what causes bump steering? - JeepForum.com
post #1 of 6 Old 05-07-2006, 11:26 PM Thread Starter
losfreddy
Can i please get a brief description of what bump steering is and what it feels like, what causes it?
99 TJ. 5 sp Manual. 4 cylinder. 2.5 liters. airaid intake.
Rock Guards. 32x11.50r15. 4 inch lift. nitro Shocks.
losfreddy is offline
post #2 of 6 Old 05-07-2006, 11:37 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Bump steer is when the steering wheel is forced left and right as the front suspension cycles up and down over bumps and dips in the road. It's caused by poor geometry in the steering system, like when the track bar and drag link are no longer parallel... most often cause by installing a dropped Pitman arm when it wasn't needed.
Gone wheeling, back Sunday night.
Jerry Bransford is offline
post #3 of 6 Old 05-07-2006, 11:50 PM Thread Starter
losfreddy
Jerry, how can i tell if my current pitman droparm is an aftermarket one?
post #4 of 6 Old 05-07-2006, 11:59 PM
Jerry Bransford
Administrator
Does your TJ have bumpsteer? If it does, likely you have a dropped Pitman arm. If not, likely you don't have a dropped Pitman arm.
Measurement wise, I think my old non-dropped Pitman arm had maybe an inch of height difference to it. Dropped Pitman arms probably have more like 3". Both of these dimensions are simple WAGS (wild-a$$ed guesses).
post #5 of 6 Old 05-08-2006, 12:05 AM Thread Starter
losfreddy
yup, that droparm looks like about 3 inches not 1. But why would my steering start bumping now? Think its related to getting mud in the hub cap?
post #6 of 6 Old 05-08-2006, 12:07 AM Thread Starter
losfreddy
could a night of turning the wheel in the wet mudd have put enough strain on my trackbars and cause my passenger wheel to begin wobbling?
YJ steering issue. Not bump steering. JokerZero YJ Wrangler Technical Forum 7 11-25-2009 09:25 PM
Odd steering issue/bump eclipse27 TJ Wrangler Technical Forum 8 12-15-2008 09:53 PM
will an alignment fix bump steering? losfreddy TJ Wrangler Technical Forum 4 04-07-2006 01:47 AM
bump steer and Sloppy steering splitskater TJ Wrangler Technical Forum 10 01-27-2006 04:37 AM
hit a bump...steering goes nuts... traman TJ Wrangler Technical Forum 9 05-25-2005 08:37 PM
