What to check for when buying a used np231 w sye? - JeepForum.com
post #1 of 3 Old 06-25-2010, 07:07 AM Thread Starter
dbx11
I found a used t case out of a 98 tj with a sye! Price is 250 but are there any noticable issues I should look for since I can't install it until I get a new shaft? Besides the obvious leaks? The price seems a bit high for this reason especially since I can't see it in use. Any input will be helpful thx
dbx11 is offline
post #2 of 3 Old 06-25-2010, 07:36 AM
Ghaniba
If I was looking to buy one, I would bring a pair of big vice grips and shift it through all positions and spin the yokes. Make sure it's all looking happy, no grinding, etc.
Dave aka Ghan
'99 XJ ['98 TJ, '98 ZJ 5.9 Limited - Retired]
Member, Eastern4Wheelers.org
Ghaniba is offline
post #3 of 3 Old 06-25-2010, 09:06 AM Thread Starter
dbx11
Ok that sounds good will I be able to turn it in low?
dbx11 is offline
2000 4.0 TJ coolent leaking-what to check before buying a water pump? dequity TJ Wrangler Technical Forum 4 03-05-2009 06:02 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 08:02 AM
buying jeep on saturday (seatbelt issue, rust, and possible things to check) ben8jam TJ Wrangler Technical Forum 24 01-05-2008 05:18 AM
Would a '89 NP231 TC & Tranny work w/ my '97 NP231 TC & tranny? MtnHighTJ TJ Wrangler Technical Forum 8 04-13-2007 06:38 PM
Questions about Swapping out Old NP231 for New NP231 computerguy YJ Wrangler Technical Forum 2 08-11-2004 01:42 PM
