a TJ is they will most likely require some grinding or knuckle modifications and they are EXPENSIVE.
But since we're talking about drive shafts here, read this thread and start another if you feel the need -
http://www.jeepforum.com/forum/f9/front-cv-axles-rubicon-i-got-some-649714/
Old 09-10-2009, 10:07 AM   #22
JerseyDubbin
awesome writeup. Explained a lot to me.
I wish they had a rep system so I could add a rep to you.
Computer Engineer for Gotham technology Group
www.gothamtg.com
JerseyDubbin is offline   Reply With Quote
Old 09-10-2009, 10:08 AM   #23
ZBDsTJ
Very informative and well presented. Well done, sir, well done!
Old Dudes Jeep Club #2750 "Sobriety is overrated."
"Suicide is a symptom of bipolar disorder."
ZBDsTJ is offline   Reply With Quote
Old 09-10-2009, 10:34 AM   #24
GregB_00XJ
GregB_00XJ's Avatar
Excellent write up and awesome pics!
2000 Jeep Cherokee Classic
1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun!
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote
Old 09-10-2009, 10:53 AM   #25
tuc
nope no need to start another thread, you seem to know alot about these things and was just picking at you brian alittle trying to learn more
oh and thanks for the link
Old 09-10-2009, 11:08 AM   #26
Peterpsc
Peterpsc's Avatar
Outstanding. Thank you.
Peterpsc is online now   Reply With Quote
Old 09-10-2009, 11:30 AM   #27
explorerlyon
explorerlyon's Avatar
Outstanding!!! I have been reading all over the internet to try and understand this stuff and just got more and more confused. You're write up is perfect!
05 Rubicon Unlimited, Automatic
explorerlyon is offline   Reply With Quote
Old 09-10-2009, 11:37 AM   #28
jgorm
great job!
jgorm is offline   Reply With Quote
Old 09-10-2009, 12:27 PM   #29
mouse
Weekend Wheeler
mouse's Avatar
Ok I have a question. So since an LJ has a longer wheel base at what point will a Slip yoke eliminator and DC be required? How much lift?
mouse is offline   Reply With Quote
Old 09-10-2009, 01:12 PM   #30
jgorm
Example:
- A 2.5" lifted SWB NV231J equipped TJ will most likely experience vibrations. A small transfer case drop will fix this.
- A 2.5" lifted LJ (LWB TJ) with a NV231J will NOT experience vibrations. No SYE or transfer case drop will be necessary - the driveshaft is long enough the driveline angle is not as severe.
- A 2.5" lifted SWB or LWB NV241J equipped TJ/LJ will most likely NOT require a Double Cardan Shaft. The shorter transfer case allows for a longer driveshaft - less severe angles.
- A 4" lifted NV231J TJ WILL require a SYE or large transfer case drop.
I would figure this to mean that you would need one if you go over ~2.5"
Glock Forum
