what are common symptoms of a bad MAP sensor? - JeepForum.com
post #1 of 8 Old 09-21-2012, 10:18 AM Thread Starter
autopc25
How common is it for them to go bad?
What are common symptoms of a bad MAP sensor?
Is the MAP sensor something that degrades over time?
Is aftermarket a OK replacement for a MAP sensor or Mopar only?
autopc25 is offline
post #2 of 8 Old 09-21-2012, 11:15 AM
TheBoogieman
JEEPS ROCK!
TheBoogieman's Avatar
Symptoms for a bad MAP Sensor would be comparable to an old vacuum advance on a distributor. The timing retards because the ECM thinks demand is low (typical failure is low).I've never had one go bad on any of my Jeeps. Aftermarket one is fine.
http://www.jeepforum.com/forum/f12/s...sensor-655191/
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #3 of 8 Old 09-21-2012, 11:44 AM Thread Starter
autopc25
Boogie, thanks for the quick reply!
autopc25 is offline
post #4 of 8 Old 09-21-2012, 01:50 PM
TheBoogieman
JEEPS ROCK!
Glad to help.
post #5 of 8 Old 11-22-2012, 07:29 PM
scicero1
MAP sensor
Glad to help.
I hope I dont sound like a knob, but symptoms of a MAP sensor could be gas mileage, and other issues. I considered changing mine just to prevent issues. I got a good deal, I work at a store, sometimes its hit or miss, but something this important can help before the code sets off. I just dont kwno where it is
scicero1 is offline
post #6 of 8 Old 11-23-2012, 03:34 AM
Jonny Jeep
Jonny Jeep's Avatar
A bad map sensor or even a small leak at the rubber tube underneath it can cause symptoms similar to a bad O2 sensor and may in some circumstances trip an O2 code. Rough running and gas mileage worsening are potential symptoms.
Jonny Jeep is online now
post #7 of 8 Old 05-15-2015, 03:16 PM
martin314
So if this is true, my map sensor could be bad bc I changed my o2 sensors (upstream) cleaned my throttle body and changed iav sensor and I still have low rpms and will stall when engine is cold then it will run fine for the rest of the time until I leave it over night and start it in the am same problem
martin314 is offline
post #8 of 8 Old 01-28-2016, 01:57 PM
crazyndn
Could this be something similar? Well, in relation to MAP sensor problems. I'm trying to figure this out currently and I think tomorrow will be this angle of attack.
http://www.jeepforum.com/forum/f9/co.../#post33809410
crazyndn is offline
Symptoms of bad Camshaft Position Sensor...? yoshi280zx TJ Wrangler Technical Forum 11 06-07-2016 02:24 AM
TPS Sensor P0123 CEL Error code no symptoms fjc1982 TJ Wrangler Technical Forum 0 02-15-2010 03:50 AM
Cam Position Sensor Symptoms shawnsix66 TJ Wrangler Technical Forum 7 08-18-2007 01:09 PM
Symptoms of A Bad Sensor? Dave R. YJ Wrangler Technical Forum 13 03-19-2007 06:02 AM
What are the symptoms of a bad MAP sensor? wage21 TJ Wrangler Technical Forum 2 01-07-2006 11:46 AM
