Quantcast What Causes Overheating? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What Causes Overheating?
Old 06-21-2005, 02:13 AM   #1
FlyguyTKI
So today as im leaving 4wheelparts my temp gauge jumped up to the begining of the red arc. around 220*. Its never done this before so i figured it was just the gauge that was messed up and drove about 3 miles. I Look back down and the gauge is maxed out at 260*. Im now 20 miles from the house so i parked it in a lot for a few min and then get going again with the heat on FULL blast which did bring it down a bit. When i got home i let it sit for 5 or 6 hours and then took it out again to see if it would overheat again. Nope not a thing stayed pegged at 210*, so just as a precaution i bought a new thermastate and replaced it tonight. So my original question is what causes overheating. What could have caused this to do it just this one time. Never before and not afterwards (for now at least). The weather was cooler than it has been recently so i doubt that was a factor. Any Ideas??
Texas Jeep Owners Club Member # 101
2007 Red Rock 2dr X JK
Homebuilt Rock Sliders Thread
FlyguyTKI is offline   Reply With Quote
Old 06-21-2005, 04:01 AM   #2
Av Native
Could have been two things i can think of,
1. A air bubble in your cooling system
2. Your thermostat stuck shut
I would bet on the thermostat stuck shut since it had never done it before.
Was it actually that hot or just the gauge saying that it was?? If the coolant temp seememd as usual, it could just be your gauge, One other idea is if the motor didnt seem to really be that hot, It could also be your sending unit..
04 Silver TJ
4" rough country lift
1" currie MML/BL
JC fab rockers and 1" seat lift
33"BFG MT's
Nth degree adjustable upper arm
Nth degree lower arms
Power trax front locker
Av Native is offline   Reply With Quote
Old 06-21-2005, 07:37 AM   #3
lsufanjeeper
i bet you a hundred bucks it was your gauge- mine does it all the time in fact all my gauges pretty much jsut do what they want-- but on the other hand a sticking thermastat is usually the cause of one time jumps like that
'98 Black TJ Sahara Soft Top
Member Of The "Playground" Jeep Club #03
Rubicon Express 3.5
BFG AT'S 33x1250x15'S
Got A 25,000 Tow Strap And Some Chains
Fabricated Shovel Mount On Inside TailGate
Midland Cb With 3' Firestick Channel 21
Some Cool Cosmetic Mods
Brush Guard
JKS Quick Disco's
Hood Mounted Highlift On The Way
Teraflex Steering Skid Plate
Hurculined
Hot Chick Riding Shotgun
Winch
[SIZE=4]GEAUX LSU TIGERS[/SIZE]
.__0_0_0_0
[l_,[____],
l---L -OlllllllO-
()_) ()_)---)_)
lsufanjeeper is offline   Reply With Quote
Old 06-21-2005, 09:08 AM   #4
JJs99TJ
im gonna guess the thermo got stuck too. it happened to me
when i was test driving my Jeep with the previous owner before
buying it.
crazy timing but we stopped and got a new one and replaced it
at his house, never had a problem since.
JJs99TJ is offline   Reply With Quote
Glock Forum
