What changes have been made to the TJ?
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |
I know that the rear seat was redesigned, and that they changed the roll cage a bit. I also know that the newer TJs have a shut-off switch for the passenger airbag, while the 97's do not. Does anyone know what other changes were made to the TJ over the years, and what years these changes were each enacted? I am looking to buy a new TJ, and just wondering what I would be getting, or not getting if I went with a 2001 vs a 1997, etc. Thanks!
#2 | |
In '03 the front seats changed, little taller and wider towards the top. They also sit a little lower. If you are still looking, make sure to get the Dana 44 rear end. |
#3 |
I think they all still have the airbag switch on the ones that don't come with a back seat.
-=John=- [COLOR=darkgreen]2004 Willys TJ[/COLOR], 4.0L I6 1994 3000GT VR-4, twin turbo 3.0L V6 "[COLOR=white]The no-mind no-thinks no-thoughts about no-things.[/COLOR]" - The Buddha |
#4 |
Gray Goose
Check out this page: http://www.geocities.com/jeepboy49028/changes.html
Off topic, but I noticed the ar15.com email address in another one of your threads... I'm also a member over there. Great Site.
For Sale: WJ Dana 44a w/ 3.73 gears and Varilock - Will part out if someone doesn't want the whole axle. 2004 Jeep Grand Cherokee Limited - January 2011 Grand Cherokee of the Month Build Thread: http://www.jeepforum.com/forum/f197/gray-goose-build-thread-1089523/ http://www.nebraska4x4.org/ |
#5 |
The center dash trim and stereo changed a little bit in '03 vs. '02 and newer. There are also two 12v power supplies on the '03 + (not sure if they all have it but the few Sport's I have seen do).
Mike [COLOR=Yellow]'02 TJ Sport[/COLOR] OME HD, OME Shocks, JKS Disco's, 1.25" BL, 1" MML, 255/85 16" Trxus MT's, Skids and other fun stuff too |
#6 |
Sailcloth top in '01.
I have one now on the wife's and what a difference!!! |
#7 |
Secret Agent Man
'03 and up TJ's come with the back seat as standard equipment, hence, no switch to de-activate the passenger side airbag.
#8 |
One other thing I like about my 01 is that I just turn the key off and pull it out. A later 01 I drove had the little button you push to get the key out. I don't know if it was an official change or what happened, but I hate those buttons.
#9 |
They did away with the distributor and went with coil packs.
#10 | |
Current Jeep: 2004 WJ Limited, stock. Past Jeeps: 1999 Cherokee, 2003 Rubicon, 1987 Cherokee, 1976 CJ5, another 1987 Cherokee, 1976 CJ7, 1983 CJ7, 1977 CJ5, 1982 CJ7. |
#11 |
i have that switch in my 03 to remove the key but it doesn't work. i test drive an 01 before i got my 03 and it had as welll but it worked in that one
#12 |
I know the engine bay looks slightly different in the 99 vs. 00 on the 4.0 inline 6's... Buddy has a 99 and another buddy has a 00 and we noticed that one day workin on them. Weird.
[COLOR=black][B]2004 Jeep Wrangler TJ [i][COLOR="DimGray"]Columbia Edition[/COLOR][/i][/b][/color] [B][COLOR="black"]2007 Victory [i][color="DimGray"]Vegas 8 Ball[/color][/i][/COLOR][/B] [B][COLOR=black]2005 Nissan Murano[i][/color][COLOR="DimGray"] SE[/i][/b][/color] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
